Pros and Cons of K20 swap
Old Nov 27, 2008 | 04:16 AM
  #41
Shaggs2Dope's Avatar
Frequent FitFreak Poster
my lil bro's h22 hatchback got 40mpg if you weren't burying your foot in it all the time. a k-series should get better mileage than the L15 because you have more hp and torque available earlier so you can almost idle the car and it will move along.
NA k-swap would be off the hook, and the accord block with k-pro and RSX typeS intake manifold you would have a super tidy, lower cost kswap
Old Nov 27, 2008 | 04:23 AM
  #42
kelsodeez's Avatar
UNBANABLE
yea, if i did a k, id either go k24 with a k20 head or get my hands on a jdm k20a. probably go with the k20a because with all the torque from the low end of the k24, there would be MAJOR traction problems.
Old Nov 27, 2008 | 08:47 AM
  #43
trancedsailor's Avatar
k20a is total win. 220hp from the RSX Type R, you could literally justifiably call the Fit a "Fit Type R"
Old Nov 27, 2008 | 09:46 AM
  #44
1coolride's Avatar
yupp. i think the k24 is a little more faster. but both motors are about the same price. i would do a k20a with crv block. k swap is total sleeper.
Old Dec 2, 2008 | 01:37 PM
  #45
whtsjdm's Avatar
Why would you spend 5k on a k20a to rip it apart and use a shitty bottom end? If you're going to do a k24 bottom end, there is no sense is spending money on a k20a. Not to mention the 4.7 fd in the type r trans would made for retarded traction issues with the extra torque. K24xx block/K20a2 head/ Ips xx cams/Pistons/ rods/ rbc IM= 270-290whp 210-220 tq.
In my opinion though, the k20 is the best fit. Block height on the k24 would make even more issues for no real advantage in my opinion. The only way I would go k24 is IF I was going boost.
Old Dec 2, 2008 | 06:29 PM
  #46
FuLLy FiTTeD's Avatar
^^^^^^ Couldnt have said it better myself^^^^^^
Old Dec 2, 2008 | 07:11 PM
  #47
how much would it cost for a k24 turbo swap? I'm thinking I'll have 10g's saved up around this time next year and would kill to do this once all my other mods are out of the way like big brakes and suspension/body stuff.
Old Jan 9, 2009 | 10:23 PM
  #48
SFactor2's Avatar
From: Negative Repland (exiled by fragile ego's and "can't handle the truth" babies) LMFAO ;P
Originally Posted by chimmike
not only that, but again, with that much power, FWD is utterly useless.
IMO a 200whp Fit would be about pushing the limits of the usability of the power.
really?
r u a grandma?
seriously......."utterly useless" u should write for the national enquirer!!!!
but seriously........"utterly useless" r u 4 real?
maybe u should get into r/c sailboats
glad that's only your opinion...maybe the first couple of gears would be a handful but u should easily be able to floor it in 3rd, 4th and 5th
IMO a 500whp Fit would be about pushing the limits.....
usability is all about the USER i.e. THE DRIVER
Old Jan 9, 2009 | 10:39 PM
  #49
SFactor2's Avatar
i think a k20 swap adds about 200lbs to the front end
boo 4 handling (at the limit)!!!!!!
u have to upgrade the front suspension if u don't want your fit to handle like a buick
Old Jan 9, 2009 | 10:52 PM
  #50
dewthedew's Avatar
Im going K24 from a cr-v because you can get them for around $1k and then later putting a k20 head and boosting it.
Old Jan 9, 2009 | 10:53 PM
  #51
dewthedew's Avatar
If you already have coilovers(which I do) all you have to do is replace the springs.
Old Jan 10, 2009 | 12:10 AM
  #52
redrumm's Avatar
it adds about 100lbs.
id be the different one and do a k20a3 turbo haha
cheapest K you can buy
Old Sep 2, 2015 | 06:23 PM
  #53
Nicx1st's Avatar
Need some advice about the k-swap in a 2008-2010 honda fit
Hey everybody, I was wondering if i can get some advice from you about the Honda Fit K20 Swap… I’m in the process of doing the swap and want to know these answers:
1) Is the swap hard to do?
2) Is it the DC5 Type R K20a Engine with Transmission and with engine harness and Suspension, Brakes, Axles???
3) Which Radiator do i use? The one with the original Honda Fit or the one from the DC5 Type R??
I need some advice on how the swap is going to go.
Old Sep 12, 2015 | 12:04 PM
  #54
space egg's Avatar
bump
I would do anything to keep this discussion going.
kindly, answer this guy's questions! ^^^
Old Sep 12, 2015 | 01:18 PM
  #55
Myxalplyx's Avatar
Originally Posted by Mr B
But with a heavier engine and a supercharger on top of that... you're pretty much only good for drag racing?
I'd have to agree with these guys actually. Unless somehow the Fit is converted to AWD (Like the custom awd converted Civics), it'd be very difficult to harness the extra power. Wider tires and extra weight up front may not be enough for grip.
This is NOT to say that I wouldn't want to own such a beast though. This thread is about the pros/cons of a K20 swap though. So carry-on!
Old May 30, 2020 | 09:38 PM
  #56
squilliam's Avatar
I haven't even done it but i can give you some obvious ones:
Pros:
1) Power. Lots and lots of power.
2) Reliability. Great motor!
Cons:
1) COST!!!!!!!
2) Weight distribution gets thrown even more out of whack
3) Tire-spinning fury-traction will be an issue.
Hello from 2020!
How could you counter uneven weight distribution?
Wider tires? Better suspension? Stiffer sway bar? Bags of sand in the rear?
Old Jun 10, 2020 | 10:53 AM
  #57
Eliseo Cortes's Avatar
170whp vs. 70whp lol That's like 150% power increase. I'm pretty sure I'll sacrifice 10mpg for that in a Honda Fit.
Spoiler
Old Oct 15, 2021 | 10:43 AM
  #58
Wht_GK5_Tx's Avatar
Yes yes yes.
really?
r u a grandma?
Yes Yes . . . Yes
i couldn’t imagine the look, the ego bludgeoning feel of a V8 driver when a FIT embarrasses them on the highway. That alone makes the swap worth doing. I mean, with lite suspension mods alone I’m doing 100 where others start backing off.
gdnatty
Sep 2, 2015 06:24 PM
07TaffetaFit
59
May 4, 2010 12:09 AM
porkchop
Feb 19, 2009 04:14 PM
Bukwheat
Sep 25, 2008 07:02 PM
j5ive
May 21, 2007 07:12 PM
