Broken Wheel Stud
Old Dec 27, 2014 | 04:44 PM
Steven Hung's Avatar
Broken Wheel Stud
A couple of weeks ago I had a shop install a set of Michelin Pilot Sport AS3 205/50R16 and today I found that they had cross threaded one of the lug nut. The lug nut wouldn’t move when I tried to loosen it. After several attempt with an impact gun and still refused to budge I took out the 3’ cheater bar and the stud snapped. Yeah, what fun!!! Inspecting the wheel hub I don’t see any room to remove the broken stud with a 2 ½ lb hammer without removing the hub. I removed the knuckle, pressed out the hub, hammered out the broken stud, installed a new stud with a stud puller and pressed every thing back together. Here are some pictures that I took.
Wheel hub pressed out with broken stud hammer out.
New stud installed with stud puller.
Pressed the wheel hub into the knuckle
Old Dec 27, 2014 | 05:51 PM
flash75's Avatar
You did a nice job replacing the broken stud. I guess I have been lucky to deal with a tire shop that always torques the lug nuts when they replace tires. If the shop does it right you will never have broken studs. Using a impact tool to tighten lug nuts can also warp and ruin your rotors.
I would have taken the car back to the shop that caused the problem and insisted they fix the problem.
Clifton
Old Oct 6, 2016 | 09:21 PM
56chevydan's Avatar
Most tire shops use torque sticks with their impact gun. The torque sticks will not allow the wheel bolts to be over-tightened. Without the torque sticks, disaster lurks.....lol
wh22366
14
Jul 13, 2024 10:45 AM
Phoenician
Oct 5, 2016 12:08 AM
Rollerboots666
Apr 10, 2014 12:02 AM
lji
Feb 11, 2014 06:30 PM
Vanct
Apr 12, 2011 04:18 PM
