DIY: Independent Fog w/ Original Switch.
Old Dec 7, 2008 | 10:28 PM
  #121
FitVic's Avatar
having only highbeams and no foglights have like a dark gap between the bottom of the highbeam line and your car. With the foglights w/ highbeams it pretty much clears that up. I did both mods on my car and wouldn't have it any other way I got 5000k hi/lo and 5000k foglights w/ yellow film so it turns green when turning on but then becomes yellow. Looks awesome though maybe i'll record it for you guys and post it. When I find the time I will.
EDIT: +1 for you Rubba for making em work
Old Dec 7, 2008 | 10:35 PM
  #122
Rubba Burna's Avatar
HID Addict
Originally Posted by Fitcapo
... so if you have 8500k lights and you are running those as high beams why the hell would you need fog lights?
hehe LEDs my friend ;] there 8500k LEDs, there just for show, they dont actually emit light THAT far, like you can see it on a wall/road, but it wont actually illuminate it lol not even close, reflectors at most.
im actually thinkin of doing a video of the lights, 3 2-way passes: ind fogs with LED, fog n headlights + led, then fogs n high beams +led. ill be able to hear what stock exaust sounds like too hehe
thanks for the rep :P lol rep back ;]
Old Dec 20, 2008 | 08:49 PM
  #123
SFactor2's Avatar
From: Negative Repland (exiled by fragile ego's and "can't handle the truth" babies) LMFAO ;P
instead of cutting the wire under the steering column then running it back to the fuse box, I think we could cut the wire closer to the fuse box then attach it to whatever 12v source we want thus negating the need to run an "extra" wire
does anybody know where the other end of the red/yellow wire leads to?
for a cleaner install we could connect the red/yellow wire to the underside of the fuse box and just plug in a fuse to supply 12v
Old Feb 19, 2009 | 04:02 PM
  #124
zeemon's Avatar
Hey,
Just finished this mod and it worked perfectly. The only thing I think may be different for me is the fact that my headlights still have the daytime running feature enabled. I thought this mod would change it so my daytime lights are disabled. I live in Canada and I purchased my fit from a local dealer so Im not sure if its the laws we have in place and hence a different wiring scheme for the lights. My question is for anyone who knows how to disable the daytime running feature on 07 sport fits. For those who dont know what that means - when my headlight switch is set to "off" I always have dim lights from the headlamps.
Any fixes to disable this feature would be greatly appreciated - PM me or reply here
THanks!!
Z
Old Feb 19, 2009 | 10:07 PM
  #125
fitster's Avatar
if u look at your fuse box under the dash theres a fuse marked DRL pull it and u have the fix
i use my fogs as my daytime runners and ive had no problems, im in BC so yeah same law
Old Feb 19, 2009 | 10:35 PM
  #126
zeemon's Avatar
Hey thanks fitster,
Im finally about to install my 6000k's from xenith so I will pull the DRL fuse when i get to it!
**EDIT
Ok so its not as easy as I thought it would be...I see the fuse box, I see that some are marked. I just cant seem to see which is the DRL fuse?
anyone have a diagram of which one to pull? or which one the DRL is relative the slot 3 where the add a circuit was plugged into?
Thanks
Old Feb 20, 2009 | 08:08 AM
  #127
zeemon's Avatar
Did some googling last night.
You have to pull the brown 7.5 A fuse in slot #8 !
indi fogs !
Old Feb 22, 2009 | 07:41 PM
  #128
bootymac's Avatar
Did this mod last week and it was a breeze. Rewiring the fog relay was a bit of a squeeze though, but nothing impossible.
Only thing I did differently was instead of tapping off of fuse slot #3, I used slot #2, which was empty. You just need to plug the add-a-circuit into slot #2, then a 10A fuse into the add-a-circuit. No need to cram things around!
Old Apr 20, 2009 | 09:57 PM
  #129
bishop5372's Avatar
complete
i just did this mod last night and it works great now what bulbs do i use to get the parking lights soo blue everythnig i have seen are not bright at all.
Old May 10, 2009 | 01:51 PM
  #130
flyellow's Avatar
all right, I did this DIY and my fogs work great now....only prob is now my check eng light came on.....any ideas on how to remedy this....?
Old May 10, 2009 | 04:17 PM
  #131
E = Mc2's Avatar
Sounds like you might have given it some juice where none was needed. I did the same trying to get my Base fogs to run independently (which did NOT work as the wiring is different). Try disconnecting the battery for 5 minutes and see what happens. I had the check engine and TPMS lights on at one point.
Old May 10, 2009 | 05:27 PM
  #132
flyellow's Avatar
I will give it a shot....thanks
Old May 12, 2009 | 08:11 PM
  #133
gnarlyj3rick's Avatar
Yeah disconnect your battery and reconnect it again. You'll have to reset your stereo clock but it should turn right off.
I did this mod myself today, same thing happened and i freaked hah. But i had a buddy who knows his stuff and helped disconnect the battery and reconnect it.
Great write up
Old May 13, 2009 | 09:49 AM
  #134
HID Addict
yep, any electrical or sensors that come up, check if it its true or not. Like if theres a TPMS light on, check your tires, if all is fine, then disconnect the battery, wait, and reconnect, this is for any times.
Old Jun 3, 2009 | 02:31 PM
  #135
jt.wilson89's Avatar
thank you for the instructions! it worked for me
but...
for some reason after i did this... my malfunction inducator lamp turned on ... any answers?
Old Jun 4, 2009 | 09:49 PM
  #136
HID Addict
happens to almost everyone, pop the hood, take out the ground wire (you have to loosen the bolt, its safe) wait about 5 mins, then put it back together and it should be good. this resets the sensors and such, but also the radio, so make sure u have teh radio code when doing this, and congrats
Old Jul 1, 2009 | 05:14 PM
  #137
leeman's Avatar
hey guys sorry to ask such a noob question but when do you use just the fog lights? seems like the only time you'd use fog lights would be in conjunction with the regular headlights. I'm asking because I'm considering doing this because it seems cool, but seeing as to how I've never done anything like this before I don't want to run the risk of damaging my car
Old Jul 1, 2009 | 05:18 PM
  #138
HID Addict
-shrugs- its just for looks. the only time when it could be useful for the road is when its almost night time, and the headlights can be somewhat too strong for the oncoming driver (it is on mine) so foglights can be useful to let your position be known to oncoming cars and still not blind them. Also for good looks
Old Jan 14, 2010 | 08:09 PM
  #139
whitedelight4's Avatar
Question this looks like its the GD model fit you were working on. If so does this same Diy work with the Ge models?
Old Jan 21, 2010 | 01:18 PM
  #140
HID Addict
a week late but, no i dont eblieve so, i remember ge8 owners complaining they coudnt do the mod. but its been a while, i think there is a ge8 DIY, search tool my man
