3rd Gen GK Specific Fit Interior Modifications Sub-Forum Threads discussing interior modifications for the 3rd generation GK Honda Fit
Rear Window Camera
Old Feb 17, 2019 | 11:28 AM
SilverEX15's Avatar
Rear Window Camera
I'm sure this has been discussed before, but I'm asking here. Do any of you have a dash cam in your rear window? Do you use the front/rear combo, or do you have separate units? I already have a dash cam, so I'd rather not buy another system. I already have 12v available in the hatch area (12 outlet), so I could tap into that wire for power. I'd appreciate any info. I have the Viofo A 119 V2 in the windshield.
Old Feb 17, 2019 | 12:48 PM
Action Jackson's Avatar
I have a dashcam with rear view camera. I put that camera on the inside of the front windshield facing rearwards. I wanted something to capture more of the interior and some of the sides of the car while still facing backwards.
Old Feb 17, 2019 | 01:53 PM
2Rismo2's Avatar
This is what I did on mine: Dual camera dash cam
Old Jun 28, 2019 | 01:56 PM
silverrose12's Avatar
i am looking for dash cams also..
i want both front and rear dash cam but there seems to be limited option =S
can anyone give me their 5cents?
Old Jun 28, 2019 | 02:15 PM
SilverEX15's Avatar
We got one of these for each of our Fits - excellent. Get the one with the GPS, and the mount stays on the windshield, but the camera removes easily. It's small, but has very good reviews. Be sure to get Version 2 (V2) because it's better some how. Also, be sure to get the kind of micro SD card they recommend.
https://smile.amazon.com/VIOFO-Inclu...fo%2Caps%2C145
Old Jun 28, 2019 | 02:44 PM
thank you for your recommendation. but its looks like this one is front camera only ?
Old Jun 29, 2019 | 06:57 AM
SilverEX15's Avatar
Yes, buy you could buy two. It's a very good quality camera. Reviews I've read have indicated that rear cameras that come in sets are not very good quality. Now how much quality you need for a rear camera is debatable.
Old Jun 29, 2019 | 09:09 AM
yeah.. that's what i heard too...
i am also looking into mirror dash cams.. they seems to be fairly cheap and all of them comes with rear camera.
Old Jun 29, 2019 | 10:54 AM
There are dashcams designed for parking surveillance with a minimum of 2 cameras. You can go all out with a 4 camera setup. I find that 720p is barely adequate to capture a license plate.
Old Jun 29, 2019 | 11:34 AM
true. i think the camera quality needs to be AT LEAST 1080 at 60FPS.
another thing is that most dash cam sucks when it comes to night vision.
Old Jul 17, 2019 | 06:18 PM
Maxplo's Avatar
I can't agree with you more!!! 1080p is not overkill it is needed
Old Jun 16, 2021 | 07:25 AM
saveMT's Avatar
I much prefer separate units instead of one unit with multiple cameras. Call it redundancy or something. Yes, more wiring mess, but oh well.
I have one forward-facing at the windshield, one rear-facing at the rear window, and another forward-facing unit from the back side, so it sees interior and through the windshield.
Old Jun 16, 2021 | 07:59 AM
SilverEX15's Avatar
Right. I don't like the double-camera kits. The rear camera is usually lower quality. Another possibility is in front facing the passenger compartment. There are swiveling cameras, so if you're stopped by a cop, you can swivel it to cover what's going on.
Old Jun 16, 2021 | 08:56 AM
woodenpickle's Avatar
My wife bought me a mirror cam with a rear camera for Christmas last year. Finally got around to installing it a couple months ago. Overall, I'm happy with it, and it was pretty easy running all the wiring. It is one of the VanTop models you can find on Amazon (the 610). I'd had it on one of my wish lists for a while, and it went on sale from ~$100 to $60. It had a reverse light wire that could be hooked up to throw it into rear camera mode to assist in backing, but since my Fit already had a backup camera, I opted to not connect that. Probably the only complaint I have is the amount of jigglyness it has when you turn off the video feed to use it as a "regular" mirror. Some day I'll probably try putting some memory foam or dynamat or something similar between the camera and the original mirror to see if I can further mitigate the vibration. I did mount the rear camera inside the car to the center child seat anchor point on the ceiling. It is still usable, but the camera view would be useless while in use. I wasn't too worried since this car is my commuter and rarely carries anyone but myself, plus all my kids are older than child seat age now anyway.
Here's some pics in case any one is interested.
Old Jun 17, 2021 | 09:25 PM
NWCH's Avatar
I'm running Blackvue front and rear cameras in my Fit. Highly recommended.
https://blackvue.com/
SilverEX15
Jan 11, 2023 08:43 AM
Scott Wyman
Jul 23, 2020 11:17 PM
SilverEX15
Aug 23, 2014 10:03 PM
jeuda
Nov 17, 2013 06:44 PM
celloville
2nd Generation GE8 Specific Fit I.C.E. Sub-Forum
Apr 20, 2013 11:22 PM
