creaking noise when turning wheel
Old Apr 24, 2012 | 10:44 AM
chilow's Avatar
Odd problem: Noticed that when I turn my wheel to the right (usually at least 1 whole turn and more) there is a creaking noise. If i leave the steering wheel positioned to the right and move the car up and down, the creaking noise is louder. Does not do it when the steering is to the left. Does not sound like power steering. I did not have enough time to pinpoint exactly where the noise is coming from.
Note - when wheels are straight, I cannot reproduce this sound when pushing the car up and down. Only when I have the wheel pointed to the passenger side will it make this creaking sound.
Old Apr 24, 2012 | 10:59 AM
Schoat333's Avatar
There are several things it could be, so you'll have to see if you can get in closer, and pinpoint exactly where its coming from.
I would start by listening near the the tie rod, ball joint, and strut itself.
Old Apr 24, 2012 | 12:00 PM
x_25's Avatar
I get a creaking noise when cornering. Its behind the seatbelt adjuster on the driver side somewhere. I think it is totaly unrelated to what you are hearing though.
What you can do is turn the wheel and have someone else push the car up and down while you listen. Try using a little rubber hose in your ear to help pinpoint where it is coming from.
Old Apr 24, 2012 | 03:02 PM
blackvelvetrs's Avatar
Former Vendor
i have the same problem on my civic. i havent found out what it is yet...mine only happens when i make a U-Turn
Old Apr 24, 2012 | 03:14 PM
raytseng's Avatar
if you have access to a lift, or just are nimble, what you do is just spray down some components with some kind of spray lubricant (silicone spray, wd-40, spray lithium, pb blaster penetrating), and see what part may make the noise go away.
Spray lubricant isn't the right lube though, so once you figure out what is the creak , grease it with some proper lube.
Old Apr 24, 2012 | 03:17 PM
sfar785's Avatar
sounds like a bushing is going out or your strut is creaking.
Old Apr 24, 2012 | 03:33 PM
SSMTEN's Avatar
Have you lowered your car or replaced the springs/shocks done any kind of suspension work that would put you out of alignment? I just put my stock suspension back on the car and, mostly likely because it is out of alignment, the sway bar is creaking/popping. But only on the right side...
Old Apr 24, 2012 | 03:39 PM
chilow's Avatar
This is my friends car. To my knowledge, nothing has been done to it aftermarket wise. I do not recall seeing a swaybar underneath either.
Old Apr 24, 2012 | 06:44 PM
Wafulz's Avatar
So I had same problem when i turn left or when i got the steering wheel and move it back and forth it would creak took it to dealer it was the shock blown so they said and they replace it was gone
Old Apr 24, 2012 | 10:00 PM
chilow's Avatar
Wouldn't a blown shock make noises regardless of where the wheel is positioned? I pushed the car up and down and the noise is only present when the wheel is turned to the right
Btw car only has 20k miles
justinb001
Sep 11, 2018 05:06 PM
dkwvelo
Sep 25, 2014 02:56 PM
Chronoknight
May 29, 2009 12:23 AM
celph titled
Jan 15, 2009 12:18 AM
pokems23
Jun 30, 2007 01:56 PM
