T1R Clutch=Big Time FAIL
Old Sep 7, 2008 | 10:55 PM
  #101
kancerr's Avatar
im not very smart when it comes to cars. but i did have my clutch replaced on my fit also. it would slip, in every gear, wether or not i shifted and acceled or just kept it in gear and punched it...it would just rev out. now that i have replaced the clutch with another oem replacement, i have noticed that sometimes when i shift and punch it there is a "delay" in acceleration, the rpms will not rise, but there is a noticable delay in acceleration, you can even hear the intake sucking, but nothing happening for a moment... this could be because of my lightened flywheel? or it could be the clutch delay. i would assume it is the clutch delay since it happens on straight aways or even down hill when i shift and am driving "spirited".
i would look into this "clutch delay" thing...?
Old Sep 8, 2008 | 11:31 AM
  #102
wdb's Avatar
wdb
The clutch delay will make itself known via clutch slip. Revs will rise but car will not accelerate, just like when your old clutch was bad. The difference is that the clutch delay will only cause momentary slip, and only during clutch engagement.
Old Sep 8, 2008 | 04:11 PM
  #103
kancerr's Avatar
thats not what i got from the link they posted.... CDV Clutch Delay Valve
The Clutch Delay Valve (CDV) is a one-way restrictor installed by the factory between the clutch slave cylinder and clutch master cylinder, as shown in Figure 1. It "delays" the engagement of the clutch, much like old record players used a damped tone-arm to gently lower the needle onto the surface of a record.
Because of this valve, no matter how quickly you lift your foot off the clutch pedal, the clutch engages the flywheel at a constant (slow) rate. In theory, it can save the driveline from shock, were an inexperienced (or immature) driver to dump the clutch at high RPM. But in practice, all it does is prematurely wear out the clutch and turn experienced drivers into people who, despite 20 years of practice, cannot shift gears smoothly. During parallel parking maneuvers, the delay can be infuriating, causing constant clutch slippage. And during hard acceleration, the large amount of clutch slippage can greatly shorten the life of your clutch. During normal, sedate driving, the shift from first into second gear is often jerky, leading passengers to question your skill. As the driver, you can see your passengers' heads bobbing back and forth during every shift!
- my revs do not get any higher during this period. there is just a 'delay'
Old Sep 8, 2008 | 10:52 PM
  #104
jits14's Avatar
I have had the so called "clutch delay" many times so far and it isn't the jerky movement you are mentioning above. It is a noticeable second or so when the engine revs up like the gear never engaged, then without any jerk it engages as the rpms drop slightly back engaged into gear.
Old Sep 9, 2008 | 10:56 AM
  #105
wdb's Avatar
wdb
Exactly. That's how you know it's not the CDV.
Old Sep 9, 2008 | 04:00 PM
  #106
kancerr's Avatar
hmmm guess i should get it checked out then...wonder why there is this delay...thx get it checked out next weekend when my cars in the shop.
AKAgeorge
17
Jan 4, 2017 12:01 AM
Cachupin
Jan 5, 2011 10:24 PM
synmyo
Aug 29, 2010 08:06 AM
Firebat666
Apr 24, 2008 09:38 AM
ride_the_pony69
Sep 10, 2007 02:36 AM
