Help with oil pan
Old Aug 7, 2015 | 01:21 AM
Kingslayer's Avatar
Help with oil pan
So...Long story short I hit something under my car and cracked the oil pan on my 2015 honda fit LX. Went to the dealership and was told I would be charged 1k for it. Said fuck that so I bought the part and switched them out with my partner. Now after getting everything hooked back up, I go to screw on the oil filter and I see this.
First image is the newly installed one. Second image is the old one. The new one is missing something, and I cant seem to find a way to get the old one out without stripping the threads. I don't see anything on the parts website that shows a part for that. There was nothing else in the package I got with the new oil pan. Anyone have any ideas?
Old Aug 7, 2015 | 04:01 AM
doctordoom's Avatar
Supervillain
90015-PH1-013 perhaps.
Old Aug 7, 2015 | 04:32 AM
Black3sr's Avatar
What if you had two nuts that fit and lock them on? May be able to remove that piece without damaging threads then?
Old Aug 7, 2015 | 04:40 AM
kylerwho's Avatar
spoon fed
I would use an internal pipe wrench to spin that adapter piece off.
Shop Superior Tool 1/2-in Pipe Adjustable Wrench at Lowes.com
if the old oil pan is off the car, take a propane torch and heat up the aluminum pan to help that insert be removed easily.
Old Aug 7, 2015 | 08:33 AM
Carbuff2's Avatar
I also recommend the double nut method.
Tho' if you saved enough money by avoiding the dealership, you would still come out ahead buying a new adapter (#8).
You MIGHT even be able to find an adapter at an autoparts store. (Bring an oil filter and old pan to assure everything fits, both thread size and thread DEPTH)
How long did it take you to swap the pan?
Old Aug 7, 2015 | 06:37 PM
Rob22315's Avatar
From bernardiparts.com, it's a $3.59 part (before shipping) - 90015-PH1-013
Just buy a new one and screw it in. It shows up on the diagram for 'Oil Pump - Oil Strainer' in the 'Engine' category.
Old Aug 7, 2015 | 11:19 PM
DrewE's Avatar
Another approach to removing the old one that might work would be to turn it with a cold chisel and a hammer from the inside of the old oil pan by striking it at a diagonal angle along the side. Two nuts jammed together would be preferable.
Heating it up with a torch before attempting removal might help, too. Obviously you don't want to go too far overboard and melt stuff or start a fire.
For a $3.59 part, it's probably not worth spending too much effort diddling around with the old one unless time is of the essence!
Old Sep 10, 2018 | 09:00 AM
JerrySFL's Avatar
No ,new oil pans do not come with the filter nipple. I would buy a new one from Honda along with the gasket o-rings for the dip stick tube , crank sensor and internal oil passage o-ring and use Honda Bond HT, works alot baetter than RTV. If you used RTV change your next filter2 early as any excess RTV will from silicone boggers that will clog your filter. The 2 nut method will work but Honda Bond or lock tite it in place so it does not come of when you pull the filter.
Old Jan 9, 2019 | 06:19 PM
gnuelniloc's Avatar
I had the same issue when I replaced my oil pan. I bought two nuts from Fastenal, and did the double nut as others suggested. I brought the damaged pan to them, and do not have the thread size on hand..
Old Aug 2, 2020 | 11:10 AM
thats_it's Avatar
I'm having a hard time screwing it in. Should I be able screw it in by hand? Threads look good on both the male and female side.
Old Aug 2, 2020 | 02:11 PM
JerrySFL's Avatar
Yes; you should be able to screw it in a couple of threads by hand, The thread on the oil pan in and the thread for the filter are different. Also don’t listen to anyone that tells you to heat up aluminum, with a touch, aluminum alloys will go from solid to liquid without warning and applying to much heAt will Change the alum and Turn it brittle. if you don’t have two nuts you can cut the bottom off of one filter and use another filter to turn it same thing. Or go to Home Depot in the plumbing section you’ll find an inside pipe wrench, when you turn it it’ll expand grab the inside of the nipple and you can tighten it.
Old Aug 2, 2020 | 02:25 PM
thats_it's Avatar
Thanks! It can't go in by hand. I'm going to try the double nut method.
Press Fit
Mar 18, 2024 02:05 PM
p nut
May 6, 2014 12:38 PM
isis07734
Dec 8, 2013 03:59 AM
ku8o
Mar 13, 2011 11:55 AM
mozarwasagenius
Mar 31, 2009 12:54 PM
