07 Can't Get it Started
Old Aug 9, 2018 | 08:36 PM
BLP's Avatar
BLP
Sorry this post is my first. I dont know where else to turn lol
Searched the forum heavily and havent been able to find a solution to my issue. Here's what im dealing with:
Have owned my 2007 Fit for about 30k with no issues. Currently @ 117k. Drove the car around with no issue yesterday. Even changed the oil. Parked it after work, came out this morning and it wouldnt start... Car turns over fine it just wont fire.
Checked the immobilizer. Operating as it should with no issue (from what I can tell)
After a brief troubleshooting session I came to the conclusion it was most likely a dead fuel pump.
- Couldn't smell fuel after repeatedly trying to start it
- Couldn't hear a fuel pump kick on
- Accessed the fuel pump and disconnected the lines. Turned the car on to see if i would spray fuel in a bottle and nothing.
- Fuse was good, relay clicked, etc...
Ultimately decided to buy a new fuel pump ($60). Installed it and still can't get the car to fire. What am I missing...
Thanks in advance
Old Aug 9, 2018 | 11:33 PM
xxryu139xx's Avatar
stupid question? did you try to jumpstart it?
Old Aug 10, 2018 | 02:29 AM
GolNat's Avatar
Is the CEL on?
Old Aug 10, 2018 | 09:22 AM
BLP's Avatar
BLP
No CEL and yes I tried to jump it.
Old Aug 10, 2018 | 10:37 AM
GAFIT's Avatar
Have you tried pulling a spark plug out, re-connect the coil and see if you get spark when turning the key? Will need two people.
Old Aug 10, 2018 | 12:19 PM
doctor J's Avatar
Is check engine light on with engine off key on?
Old Aug 10, 2018 | 03:18 PM
upallnight's Avatar
Thanks in advance
But did you check for power at the fuel pump connector? Did you check for Ground at the connector? Fuel pump won't run if there is no power or ground.
Old Aug 10, 2018 | 04:33 PM
Jared592's Avatar
Might be worth a shot, though I'm not sure how you could've tripped it:
Old Aug 10, 2018 | 04:42 PM
GolNat's Avatar
Unplug the crankshaft sensor and see if it starts. A bad one can cause a crank no start condition.
Old Aug 11, 2018 | 01:05 PM
BLP's Avatar
BLP
CEL is on with the key in the on position. Goes off when you try to start the car.
Borrowed my friends OBD Scanner and it did throw P0302 cylinder 2 misfire
Old Aug 11, 2018 | 01:13 PM
BLP's Avatar
BLP
No change with unplugged crank shaft sensor
Old Aug 11, 2018 | 01:47 PM
BLP's Avatar
BLP
Fuel pump is running
Old Aug 11, 2018 | 01:59 PM
upallnight's Avatar
I'm assuming now that the fuel pump is running you need to check for spark at the plugs and an injection pulse at the injectors.
Old Aug 11, 2018 | 07:13 PM
BLP's Avatar
BLP
Replaced the plugs and tested the coil packs. Tested three total. 2 didnt spark, 1 did. After that i figured im replacing all 4 anyways.
Does any one else find it weird (and highly unlikely) i would lose a fuel pump and a couple ignition coils at the same time?
Old Aug 11, 2018 | 07:47 PM
GolNat's Avatar
That is weird and highly unlikely. Loosing more than one coil pack is odd but also a fuel pump!!! Honda fuel pumps are very robust! I’m wondering if you have another issue and it’s not these isolated things.
Old Aug 11, 2018 | 07:57 PM
BLP's Avatar
BLP
Fully agree. Running out of options... car had no issues. Changed oil around noon (oil levels are fine). Drove it home from work at 5pm. Parked it at 6pm. Cranks but wont fire at 7am the next morning
Old Aug 11, 2018 | 08:13 PM
GolNat's Avatar
How did you test the immobilizer? I believe it will still allow the car to turn over but cuts fuel and spark.
It also can have a code and not show a CEL.
In the service manual low key fob voltage could be an issue.
Old Aug 11, 2018 | 08:24 PM
BLP's Avatar
BLP
i just watched the dash light. Solid then goes off. No blinking.
Only code was P0302 but ive never had a CEL so im not convinced its relevant to my current issues.
Car didnt have a service manual so I dont have one. Only have 1 key for it.
Old Apr 17, 2021 | 07:15 PM
nature boy's Avatar
did you find the problem? my mechanic said under dash fuse box bad and rewired something with a jumper.
Old Apr 18, 2021 | 05:20 PM
BLP's Avatar
BLP
It was a dead fuel pump. Issue was in the fuel pump assembly replacing the fuel pump alone didnt solve it
Phillip S. Chrin
Dec 14, 2019 02:50 PM
Vash
Nov 21, 2018 11:08 AM
BLP
Aug 12, 2018 03:43 PM
mikestvn
Dec 15, 2015 01:41 PM
timsfit
Nov 13, 2011 04:55 PM
