Help my dying fit
Old Nov 23, 2014 | 11:30 PM
eric11097's Avatar
Help my dying fit
Hello I have a 2008 Honda fit. Today I was driving in some wet conditions. I was spinning the tires a bit but otherwise driving normal. After awhile a really loud rattling sound came from the center console of the car. The sound got worse after shifting gears but the sound eventually subsided. Later i was driving just cruising in third gear when the same thing happened. Has anyone experienced similar problems and if so what is the cause. I have read other forums saying the trans is about to go. I have a manual transmission with 55k miles and a new clutch with 6k on it.
Old Nov 24, 2014 | 09:24 PM
patm95's Avatar
Could it have been a rattling exhaust? Only other thought that I would have is that if you are replacing the clutch at 49k, do you drive the car hard? Popping the clutch could cause the transmission to go sooner. I have 110k on my stock clutch and there is no slippage or anything.
Old Nov 25, 2014 | 12:26 AM
Mini_Odyssey's Avatar
loose heatsheild?
Old Nov 25, 2014 | 03:56 PM
Codger01's Avatar
I would say heat shield. I had the same kind of noise after I picked up my Fit from the bodyshop after a run in with a chunk of cast off tyre tread. They tightened it up and I have had no issues since.
tduffy
Jul 27, 2013 05:47 PM
CrazySte
Jan 4, 2012 03:22 AM
Chairman Kaga
Dec 21, 2011 02:21 PM
bigcanoe
Jan 15, 2010 11:36 AM
CorrodesTheFilm
Oct 21, 2008 07:05 PM
