Olga: The SoCal GK5
Old Oct 30, 2017 | 11:28 PM
  #41
USDM's Avatar
Changed the engine oil, rotated the tires, and installed my Spoon Sports magnetic engine oil drain plug! This is my first time trying out the Motul 8100 Eco-lite 0W-20.
Olga seems to like it so far. Prior to Motul 8100 Eco-lite 0W-20, I used Mobil 1 0W-20 Advanced Fuel Economy.
I've also sent a sample of the oil from my last oil change to Blackstone Labs for analysis.
I'm curious to see how the engine is doing after 10,000 miles. I'll share their analysis once I receive the results.
Old Oct 31, 2017 | 01:23 PM
  #42
USDM's Avatar
Morimoto M-LED projectors installed by 818 Retrofits!
Check out the link below for more information:
https://www.fitfreak.net/forums/3rd-...rofit-gk5.html
Old Nov 7, 2017 | 12:41 PM
  #43
USDM's Avatar
The results are back from my engine oil analysis! Looking good so far!
Old Nov 7, 2017 | 01:23 PM
  #44
GAFIT's Avatar
Was that 0w20?
For some reason, the report shows you have ~5000 miles on the oil, but the comments say 8,100 and they seem to think this was from the factory fill.
Old Nov 11, 2017 | 12:55 AM
  #45
USDM's Avatar
Originally Posted by GAFIT
Was that 0w20?
I used Mobil 1 Advanced Fuel Economy 0W-20 for ~5,400 miles before changing my oil.
According to the analysis, I'm showing similar wear for oil that was used for ~8,100 miles.
I e-mailed Blackstone Laboratories for clarification and this was their response.
"Hi there, Kevin
Yes, that's correct. You had fairly average amounts of metal after a shorter-than-average interval. As for the metal from break-in, it'll almost always show up beyond the first (initial) oil change, and often into the third or fourth. There was likely a little residual metal in your sample, and there may even be some next time, not that that's a problem. I hope this helps, but let me know if you have any more questions."
I hope this helps!
Old Nov 11, 2017 | 03:15 PM
  #46
GAFIT's Avatar
Thanks for the clarification. Your oil was also fairly broken down from a viscosity stand point for that amount of miles. I saw similar when I had Blackstone test Motorcraft full synthetic.
I bet you'll see better results from the Motul.
Old Nov 11, 2017 | 06:13 PM
  #47
USDM's Avatar
You are very welcome. I greatly appreciate your input!
I'll be sending another oil sample when the time comes and we'll see how the Motul 8100 Eco-lite 0W-20 compares to Mobil 1 Advanced Fuel Economy 0W-20.
Old Nov 13, 2017 | 01:14 AM
  #48
USDM's Avatar
Took her out for a drive today. This thing is lots of fun!
Old Nov 13, 2017 | 11:32 AM
  #49
2Rismo2's Avatar
Projectors look awesome
Old Nov 14, 2017 | 04:17 AM
  #50
USDM's Avatar
Thank you!
Old Nov 24, 2017 | 12:29 AM
  #51
USDM's Avatar
Hasport rear motor mount installed! Installation was fairly easy and took around 30 minutes in total.
The difference between the two mounts is immediately noticeable. I opted for the U70A urethane and don't regret it whatsoever.
The cabin does experience an increase in NVH, but that's to be expected.
The increase in NVH is most noticeable while idling with the A/C on and during initial take off. Besides that, it's not very noticeable at all.
Engine response has significantly improved after installation of the Hasport rear motor mount.
Also, gear changes are much more direct now and there is no second-guessing occurring during gear changes.
Old Dec 14, 2017 | 08:26 AM
  #52
gordata's Avatar
Nice mods on the fit! Lots of expensive parts.
Old Dec 17, 2017 | 12:31 AM
  #53
USDM's Avatar
Thank you very much!
Old Dec 29, 2017 | 06:49 PM
  #54
Shutterspeed's Avatar
Did you ever install the Spoon rear view mirror?
Old Dec 30, 2017 | 03:35 AM
  #55
USDM's Avatar
Yep!
https://www.fitfreak.net/forums/3rd-...ml#post1383560
Old Jan 7, 2018 | 02:38 AM
  #56
USDM's Avatar
Here's a little teaser for you all.
Also, I switched from Morimoto M-LED projectors to Morimoto Mini D2S 4.0 projectors.
Once again, I highly recommend checking out 818 Retrofits' work. I am very happy with the finished product!
Old Jan 7, 2018 | 02:48 PM
  #57
[LegenD]'s Avatar
Haha sick dude!!! What's in the Spoon boxes?
Got a few things myself, just waiting for the Canadian arctic winter to pass before doing anything..sigh -_-;
Old Jan 7, 2018 | 05:45 PM
  #58
USDM's Avatar
Thank you!
The boxes contain:
Spoon Sports side mirrors (P/N: 76203-GK5-030)
Spoon Sports stainless steel clutch line (P/N: 46961-GE8-000)
Old Feb 7, 2018 | 04:31 AM
  #59
USDM's Avatar
More goodies!
Old Feb 15, 2018 | 01:55 PM
  #60
fit13mwm's Avatar
I am really impressed with your choice of mods thus far. you inspire me to start on My GK5. I'm excited to see what's next.
