JDM Wiper Mod.
Old Aug 13, 2010 | 07:58 PM
  #61
555sexydrive's Avatar
Out of curiosity, how and why is this called a JDM mod? I ask only because the JDM model also comes from the factory with a flaccid wiper.
And to the poster above, maybe move to where the driver sits on the right as the erect wiper resides behind me. hahaha
Old Aug 13, 2010 | 08:03 PM
  #62
blassty's Avatar
so in essence you're saying..."one of us! one of us! one of us!"
Old Aug 13, 2010 | 08:16 PM
  #63
Krimson_Cardnal's Avatar
Old Aug 14, 2010 | 04:27 AM
  #64
Black3sr's Avatar
I rather like being on the left. When I check the mirror I can see if my wiper is flaccid or has a stiffy.
Old Aug 14, 2010 | 08:46 AM
  #65
polaski's Avatar
Think this will help with snow/ice accumulation on the blade in the winter? I cringe every time I have buildup and hit the blade, and it moves sooo slow because it's lifting a ton of snow.
I do stuff for function before form
Old Aug 15, 2010 | 03:54 PM
  #66
wdb's Avatar
wdb
Uhhh, yeah. After performing the mod, the wiper parks in a nearly vertical position -- no place for gunk to build up. Works the same way in the summer too; no tree gunk or road gunk piles up to be smeared across your window.
Keeping gunk off the wiper was the only reason I did it.
Old Aug 15, 2010 | 04:09 PM
  #67
gunk off the wiper - here's to that! good mod
Old Aug 15, 2010 | 07:15 PM
  #68
v95's Avatar
v95
Thanks for the details on this mod.
Got the car yesterday and I'm already changing stuff...just can't help myself:
On the 2010 that I have, it seems that Honda got the idea that people had to break off something to do this. Now...it comes with 6 different holes. Mine was already set on a "blue grease" position......just changed it to the opposing hole. Worked great!
While at it, I went ahead and debadged it:
Old Aug 15, 2010 | 09:57 PM
  #69
polaski's Avatar
Wow that does keep the dirt on the blade to a minimum, now that I've seen it after a few miles on clay road. I bet the blade will last longer this way.
A tip to those attempting this, removing the two plugs on the bottom of the tailgate is easier than I knew. Push the center in, then once you remove it carefully pop the center pin back out. Took me a while to figure out (and I've only taken apart what, 6 hondas? )
Old Aug 16, 2010 | 12:15 PM
  #70
britdevine's Avatar
Ok, so I did this today, but my wiper seems to be stuck. After I switched the hole on the wheel to the opposite one, I can't remove the metal piece that attaches to the wheel and my wiper motor seems very hot.
Any ideas?
Old Aug 16, 2010 | 12:26 PM
  #71
Pull the power connector off the motor. Or the fuse.
Old Aug 16, 2010 | 12:36 PM
  #72
britdevine's Avatar
Got it out, rechecked everything and gave it another go.
I only get a 1/2 wipe then my wiper stops and my wheel looks like this.
The left bar was pushed all the way to the right and it stops in the middle instead of giving me a full wipe.
Old Aug 16, 2010 | 12:46 PM
  #73
britdevine's Avatar
Nevermind, problem was when I first took it apart the wheel flew off so I didnt know which way was the right way for stock, now I have it all set up right and have my stiffy.
Thanks for the DIY
Old Aug 16, 2010 | 12:57 PM
  #74
Tricky little devil, isn't it. I got to know mine too well.
I had all the pieces in my hands first time.LOL
Old Aug 16, 2010 | 03:08 PM
  #75
Black3sr's Avatar
He seems to have a grasp on the situation now.
Old Aug 25, 2010 | 02:45 AM
  #76
oOopinkmanoOo's Avatar
My friend told me about this and I just did this yesterday it was weird at first but it grew on me hahah nice little mod
Old Oct 22, 2010 | 12:13 PM
  #77
crash001's Avatar
Did this but now it won't wipe any ideas
Old Oct 22, 2010 | 12:27 PM
  #78
Electrical connection at the motor if it doesn't move would be a first guess.
Old Oct 22, 2010 | 04:15 PM
  #79
Black3sr's Avatar
You broke it?
Nah. Just try again. Maybe a wire came loose or you just do not have it together the right way.
Old Nov 13, 2010 | 07:51 AM
  #80
ching1206's Avatar
humm......
i got a problem..
i followed the instrustions...
i have a GD3..
i relocate that thinging to the bottom...
then spin the big clock thingy to the bottom so i can put that flat metal plate back to locate them...
then i put everything back on...
install the wiper up right....position..
turn it on...
then it just goes back to normal....
soo
wht i did wrong??
