Vertical rear wiper DIY help
Old Jun 18, 2009 | 04:15 AM
J3SS13's Avatar
This is a post in response to :
https://www.fitfreak.net/forums/1st-...t-jazz-gd.html
That was a great post and should be helpful for fit owners who want to verticalize its rear wiper.
However, excuse me being a noob, from the steps demonstrated on above post, it is still unclear to me about how we are supposed to take off the black covering of the trunk door in order to expose the inner stuffs under (in this case the dynamo)
Besides, the post only shows diagram pictures from a GD model.
I do not want to break things unnecessarily from my car. If anybody has ever done this to ur GE, could you please clarify?
And after we are done with all the steps, when we are putting back all stuffs together again, in what position should we put the rear wiper back on? Is it vertically or is it horizontally (so the wiper will automatically readjust to vertical position when we turn it on as a result of the steps we did)?
Thanks for your help
Old Jun 18, 2009 | 12:27 PM
wpyeo's Avatar
^o^ Photos for verticallizationing of rear wiper for
:: FIT & JAZZ :: GE
1)All E round in red is the clips 1,2,3,4,5,6 & etc ....
2)after u pull of the black cover u should see
ur wiper dinamo , remove the three bolt round in red ,
the wire cable & holding the wiper compartment on ur car
3)now u already remove the dimano
there's 4 bolt holding this cover round in red
4)now this is what u should see,
there should be 6 hole on it
5)u should get this result
move the arm backward
& now put the metal bar back
than install everything back
hv fun
^o^
Old Jun 18, 2009 | 12:43 PM
J3SS13's Avatar
Thanks sir wpyeo
I saw this thread before. But my problem lies in step 1, where it only show the position of the clip holes attaching the cover to the trunk.
I am confused how we suppose to pull out the cover. Should we tear the whole thing off with force to pop out the clips off its place? Or maybe there is a spot where we can start with using a tool (like a screwdriver) instead of tearing it off.
I do not want to make any irreversible damage because that is a big chunk I'm pulling out, that's why i am hesitant to use force.
With all regards, could you please clarify a bit further?
Any help will be very much appreciated
Old Jun 18, 2009 | 12:50 PM
J3SS13's Avatar
Also, what are those 5 unnumbered clips? They do not correspond to any hole on the trunk chassis behind the cover.
Thanks ^^
Old Jun 18, 2009 | 12:52 PM
stevet47's Avatar
lol, maybe you shouldn't be doing this yourself.
Old Jun 18, 2009 | 07:59 PM
stalonehong's Avatar
Originally Posted by J3SS13
Thanks sir wpyeo
i actually did it myself.
just pull REALLY hard. i was scared at first because I thought I would break something (when the clips come off, it makes a really loud POP)
but u can actually bend the plastic just enought to see where the clips are and just pull. I had 2 clips that were still stuck onto the metal frame. I just used dental floss, wrapped it around the clips....and pulled it off.
its very easy.....wear gloves tho. the edges of tend to hurt alittle since you have to use force to rip off the panel.
heres mine:
before
after
Old Jun 18, 2009 | 09:50 PM
wpyeo's Avatar
Thanks sir wpyeo
just give it a hard pull!
Old Jun 18, 2009 | 10:48 PM
theloxmyth's Avatar
Fit Gadget Freak
Fyi...
Here is some insightful information, I think...
https://www.fitfreak.net/forums/fit-...tallation.html
HTH.
Old Jun 19, 2009 | 01:05 AM
J3SS13's Avatar
aaahh I see now, i will start to pull mine hard then starting today.
I will give u updates soon
Any information about those 5 unnumbered clips from the pictures? Or should I just ignore em?
When we put the rear wiper back on, should I put it vertically? Or should I put it back on its original pos and let the motor reposition itself?
Thanks a lot again sir wpyeo, sir stalonehong, and sir thelox.
I greatly appreciate ur help
Old Jun 19, 2009 | 03:36 PM
leave it vertical.
Old Jun 20, 2009 | 12:08 AM
J3SS13's Avatar
I did it last night, and it worked quite well. Just taking a lil while in repositioning the wiper back to make a perfect pattern on the rear window.
Thanks a lot guys, you have been great help in this matter.
Thread closed
Old Apr 13, 2010 | 04:18 PM
sandblasted's Avatar
my saturday project here.
pip_rocks
May 14, 2025 01:20 PM
Flashesbuck
Jan 4, 2023 11:33 AM
dwiebe
Jul 11, 2022 08:09 PM
Bthasht
Jan 5, 2011 05:56 PM
FitPilot
Oct 3, 2009 07:42 PM
