Grounding improvement for the Fit
Old May 26, 2010 | 06:22 PM
  #41
Roger's Fit's Avatar
Originally Posted by bmxman
hmm.. 2 FF members claiming opposite results. I'm guessing the only true answer is to test your own car as they may have different readings. I personally trust Honda and will leave my Fit as is. Curiosity did get the best of me and I tested my car and had the same results as applemacfit. I do have a friend that also has a GE next time he's over I'll take reading and see if there is a difference.
I would not call them opposite results, they are similar, just one being more extensive than the other. I do agree with Lyon, however, I am operating under a different premise. I like to keep the car looking as close to stock. I am also not too worried about the accessories, they operate well already. Lyon is into the aftermarket stereo scene, and under that premise, all 3 would definitely need to be upgraded. My 96 GMC Suburban used a 10 gauge wire between the alternator and battery (a 105 Amp alternator). I definitely upgraded the big three on that vehicle, but there was more need for me on that vehicle. If i start adding more loads on the Fit's electrical system, I will consider more upgrades. Until then, Ill stick to the problems I see.
He advocates a more extensive modification. I, as one poster stated, keep it simple. Reference all of my other mods. See a theme there. I am less willing to cut into this new car than i am older vehicles. You are free to perform the upgrade at the level you see fit. But we both DID show you the issue, and gave you an option to fix.
Old May 26, 2010 | 06:27 PM
  #42
thefit09's Avatar
I bought the cable yesterday and I'm going to put it in this evening. I feel like Wal-Mart is going to have an unexplained rise in sales of battery cable. lol
Old May 26, 2010 | 06:42 PM
  #43
Lyon[Nightroad]'s Avatar
Lol Roger I wish my attitude online was as good as yours. Sorry for hijacking your thread.
Old May 26, 2010 | 07:41 PM
  #44
beangrower's Avatar
Originally Posted by deleonl1
Anyone find a good spot to attach the cable on an automatic?
in the same boat here. i bought the cable and was about to do it. ...but realized something looked different. here's a pic of what I have to work with:
i was thinking mounting it in one of these three point. #1 seems to have a wire going further in ( don't know where ). i think #3 might be a little to far to reach. what do you folks think?
Old May 28, 2010 | 11:40 PM
  #45
jondotcom's Avatar
If you have a fit sport there is an excellent body ground point behind the driver side fog light if you are also looking for another stealth body ground. Three or more harness ground wires go to one ground bolt there.... to remove the fog light simply inscrew the single visible 10mm bolt on the fog housing.
Cheersi
Old May 29, 2010 | 01:02 PM
  #46
freeurmind69's Avatar
**PLUS REP to you Roger!!** Please keep us informed with your findings and thank you for sharing it with us!! this just makes our great cars even better!! loving it!!
Old Jun 18, 2010 | 07:51 PM
  #47
THEproFIT's Avatar
Originally Posted by Lyon[Nightroad]
Honda has provided a ~90 amp alternator, there is nothing stock in this vehicle that comes close to needing that much power. 1 ohm of resistance will not affect normal operation of the vehicle and as I mentioned that resistance does not apply to the plugs.
it MIGHT only be worth it if it's free and low hassle i.e. using an old extension cord or anything electrical that u were going to throw out anyways and u were already working on the car with some spare time.
otherwise..
Old Nov 9, 2011 | 03:00 PM
  #48
FitStir's Avatar
Tried to rep you but it says I have to spread it around some more. Thanks for the DIY!
I finally got to this mod last weekend, done in less than 5 minutes. But I could only find that cable at Walmart. Local auto parts store didn't have anything close enough.
Wanted to get this done before I start my other electrical mods.... call me paranoid but better safe than sorry.
Old Nov 9, 2011 | 03:45 PM
  #49
MOTOMATT's Avatar
I wish I could see this mod link does not work ?
Old Nov 9, 2011 | 04:04 PM
  #50
FitStir's Avatar
Go to his dedicated website ---> www.fitmods.com and click the ground improvement mod from there.
It's complete with pics and everything.
It's basically just an additional grounding cable from the neg battery terminal to the engine block.
Old Nov 9, 2011 | 05:49 PM
  #51
MOTOMATT's Avatar
Thumbs up
Thank you
Old Nov 11, 2011 | 01:03 AM
  #52
m1sf1t's Avatar
I'm usually skeptical of the value of grounding mods, but I'll think I'll do this one. Cheers.
Old Nov 17, 2011 | 12:55 AM
  #53
Red Rockit's Avatar
This is just one of the "Big Three" that audio tuners do. I do it on all my cars.
As long as the ground wire is larger than the power wire, you're set.
I typically go for 1/0 that can be had for $5/foot, which is all you really need.
Maty J
Jun 22, 2013 02:19 AM
Ciggy
Oct 14, 2010 09:52 PM
mx5
Jan 30, 2010 11:19 AM
shazaam
Sep 28, 2008 10:29 PM
sillypuddy
Nov 23, 2006 03:34 PM
