after boosting, whatelse?
Old Apr 23, 2008 | 10:50 AM
03DSM-RSX's Avatar
Frequent FitFreak Poster
one thing though, i am going to be running more than 6psi
thats perfectly fine. still no need to change oil viscosities
Old Apr 23, 2008 | 10:53 AM
kelsodeez's Avatar
UNBANABLE
well, you do sound like you know your stuff, but you are literally the first person to tell me not to run a thicker oil for my application.
Old Apr 23, 2008 | 11:01 AM
03DSM-RSX's Avatar
thanks, but a lot of it was from trial and error and seeing other ppl's mistakes and learning from them, and making some mistakes myself.
i honestly used to think like that about oils as well. Cuz it would make some sense. Thicker oil, sticks on the parts better instead of dripping off. But after much research and discussions with Honda heads, even domestic techs, they've all said the same thing.
I was also bought into the hype and gimmicks of Royal Purple, stockpiled over 50 cases of RP in the garage. Went thru about 3 cases before i started questioning its integrity and quality cuz it gave off an odd burnt smell after 3k miles on multiple cars that i used it in. Researched it online, and low and behold, i found the dirty facts and kept trying to tell myself that "its not true". So oil analysis, and baam, facepalm. Liquidated the RP supply to a bunch of locals, and used Amsoil or M1 ever since.
Old Apr 23, 2008 | 11:42 AM
eldaino's Avatar
one thing you dont know though, i am going to be running more than 6psi
my dyno tuner friend said that 5w40 would be the best for my application. he sees all types of turbos come in and out and i trust that he knows his stuff.
kelsodeez, what F.I. application are you going to use? Reason i ask is cause most of the kits out for our fits right now, don't really REQUIRE ANY of the things people have been mentioning, for example, even the 10psi kraftwerks kit that is coming out is suppossed to be plug and play and to only have minimal wear on the stock components. (again, this is why i'm asking you about what set up you are going with, as the rotrex kits in general are a bit of an exception to the wear and tear issues, simply because of the way they are designed)
Just wondering man!
Old Apr 23, 2008 | 12:40 PM
kelsodeez's Avatar
UNBANABLE
Just wondering man!
im going to be running the t1r kit.also I have a different engine on the way I will be building for boost
RSXPARTSMANN
Mar 28, 2015 12:50 PM
M@lew
14
Jul 16, 2014 11:27 PM
phil_qc
Dec 22, 2007 10:55 AM
blackgd3
Aug 28, 2007 04:25 PM
sLiVeRwOrM
15
Aug 8, 2007 10:44 PM
