KRAFTWERKS SUPERCHARGER aka (Jackson Racing)
Old Jan 23, 2008 | 09:27 PM
  #721
07_g_fit's Avatar
Originally Posted by tricolor
A 30 percent gain in torque that translate into A 50 percent increase in power: Does that mean the engine top RPM increased over it's 6500 stock? How does it make sense
30% ft/lb increase & 50% hp increase, at peak increase. To the best of my knowlegde 6500 limiter is the same.
Assuming that the blower adds 50% more air across the whole rev range (it doesn't). Keep in mind peak torque is made lower in the rpm range and drops after a certain point. For ex. lets say peak torque is at 4000 rpm, here the blower will give you 50% more of half the max air, (4000rpm is 60% of all available rpm) hence a 50*.6 = 30.
Since hp always climbs except for near the limiter, it will have 50% more of full air (6500rpm is 100% of all rpm) hence a higher gain. 50*.1 = 50
It's hard to explain and I think I may be just confusing people & my-self. But that's the best I can do at the moment, for reference: HP = torque * RPM / 5252
Old Jan 23, 2008 | 09:43 PM
  #722
tricolor's Avatar
Yes, I forgot that the torque slope is not linear as the RPM increases. Can I assume that the blower isn't likely to provide full pressure (5psi) as the demand nears its peak
But anyhow, I am happy with the promised torque gains at low RPMs.
Old Jan 23, 2008 | 10:09 PM
  #723
mrmandmman's Avatar
Coming from a turbo charged car I can say that it was always difficult to maintain full boost pressure at high rpms with a smaller turbo, because it could not flow enough air. I am not sure the size of the rotrex so you'd have to see on a gauge or learn from one of the testers
Last edited by OJRKraftWerks; Jan 24, 2008 at 02:59 PM. Reason: Remove old, confusing information :)
Old Jan 23, 2008 | 11:59 PM
  #724
Lyshk0's Avatar
Originally Posted by mrmandmman
I haven't been able to find a Siphon to be able to read the article so perhaps you could shed a little light on it for me. Fuel economy is very important to me (environmental and foreign dependence not as much economical) so I was wondering what the results were, you mentioned a slight increase seen by someone but I wonder if this would be typical given similar driving habits. (would depend on the ecu tune I guess)
Also, given that I am in a high altitude (CO), and not knowing specifically how the Honda ecu and the map with the SC work, would running at a higher altitude make the car run slightly richer in comparison with the same car at sea level. I am wondering because a MAF sensor just measures the speed of the air if I recall correctly and I am not sure how or if the ecu corrects for density with the fuel mixture or something.
I am not sure if it is planned or not, but comparisons showing pre and post SC fuel mileage in similar driving conditions (temp, route, etc..) might go a long way convincing others like me it would be a fun purchase (that this won't hurt our wallet/environment etc. daily).
i believe the maf mesures the speed, and temp of the air charge at the same time. with both of those (and given to constant size of piping where the maf is, and density of air at a given temp) it can calculate the actual mass of the air entering the intake manifold. maf's are calibrated to the diameter of pipe where they are installed, and have extremely delicate elements. if you think there may be a problem with contamination or something like that, you can clean the element with non-chlorinated brake cleaner. im not sure about the one on the fit, but on my other cars the maf sensor element looked like a thin metal thread in a plastic tube with one side exposed (goes about 3/4's of the way down the tube). kinda like this (i). if you're looking down the open tube.
Old Jan 24, 2008 | 12:16 AM
  #725
claymore's Avatar
Hello the FIT doesn't use a MAF sensor it uses a MAP sensor.
Old Jan 24, 2008 | 02:27 AM
  #726
mrmandmman's Avatar
Well dang, guess I am a few years behind... I haven't had to work on anything yet!
Old Jan 24, 2008 | 07:28 AM
  #727
Lyshk0's Avatar
LOL!! i guess i need to learn more about the fit hahaha never had to do anything, and i run stock class so no intake for me yet lol
Old Jan 24, 2008 | 11:02 AM
  #728
eldaino's Avatar
the torque on the dyno sheet seems pretty linear to me.
Old Jan 24, 2008 | 11:31 AM
  #729
REXXXXXXXXX's Avatar
Frequent FitFreak Poster
Hey Chris!
The days are dragging by and im itching to get my supercharger. In the meantime, just to humor us, why don't you share a story or two of your feats. There's gotta be at least one good story of how you burned an unsuspecting racer at a light or embarrassed some tough guy who once thought he had a fast car. Im not concerned with numbers at the moment, I wanna hear what this baby can do!
Old Jan 24, 2008 | 12:04 PM
  #730
manxman's Avatar
Same here! Good post REXXXXXXXXX.
Old Jan 24, 2008 | 12:37 PM
  #731
eldaino's Avatar
+1
i'd love to hear some more stories. numbers are numbers, but real world butt dyno's are even better.
Old Jan 24, 2008 | 12:53 PM
  #732
kennef's Avatar
oscar,
could you post a link or two regarding the supercard engine management software? will something like a tactrix cable or other suitable obd2 interface be able to reflash the supercard, or will you make the necessary interface available for sale at some point?
and for everyone else, here's a link for perusing -
http://www.w2wpowertrain.com/images_...infoC15-16.pdf
Old Jan 24, 2008 | 01:37 PM
  #733
SickFit's Avatar
I find it akward that after reading the charts and info that were on the pdfs that MRM posted up earlier show that the 10psi kit had 150whp. But what i'm trying to think about was that wasnt this the older kit? Because if i read right, the newer kits on 5psi should be making 130 to 145 whp? Please correct me if i'm wrong. Thanks guys.
Old Jan 24, 2008 | 02:07 PM
  #734
ToyotaLover's Avatar
it's 155whp on a 5spd with 5lbs of boost and full modded exhaust system including going catless.
more accurate info is on the siphon mag.
Old Jan 24, 2008 | 02:40 PM
  #735
OJRKraftWerks's Avatar
Former Vendor
Those PDFs are old and show the old inefficient setup. I will remove them to avoid any further confusion.
-Oscar Jackson Jr.
Old Jan 24, 2008 | 02:44 PM
  #736
SickFit's Avatar
Awesome thanks.
Old Jan 24, 2008 | 02:45 PM
  #737
Former Vendor
Originally Posted by kennef
oscar,
The SuperCard is a sealed unit, and is not able to be reflashed.
-Oscar Jackson Jr.
Old Jan 24, 2008 | 02:58 PM
  #738
Former Vendor
I'm confused... peak what?
The supercharger is connected by the crankshaft, and thus turns faster at higher RPMs. The figure 5 PSI means that the greatest amount of boost you will see from this supercharger system is 5 PSI. You will see about 5 PSI at high RPMs.
Boost pressure is also determined by conditions and modifications.
-Oscar Jackson Jr.
Old Jan 24, 2008 | 03:07 PM
  #739
Former Vendor
There are multiple reasons the small turbo begins to lose pressure after peak torque...
The Rotrex does not have this issue. It continues to spin and be efficient throughout the rev range.
-Oscar Jackson Jr.
Old Jan 24, 2008 | 03:55 PM
  #740
You're killin me Oscar lol! It gets better and better ever day! Im getting to be like a 9-year old on crack on Christmas EVE!
