V6 Honda Fit Build
Old Aug 26, 2015 | 09:46 PM
  #121
PinkBatman's Avatar
So this is how I spent the entire weekend.
Looking over diagrams trying to figure out why in the He-double-hockey-sticks
the fuel pump wouldn't fire. First problem was that the ECU didn't seem to be spitting out a +12v signal to fire the FPR. So I hunted for missing grounds, and blow fuses, and broken relays. LONG story short, A15 outputs a ground signal to fire the relay, once I figured that out the fuel pump still didn't fire. So once again I started pulling more fuses, and relays, and then spent about an hour looking for an inertia switch that was mentioned in the troubleshooting guide, a guide that was for a Civic, apparently, another thing that got overlooked in my mad dash to get this project busted out.
Another day of looking over the A plug for the Fit harness I noticed a sneaky little second relay that needs to be run to ground that should allow the pump to run, ground that lead and still nothing. Back to the diagnosing again, using the correct guide this time, do a few checks. Turns out at some point the lead from the ECU to the chassis got disconnected. Plug that back in and I hear that glorious fuel pumping sound.
Now the bay is a disaster from all the testing and wire swapping that happened, still haven't fired, but I think it should be pretty easy, maybe a missing ground or something silly like that.
Additionally here is the Fit A plug and its replacement.
Old Aug 26, 2015 | 10:05 PM
  #122
connor55's Avatar
Damn... Gotta love wiring issues
Old Aug 26, 2015 | 10:31 PM
  #123
FittinglyFittedFit's Avatar
Nice to see the progress on this! I am loving all the projects within the project! FIT-CEPTION!
Old Aug 27, 2015 | 02:40 AM
  #124
PinkBatman's Avatar
Old Aug 27, 2015 | 05:19 AM
  #125
Black3sr's Avatar
No Sheet!!!!!!!!!!!
Oh the satisfaction on hearing that start up. Well done!!!!!
Old Aug 27, 2015 | 09:10 AM
  #126
Bassguitarist1985's Avatar
Dude, with the right exhaust that motor is going to sound badass! Congrats on all your hard work!
Old Aug 27, 2015 | 09:22 AM
  #127
g95pteg's Avatar
been watching this thread since it was first posted... so good now that theres video of it starting up... can't wait to see this thing move!
Old Aug 27, 2015 | 10:07 AM
  #128
cbgoding's Avatar
You forgot the NSFW tag!
Old Aug 27, 2015 | 03:44 PM
  #129
Sylak's Avatar
Wow, That's Loud!. Yeah wiring issue are always a freaking pain. At least mine were always on protoboard lol.
Nice progression of your progress. Steady and painful, but it will be worth it!
Keep it up.
Old Aug 27, 2015 | 09:52 PM
  #130
Red 05's Avatar
What a beast! That's rad dude...
Old Aug 30, 2015 | 02:52 PM
  #131
counterFIT's Avatar
Damnnnn... I want to see some hp numbers! With the right exhaust it could sound like a Lambo V10!
Old Sep 1, 2015 | 04:29 AM
  #132
PinkBatman's Avatar
Thanks everyone! Tons of progress this weekend, got a bet going I will driving this car in the next 24 hours.
My second junkyard J came with these upper manifolds so I finally put them back to work.
This is the section that goes over the steering rack, way different than the Civics we usually do. Surprisingly tight.
First pass at the rear had the split way longer with the merge way back where the cat used to sit. This setup looks killer but is just impossible to get to fit.
Here is the whole y-pipe tacked together. You can see how much shorter is ended up being, merge right above the steering rack.
As I was fitting the merge to 2.5" my old man challenged me to a Welders Nationals. I think I had the better looking beads, but had a blow through, that's a big points deduct. Did a few minutes of port work to improve flow, didn't grab a photo, maybe tomorrow.
This is a mild steel joint that got some great color. The y-pipe is mild because I have a better plan coming up next year
The ol v6 car getting gutted, RIP Sedantha.
Hasport EG swap axles fitting pretty nice, noticed this axle bearing is out, not just a little bit, got a new one coming in the morning.
Abracadabra, the engine is gone again!
Little braided clutch line, Honda added a nice little hole in the shock mount so you can reach the fittings. Thanks guys.
Throttle cable mounted, had some trouble with the MIG.. again. But it is functional.
Don't think this was posted yet, here is the RSX pedal mount to the adapter plate.
Old Sep 2, 2015 | 05:40 PM
  #133
counterFIT's Avatar
That's some nice fab work for sure. You're definitely doing it right.
Old Sep 2, 2015 | 06:26 PM
  #134
harribert's Avatar
Originally Posted by Myxalplyx
PinkBatman,
Where can I find more information about your road racing civics? 1/4 mile times and trap speeds? Any videos of them? The V6 versions specifically.
Also, do you know what their curb weights were and power they had in their engine?
Is this you ---> J32A2 V6 Civic first run down drag strip. - YouTube
Sorry about quoting an old post. That's PIR in Portland, OR.
Old Sep 3, 2015 | 12:00 AM
  #135
C-Web's Avatar
Congrats on getting it fired up for the first time. I'm not on here much these days other than to check your progress. Been following since the beginning and can't wait to see it on the road!
Old Sep 5, 2015 | 04:14 AM
  #136
PinkBatman's Avatar
Thanks everyone!
First things first, I did not win the bet . Wanted the car running at 2am, ended up being some problems. Reinstalling the engine there was a bolt hole that was not quite lining up and needed a bit of reaming, then the rear mount moved off the tacks and shifted about 4mm. Almost no photos since I was up until 6pm the next day buttoning stuff up to get the car loaded.
Like I mentioned the front bearing was absolutely shot so that got replaced first thing.
The last half of the exhaust is just temporary, but hilarious. Super stoked that this came together to well since it was 3am and I was flying through the project. Thankfully I got help with the final TIG work that saved me about an hour of welding.
Got to Speedfactory around 7 this morning and tried to hook up the AEM to 2 different computers, one which had connected to the ECU before. For some reason the USB connection would not work and the serial line was fine. Once that was going Kevin and I checked through the sensors and everything looked good. Started up and set the timing, got all the cylinders firing and drained the tank to get some fresh 92 octane.
James jumped in and did a bunch of pulls getting it dialed in, tested a few manifolds and got some good data. Something I was amazed by is how much the motor picked up on to by opening the butterfly on the stock a2 intake. Didn't get a shot of that but it was around 20hp instantly and just a small loss on the bottom, pretty amazing.
This is one of the earlier runs spinning to 7k, doesn't show how chest wrenching the exhaust really is.
By the end of the day we hit 278whp | 263tq, fantastic numbers, much better than I could have hoped for!
This chart is my v6 sedan vs the Fit.
Only one thing left to do is break in the clutch.
Old Sep 5, 2015 | 12:40 PM
  #137
Lance's Avatar
Absoulte sickness
SMOKE EM IF YOU GOT EM! SUCH AN INSANE BUILD . I wonder if the J32 would have much problem going into an 07 GD3 Fit.
Old Sep 5, 2015 | 01:51 PM
  #138
counterFIT's Avatar
Holy christ. 278whp???? You could probably beat an E46 with that thing lol.
Old Sep 5, 2015 | 03:03 PM
  #139
g95pteg's Avatar
Damn.. I want that in my GE.. Such a sleeper
Old Sep 5, 2015 | 07:46 PM
  #140
sultanofslide's Avatar
Speedfactory? Are you in the PNW?
