2010 Fit. Driver's door won't unlock.
Old Jul 21, 2018 | 10:26 PM
Eric Schumann's Avatar
My driver's door doesn't unlock with the remote nor the key manually, this in turn means that none of my doors unlock .I cannot get into my Honda fit .seems rediculous to have a single point of failure with one manual lock that doesn't allow any door to work when it's broken.
Any help is appreciated .
Old Jul 22, 2018 | 03:31 AM
Black3sr's Avatar
Google suggests try spraying key with WD40 and working it back and forth and respray a few times. A lock de-icer would work too.
Do you have spare key? It may be a dead battery in the fob.
Old Jul 22, 2018 | 09:43 AM
upallnight's Avatar
He tried unlocking the door on the driver side with his key and that didn't work.
Most likely the actuator module on the driver side door has failed. Good luck with trying to get that fix if you can't get into the car.
Old Jul 22, 2018 | 11:55 AM
There has got to be a way to get into the car when the drivers lock fails .what kind of idiot engineer would design a system where all doors don't work, when only one is broken .
WD-40 didn't work.
Old Jul 22, 2018 | 03:42 PM
James Butler's Avatar
Can you use the key to get in back hatchback , crawl in and open doors from inside?
Old Jul 22, 2018 | 04:24 PM
Mine is the sport model .Anyway, it finally opened .I'm leaving it unlocked until I can get the lock replaced .
Old Jul 23, 2018 | 05:58 AM
Black3sr's Avatar
Did it open with fob or key?
Old Jul 23, 2018 | 01:28 PM
upallnight's Avatar
Unlike the Base Fit that has a key on the driver and passenger door and a key lock for the hatch, a sport model only has one key lock.
Old Apr 17, 2020 | 08:48 AM
Sihlobo Khumalo's Avatar
I had the same issue with HondaAirwave, a tug of the cable under the hood gave me access to the car battery which had died.
upallnight
Jul 9, 2018 11:07 AM
ivymae
Sep 29, 2017 04:03 PM
snit fit
Jul 29, 2017 11:22 AM
nfs480
Jul 1, 2014 04:03 AM
Vince_TB
Oct 24, 2012 02:56 AM
