Question about immobilizer
Old Jan 9, 2015 | 03:10 PM
cwild's Avatar
I've been doing some searching and have not been able to find a definitive answer on something. I have a 2015 EX 6MT with the Smart Key. As it's been quite cold in the mornings, I've been starting my car and letting it warm up while I finish getting ready in the house.
The car does not allow me to lock the door from the door handle button when it is running, so I'm a little concerned about security. The car beeps when it is running and the key gets outside the sensible proximity, but still allows it to idle. I'm wondering if there is a feature where the immobilizer would cut the fuel system off if someone attempted to jump in and drive off with it.
Anyone have any info on this?
Old Jan 9, 2015 | 04:17 PM
carrier's Avatar
Immobilizer
Hi,
As far as I know, anyone can get into your car while its running and drive away with it. They just will never be able to turn it off, as *then* the immobilizer would kick in.
Old Jan 9, 2015 | 04:29 PM
NotBlake's Avatar
Originally Posted by carrier
Hi,
Correct, the car wont restart without the key, but there is no way to secure the car while it's running if you have the smartkey system. This was a major bummer for me.
Old Jan 9, 2015 | 05:32 PM
Vanguard's Avatar
This problem must be limited to the MT version. One of the nice features about the remote start option (for CVT models), is the door remains locked while starting, then requires you to unlock the door to get in and leave.
Old Jan 9, 2015 | 06:09 PM
cwild's Avatar
Bummer.
Well, thanks for the responses!
Old Jan 9, 2015 | 08:54 PM
NotBlake's Avatar
Not talking about remote start here. Just the normal Smart-Key system.
Old Jan 10, 2015 | 10:21 AM
exl500's Avatar
Perhaps I misunderstand, but if you take the smart key with you and someone jumps in the car to drive away it will stop after 25 feet or so. I've seen it do that when the salesperson went to fill up my car without the smart key in the car. Yet the car was continuing to idle without the smart key in the car. This is true of the CVT at least.
Old Jan 10, 2015 | 01:33 PM
cwild's Avatar
Hmmmm...interesting. So just to clarify, in this instance you speak of the car did not continue driving but did in fact continue to run?
Old Jan 10, 2015 | 03:26 PM
andre181's Avatar
I haven't tried this but I would think it would work.
Start the car, get out, close the door. Take the physical key out of the smart key and lock the car by inserting the key and turn it. That should lock all the doors.
Again, I haven't tried it, but common sense tells me it should work. If it doesn't, that's dumb.
Old Jan 11, 2015 | 08:53 AM
esnave09's Avatar
This does work. That's what I do when I start my car at work.
hangout
Dec 7, 2017 12:21 PM
komark
Jul 7, 2016 08:41 PM
Jo Anna
Apr 15, 2016 01:25 PM
Press Fit
Dec 14, 2015 01:10 PM
MagicGuitar
Jan 7, 2015 07:07 PM
