What is wrong with my Fit??
Old Jun 12, 2012 | 06:32 PM
  #101
SilverBullet's Avatar
Originally Posted by Steve244
No, it won't. It's designed for less than 87octane (regular in Japan is 89RON).
bwahahahahahaha.
You cant prove that and hondata proves that MBT timing happens with high octane of 91/93 R/M.
Hondata:
1. Using a (very) high octane fuel, the engine is tuned to find the ignition timing which makes the most power. This is called 'mean best torque' (MBT) ignition timing.
2. Using 100 octane (RON) fuel, the engine is tuned to find the maximum spark advance before any knock is likely. This is called the 'knock ignition limit'.
3. Using 90 octane (RON) fuel, the engine is tuned to find the maximum spark advance at this octane. This gives the low octane knock limit ignition advance. The reason 90 and 100 octane is used (approx 85 and 95 octane r+m/2 method) is because this is the likely range of fuel octane the engine will used with.
Old Jun 12, 2012 | 06:35 PM
  #102
Subie's Avatar
Originally Posted by malraux
Well I guess the only way this thread could get worse is an octane debate....
Here we go... I knew I shouldn't have mentioned it...
Old Jun 12, 2012 | 06:47 PM
  #103
Steve244's Avatar
Originally Posted by SilverBullet
You cant prove that [snip]
Others already did. You were there.
Old Jun 12, 2012 | 07:34 PM
  #104
hayden's Avatar
Old Jun 12, 2012 | 07:36 PM
  #105
89 is a lot different then 87. Sorry Subie but a lot of the problems described is caused by gasoline, not that high octane will fix what is broken but helps prevents it.
Old Jun 12, 2012 | 07:57 PM
  #106
Subie's Avatar
No prob SB! I'm with you there...
Old Jun 13, 2012 | 09:37 AM
  #107
Steve244's Avatar
What does "89 is a lot different than 87" mean?
The standard for regular gas in Japan is 89RON. This is equivalent to 84AKI here (using (R+M)/2 and a .95 conversion factor). So if you mean Honda designed the Fit for "a lot" lower octane than is available here, you would be right. High octane will prevent damage from knocking in a car that needs it. The Fit isn't it.
Honda Japan says in the owners manual you may use higher octane, but the difference in performance is not significant. (link to somewhat fractured google translation).
To the OP: definitely, try a tank or 3 of hi-test. It will unlock the hidden potential of your econobox. Potential Honda and Big Oil can't tell you about.
Old Jun 13, 2012 | 12:12 PM
  #108
Japans regular is our premium. 95 ron. Octane rating - Wikipedia, the free encyclopedia
Old Jun 13, 2012 | 12:31 PM
  #109
hayden's Avatar
I don't know what MOR (motor octane rating) is but would this online conversion tool help clarify differing opinions?
Octane Information And Calculator
Old Jun 13, 2012 | 01:49 PM
  #110
Steve244's Avatar
Someone edited wiki. Prior to June 7 it said 89RON was regular. Coincidence? You'll note I gave the same cite along with the pertinent standard JIS K 2202 on May30. Here's another link to the standard stating 89RON. Want me to change it back?
Edit: the japanese wiki (translate using google if you wish) shows regular (fuel #2) as being 89RON since 1986. The latest standard was published in 2007. Before 1986 it was 85RON.
Old Jun 13, 2012 | 01:54 PM
  #111
Steve244's Avatar
Not really.
It's just the average between RON and MON (R+M)/2. In Japan they don't test/publish the MON rating so extrapolation requires a "fudge" factor. 95% of the RON rating is what is generally used.
The point is that the standard in Japan JIS K2202 requires a minimum of 89RON for "regular" (and 96RON for premium) regardless of what someone edited wiki to say. The equivalent here is someone less than 89 for regular. 0.95*89=84.55, less than the minum standard for regular here (at least at lower elevations).
Old Jun 13, 2012 | 02:12 PM
  #112
Something is missing in the translation. They do not say RON.
Here is something about 100 RON in 1986. JAPAN FIRMS TO LAUNCH SALES OF 100 OCTANE GASOLINE
So if your getting 35 mpg on regular and then use premium and get 39 or higher is that a waste of money? There is a reason 100 ron sales jumped up over 300 percent in '86 from 6 percent to 20 percent. Keep in mind that ecu was tuned to their 95 RON regular fuel.
Old Jun 13, 2012 | 02:29 PM
  #113
Steve244's Avatar
Japan doesn't use (R+M)/2. In US publications we often don't see "87AKI using (R+M)/2 method." Check this page, it specifically states 89RON for fuel type 2 (regular).
If you are getting 35mpg and jump to 39 using premium it's not a waste of money so long as premium is less than 11% more than regular. What did you expect me to say?
You're a good consumer, Bullet. It's ok.
Old Jun 14, 2012 | 07:04 PM
  #114
seb9316's Avatar
So coming home from work today my tranny started holding in 4th gear (no torque lockup) even though I had the shift lever in drive! Heading up a hill and it simply would not engage 5th gear cresting the hill or the lockup converter. WTF Honda?????
Old Jun 14, 2012 | 07:27 PM
  #115
krunk13's Avatar
MY God......Your Fit knows that you hate it.......Get out while you still can
Or use Ye Old Warranty
  #116
malraux's Avatar
The lockup disengages during power situations like going up a hill and getting up to speed. Buy another car because clearly this car isn't going to make you happy because it will downshift.
Old Jun 14, 2012 | 07:45 PM
  #117
seb9316's Avatar
You clearly are an imbecile. The car would not disengage from the gear it was in AT ALL.
Now say there isn't something wrong with my car. Yeah that's right, a Honda Fit with barely over 8000 miles on it. Explain it. Go right ahead. You too Krunk. Since Honda could you know, NEVER have a flawed car come out of their factory. Fucking blind loyalists. Holy shit.
Old Jun 14, 2012 | 08:18 PM
  #118
malraux's Avatar
Lacking data on incline, speed, throttle position, etc it's hard to say if that's a problem or not. Depending on situation, the TC will not engage and not shift into highest gear. Especially situations like going up hill and then getting up to speed. A gear box that works like that is clearly unacceptable to you. You should get rid of the car.
Old Jun 14, 2012 | 08:24 PM
  #119
krunk13's Avatar
I'm looking outside at my MT Fit right now....I might go for a leisurely drive. OP if we cant help you and you wake up tomorrow morning still not liking the car common sense says that you should sell it. You seem to have already condemned the car any way. You dont like it so your gonna keep finding faults with it
Old Jun 14, 2012 | 08:26 PM
  #120
seb9316's Avatar
Would you ever consider another car that gets just as good fuel mileage as the Fit, yet is larger and has more power? I'm not auto tranny fan myself, so let's leave that out of the equation. Would you?
