GE8 Lowered Thread - Post your pics!!!
Old Sep 11, 2011 | 02:01 PM
  #1061
dovey's Avatar
hello, can you take a sideview picture of it if you have time? so i can see the fender. thank you..
Originally Posted by dels
Not to many pics of GE8's with NF210's so I thought I would post up if anyone else was interested. Its been a couple of months since installation so I figure it has settled up.
Old Sep 11, 2011 | 09:38 PM
  #1062
flip's Avatar
Eibach Sportlines
Old Sep 11, 2011 | 10:26 PM
  #1063
555sexydrive's Avatar
I'll contribute, dropped on J's/Crux. Camber of -2.4 and a slight toe out, 12k front (8 hardness, out of 30) and 8k rear (7 hardness), 45mm drop can go lower still, but completely unnecessary.
About the hardness, I don't think very many people would even want to daily drive this thing, with the solid engine mounts and even just 12k/8k spring and the hardness set to 8/7 it is quite stiff. With the rear shock having a poly insert, it creaks. Not at all a problem for me as I like "RACE CAR". When on circuit I'll increase the stiffness to about 15 front and 20 rear, will make for quite the ride.
Old Sep 12, 2011 | 08:59 AM
  #1064
SSMTEN's Avatar
Your car is so awesome 555....
Old Sep 17, 2011 | 02:03 PM
  #1065
12toothassassin's Avatar
Modest 1.5" drop with Eibach Pro Kit, but I love it! Cant believe I didnt do this sooner.
Old Sep 17, 2011 | 02:05 PM
  #1066
I like the white antenna, nice touch.
Old Sep 17, 2011 | 05:26 PM
  #1067
dovey's Avatar
hello sir, is that stock tires and rims?
Old Sep 18, 2011 | 12:34 AM
  #1068
Yes stock base rims with covers removed and aftermarket replacement tires that are the same dimension as stock tires. Rubbed my fender well with stock spec! I think its because I cut the bump stops.
Old Sep 18, 2011 | 02:49 PM
  #1069
Pang3t's Avatar
alrite cool thanks for ur post i was deciding on a 1.5" drop and looks good.
Old Sep 18, 2011 | 03:09 PM
  #1070
dovey's Avatar
so what tires are you using now sir?
Old Sep 18, 2011 | 05:33 PM
  #1071
Yokohama Avid Envigor 175/65R15 84H
$290/pair out the door at reputable tire shops including mount/balance, nitrogen and road hazard.
Old Sep 18, 2011 | 08:52 PM
  #1072
dovey's Avatar
If you use the stock, it rubs?
Old Sep 18, 2011 | 10:56 PM
  #1073
Yes, I was pretty surprised. If I were to do it again I would probably leave the full stock bump stops the way they are and not trimmed down like the spring instructions suggest - this would likely keep it from rubbing though Im not 100% sure.
Old Sep 18, 2011 | 11:10 PM
  #1074
Mr.Dan's Avatar
so jealous of your ride
Old Sep 18, 2011 | 11:16 PM
  #1075
dovey's Avatar
hello sir, sorry noob/newbie here. what do u mean by full stock bump stops if you dont mind me asking? thanks
Old Sep 18, 2011 | 11:47 PM
  #1076
Goobers's Avatar
in the shocks/struts are pieces of rubber, called bump stops. the idea is they prevent the shock from fully compressing to the point where it'll damage itself (end of compression or blow a gasket).
some springs instruct you to cut the bump stops. but there are a few springs that also tell you that you don't have to (Swifts). "full stock bump stop" just means leaving it alone.
Old Sep 19, 2011 | 12:16 AM
  #1077
jookybanana's Avatar
HKS hipermax s-compact's
Old Sep 19, 2011 | 01:38 AM
  #1078
90 DGRZ's Avatar
SICK JOOKY!^^ so thats what it looks like painted......
sorry, my camera phone SUCKS.
Old Sep 19, 2011 | 02:07 AM
  #1079
FittedOnEm's Avatar
^ what coils are you on? looks 1000x better in person
Old Sep 19, 2011 | 03:19 AM
  #1080
dovey's Avatar
Thanks for explaining...
