P0980 Error Code
Old Jan 30, 2024 | 04:00 PM
ccoggins's Avatar
P0980 Error Code
Hello all,
I was getting ready to go to work this morning and when I went to put the car in drive the entire car shook and made a thump noise.
My D (Drive) light started blinking and my check engine light came on.
I diagnosed it as a P0980 code. P0980 - Shift Solenoid (SS) 3 Control Circuit High Voltage (TCM)
I was wondering if anyone has run into this issue before.
I drove the car into work - Car Thumps into first and second. Will not go into Third (I think) so I kept the drive at about 30mph.
The car has about 111k miles on it. I am not sure if / when the transmission oil was changed.
It looks reddish brown.
Has anyone run into this?
I searched the forums and I saw the post/video of the guy who checked his solenoid using a battery jumper. I might start there, but I thought I would ask the question first.
Thanks for any help.
Kind regards,
Chuck Coggins III
Old Feb 2, 2024 | 07:47 AM
Pyts's Avatar
Tell me of the first and second Mr. Coggins!
And it sounds like your issue is already diagnosed based on your symptoms and fault code. I don't believe it to be standard fare for the community though.
I can check out troubleshooting for said shift mechanism via the service manual and see if faults there-in align. Doing an independent test on a component like that would be wise. Aftermarket parts supply seems lackluster -- standard motors is far from my favorite brand, though they can make a good product when they want to. If it comes down to it, I'd check dealer/ebay prices before pulling the trigger.
Oh right! You're confident the transmission is filled sufficiently, yes?
Old Feb 2, 2024 | 04:10 PM
ccoggins's Avatar
It turned out to be a broken wire going to the shift solenoid connector.
The car is running just fine now. Although I should get the transmission flushed lol.
Old Feb 2, 2024 | 05:59 PM
Pyts's Avatar
Nice! Nothing fun about chasing chewed up wires -- I'm really glad you got it checked v. throwing a part at it. Kudos!
As for a trans flush, well, couldn't hurt, eh? But if the fluid doesn't look so bad, maybe just a drain and fill will get you by.
Old Feb 3, 2024 | 08:32 AM
ccoggins's Avatar
Thank you!
Yeah, maybe I will see if I can find a video online on how to drain and fill the trans fluid vs. taking it in for a full flush.
Thank you for the idea!
Old Feb 3, 2024 | 11:12 AM
Frenzal's Avatar
I would drain and fill, at least one time. If you want more, I would do it a second and third time, but would not do a flush.
Old Feb 3, 2024 | 09:49 PM
JDFit's Avatar
Originally Posted by ccoggins
Thank you!
This is the way I drain and fill mine, a lot better than the Honda method (which wastes a lot of expensive fluid).
https://www.fitfreak.net/forums/2nd-...ill-flush.html
Joey217
May 8, 2026 05:09 PM
suplexx
May 25, 2023 07:03 PM
PhilRai
Dec 6, 2016 07:12 PM
super_mario86
Mar 14, 2012 05:08 PM
madvibes
Aug 31, 2010 03:51 PM
