TougeMonster_GK5's Build Thread
Old Nov 4, 2017 | 05:52 PM
  #101
touge- i have the same wheels on my wife's GK with snows right now.
Old Nov 30, 2017 | 08:29 PM
  #102
TougeMonster_GK5's Avatar
Tires for the new kicks are in! I would have opt for 225-45-15, but there arent as many options (cost effective wise) for my daily 60mile commute.. nothing available with 300AA + treadwesr for this size. The S Drives should do for the TE37rt's.
Old Nov 30, 2017 | 08:46 PM
  #103
205's are plenty wide for a GK.
Old Dec 1, 2017 | 07:37 PM
  #104
atvfit16's Avatar
Originally Posted by TougeMonster_GK5
And more goodies came in the mail.
I just ordered one of those grills, did you order the Mugen Logo front Badge?
Old Dec 2, 2017 | 05:43 PM
  #105
i didnt, i actually returned it becuz it didnt directly bolt on.
Old Dec 2, 2017 | 05:56 PM
  #106
Project Kics WTS 10mm Wheel Spacers installed.
Old Dec 2, 2017 | 06:30 PM
  #107
now you're talkin!
btw, push in the top of that front bumper.. looks like the clip came loose near the top.
Old Dec 2, 2017 | 06:46 PM
  #108
Originally Posted by kenchan
now you're talkin!
thanks man for pointing that out! I actually have been pushing it but keeps slipping... i wanna do the anti-sag fix soon but still getting around finding out the dimensions/size for the extra foam piece to make it work..
Old Dec 2, 2017 | 08:20 PM
  #109
2Rismo2's Avatar
Hey bro,
(71173-T5R-A10 https://www.hondapartsnow.com/genuin...3-t5r-a10.html #33) If I'm ever going back in there, then I'll probably order that part and do it OEM.
Old Dec 2, 2017 | 10:37 PM
  #110
Originally Posted by 2Rismo2
Hey bro,
so this is all i need to fix the sag really???
Old Dec 3, 2017 | 05:21 AM
  #111
2Rismo2's Avatar
​​​​​ Maybe. I just saw that I did not have this part when I removed my bumper to fix the sag, but another member(USDM) did when he did projector headlights. Not sure if it was something they added to later years since mine is a 2015.
https://www.fitfreak.net/forums/3rd-...rofit-gk5.html
I would advise to do it sooner than later. I think my clips must have flexed so even though it's not sagging it still pokes outward a bit.
Old Dec 31, 2017 | 11:18 PM
  #112
Put some work in this weekend. Drove to So.Cal to finally pick up the TE37RTs..
Old Dec 31, 2017 | 11:26 PM
  #113
So I had to remove my Project Kics 10mm Spacers because for some reason, the cavities next to the bolt pattern holes would not allow the original stud to fit in! Such a bummer! Therefore, will be selling those off now. Finally installed!! (minus the Project Kics Iconix lugs)
Forgive me for the poor quality photos, my intention was to finally share my desired wheel setup! Finally another set of TEs! I share better pics very soon!
Cheers!
Old Jan 1, 2018 | 09:30 AM
  #114
should do stud replacement type or just trim down the stock studs.
congrats on ur new wheels!!
Old Jan 1, 2018 | 12:12 PM
  #115
Thanks man! Yeah thinking of doing the stud replacement version now. Since i still have the H&R spacers, i think ill use them.
Old Jan 1, 2018 | 06:46 PM
  #116
sounds good.
unless youre planning to go back to stock id just leave those 10mm on an cut off the stock studs. its not like you cant use factory wheels and lugs on them if you cut the factory studs.. something to think about i guess since it'll be free.
is your front rubbing at all? that's a pretty aggressive setup you got there.
Old Jan 2, 2018 | 04:44 AM
  #117
hasdrubal's Avatar
I'm wondering about rub too, looks like you're lowered about the same as me, but I had to run camber bolts at max negative to get clearance. No spacers for me, either. Looks strange now with blizzaks on the stock steels, sunken so far in.
Old Jan 2, 2018 | 08:27 AM
  #118
hydesg's Avatar
Hows your haspor rear mount so far? Less vibration now?
Old Jan 2, 2018 | 02:56 PM
  #119
sounds good.
You have a point about just cutting off partially the OEM studs. I may consider that.
I am rubbing when I hit small dips on the road, its more evident when I have passengers in my car. I am more concerned for spirited drives thru curves and would like to roll my fenders soon for peace of mind.
Aggressive = Monster stance
Old Jan 2, 2018 | 02:57 PM
  #120
Can you share pics with your camber bolts installed? I'd like to get a better picture. I have SPC camber bolts and considering on throwing them on for a little bit more negative camber at the front.
