DIY: Independent Fog w/ Original Switch.
Old Dec 3, 2008 | 11:15 PM
  #101
Rubba Burna's Avatar
HID Addict
after fidding with the battery bolt, i finally disconnected it [the black one]. made sure the wires were securely touching. and put the battery back on. yay, now the engine lights and the air bag light is gone and im pretty sure the CC is working as well. i think its a HONDA saftey thing. but... no fog lights =[ wtf? someone tell me whats wrong...
Old Dec 4, 2008 | 02:15 AM
  #102
heymikesays's Avatar
did you check your fuses? if its not that its probably the slot you have them in, try a different one, or recheck your wiring/crimp/solder.
Old Dec 4, 2008 | 06:59 AM
  #103
HID Addict
check my fuses what do you mean by that? its just putting it in the right slot heh ill try a different slot, thats prolly the problem. i think i have it in slot 2 with no red-thing attached to it. i was going to rep some buh nooooo i gotta spread some around heh
Old Dec 4, 2008 | 01:53 PM
  #104
fit4afit's Avatar
bump, anyone wanna try doing this mod to the 09s? xD
Old Dec 4, 2008 | 07:27 PM
  #105
HID Addict
i tried the bottom 5 slots and one one the left side, nothing... no fog lights with or without headlights/highbeams/daylights... i also noticed... -gulp- my reverse lights dont come on... and i forgot to mention, the fog light icon in the display, does't come on either, but the daylights does and so does the highbeam when i use it. someone help me >.<
as for ind. fogs for 09s, i belive theres someone in the process in doing it, but i heard that a while ago...
Old Dec 4, 2008 | 08:19 PM
  #106
check your fuses, there's instructions in the owner's manual on how to do this.
Old Dec 4, 2008 | 08:21 PM
  #107
jono21's Avatar
oh shit... this is why i wanted to wait till a meet, got dammit. i was doing the mod to the end. and when i tried it... the fog lights didnt work and the Engine light was on and the airbag light was on [in the display] while passanger airbag was ok [meaning that light was off] and this is the worst part.... no cruise conotrol!!! me and my mom need it and we use it everyday >.< did anyone have this problem?!!? any idea what could be wrong? solutions!?!?! please help anyone!!! >.< i need to fix it tonight! onthe add-a-circuit, i see one 10 amp fuse, is that right? or is there two? if so where do i get the second red thing?!?
hey i think your problem is you need two 10 amp fuses in your add-a-circuit fuse. I remember doing this and when I first tried it out I only had one fuse and it didn't work. Hope that helps.
Old Dec 4, 2008 | 08:59 PM
  #108
HID Addict
yea i used one fuse [assuming the fuse is the red thing with "10" on it, getting the manual few minutes], if thats the case, where do i get the second fuse? and what slot did you use? you remember? be my life saver!!!
Old Dec 4, 2008 | 09:19 PM
  #109
Fitcapo's Avatar
... you have to buy another one. Two fuses should plug into the add a circuit they are both required for the add a circuit to work. You should put the add a circuit I believe into the 3 or 5 slot don't remember but check the first page and it says.
Old Dec 4, 2008 | 09:22 PM
  #110
HID Addict
yea slot 3... never said anything about a 2nd fuse -.- god dammit -.- any ideas where? or any fuse i can take out and use temporarily?
Old Dec 4, 2008 | 09:29 PM
  #111
Fitcapo's Avatar
Naa I wouldn't take out any other fuses. You can get 10 amp fuses just about any where a hardware store a car store. I got mine from a local autozone.
You want ATM 10amp fuses. Make sure they are ATM because that is the size/type. I think some brands might say mini too don't remember.
Old Dec 4, 2008 | 09:34 PM
  #112
HID Addict
then ill go tomorow after school. god damn now i cant wait lol autozone its going to be, hope fully the friggin guy wont ask me questions and say "thats illegal, im going to have to reject the sale", HA! nice try... im going to plead the 5th admendment
Old Dec 5, 2008 | 02:30 AM
  #113
jono21's Avatar
hey fitcapo is right. you just need to pick up another 10amp mini fuse. I've got mine currently plugged into slot 3.
On a side note, in the DIY it said that if you wanted to run the foglights like they do in europe where the fogs come on with the parking lights it says to plug into slot 22. When I do that the fogs are on right away once the ignition is started. What I would like to be able to do is leave my foglight switch to on but only have the fogs on when I switch to my parking lights or headlights. Does anyone know if this is possible?
Thanks
Old Dec 5, 2008 | 06:14 AM
  #114
HID Addict
heck i want it on ALL the time, without headlights/highbeams and with heambeams and headlights. cant wait till after skool
Old Dec 5, 2008 | 07:12 AM
  #115
Fitcapo's Avatar
If you do it the way they said in the diy you will be able to leave the switch turned on all the time and then they will turn on with the car and turn off with the car.
Old Dec 7, 2008 | 03:32 PM
  #116
HID Addict
HIGH BEAMS + fog lights
so i got independant fogs to work, meaning without any light, with DRL, and with headlights. but i still want to have the fog lights on with high beams, i tried webskies [or some name like that] mini-DIY and turns out its the headlights with highbeams, not fog lights. id use it but it doesnt let me use the fog lights AT ALL, so i put it back, to regular ind. fogs. does anyone know, AT ALL, how to make the fog lights active with highbeams as well as active with headlights and DRL. any if by anychance, what about ALL lights? foglights,headlights,highbeams, and DRL all on anyone know how to do that? that i would REALLY love, ill do.... anything... -gulps- ...
Old Dec 7, 2008 | 05:09 PM
  #117
pwnstar's Avatar
lol if you messed up on the independent fog lights the normal way lol i would not suggest trying to do the part to get them to come on with the high beams you will have eveything all messed up LOL no pun intended just saying might wanna have somone that really knows what thay are doing do it for you :P
Old Dec 7, 2008 | 07:10 PM
  #118
HID Addict
>_> you have no idea how bad i want high beams with fogs -.- maybe i was fantasizing when i said headlights + highbeams + DRL + fogs but i would like the fog to be on with the high beams. i saw a video of the fit with highbeams/fogs, http://planetkris.com/fit/Independen...da_fit2008.mpg , im not sure who it is but he did it. oy
Old Dec 7, 2008 | 08:47 PM
  #119
HID Addict
wow -.- i figured it out -.- i messed up, i grounded the wire from the car/batch-of-wires instead of the one from the little box thing [relay?] hehe stupidity on my part, but damn im going to ride 'er out soon now i got 8500k LED + 7000k Fog and full lights ^.^ thanks so much guys!
Old Dec 7, 2008 | 10:20 PM
  #120
Fitcapo's Avatar
... so if you have 8500k lights and you are running those as high beams why the hell would you need fog lights?
