Rear Dash Cam
Old May 28, 2018 | 12:04 PM
SR45's Avatar
Originally Posted by kenchan
so wat do u do if u cause the accident? delete the vid and remove it from the car before the cops show up?
Silly. No I don’t. I fess up and take responsibility of what I did to cause the accident.
Old Jun 6, 2018 | 05:21 PM
Fiiit's Avatar
I installed with Thinkware..? Korean brand 2 channel and they work great.
Old Mar 2, 2025 | 03:51 PM
KARIJIN's Avatar
Checking to see if this thread is still alive.
Looking for advice on how to route the cables from the front fuse box to the rear.
Old Mar 2, 2025 | 03:52 PM
KARIJIN's Avatar
Originally Posted by macbuddy
I mounted a rear dash cam to the back of my GD3. With the help of a "parts bin" full of miscellaneous SLR camera mounting hardware, I was able to cobble together a mount. That was the easy part of the project. Routing the power line and RCA cable was time consuming.
Hi,
Mind sharing how you routed your cables, from power source to the rear camera?
Also, what kind of camera mount you used?
Thanks!
KARIJIN's Avatar
Originally Posted by justanewbie
I was involved in a incident that i had to go to court to get my ticket cleared. I only had a front facing dash at the time of incident. Anyways, after the incident, i upgraded to a dual channel.
https://www.lukasdashcam.com/dashcam...kas-lk-7950-wd
this is the one i had. I bought mine on costco about 1 ~ 2 years ago. I tested it before install, its quite a nice device, it has wifi which you can switch on, which allows you to watch footage or download video immediately.
As for installation, i put the sticker on and stick them on the front and back window. For the rear, i place it on top of the very 1st heater line and in the center position where the wiper blade can wipe. (for good video on all seasons). I plug the dash cam in and start shoving the cables into the right side of the plastic, the cable then goes down the front door, goes onto a flat area under/below the glove box and to the front voltage plug.
I do recommend plastic bits you can buy to install. My espresso spoon made small indents on the plastic bit. You won't realize its there unless you inspect it in detail, but if your a perfectionist, you definitely don't want to do what i do.
Hi,
Thanks!
Old May 22, 2025 | 09:26 AM
woodenpickle's Avatar
Originally Posted by martinoren8
Bro, were you driving in Laguna Niguel?
Already asked, and answered.. back in 2018
https://www.fitfreak.net/forums/3rd-...ml#post1400213
simonx314
61
Oct 13, 2024 10:15 AM
2Rismo2
Sep 25, 2019 09:17 AM
hogwylde
Dec 16, 2014 07:04 AM
benmunger
May 17, 2011 07:52 PM
Jimmy101
Nov 9, 2006 12:23 PM
