Check this IM out
Old Jan 20, 2009 | 07:52 AM
im the fit's Avatar
you know our stock manifold has a baffle in it so each of the cylinder will breath the same amount of air, im thinking that with the weapon-r cylinder 1 might get less air than cylinder 4 and cause to lean out
Old Jan 20, 2009 | 08:02 AM
im the fit's Avatar
Size:  15.1 KBheres someone elses but mine was worse, dont mind the red ring its not my pic
Old Jan 20, 2009 | 08:50 AM
SHG_Mike's Avatar
if this were the case the all the other performance intake mani's would do the same, which they dont. The problem with the weapon r is they probably did no research into the correct runner length or plenum volume to make any kind of power.
Old Jan 20, 2009 | 09:06 AM
im the fit's Avatar
its good i didnt buy it , nobody had it in stock so i bought rims instead
Old Jan 20, 2009 | 11:05 PM
kylerwho's Avatar
spoon fed
other than weapon r i dont think anyone else makes an intake manifold. correct me if im wrong though.
the jdm fit/jazz has a black cast manifold that has a differant shape than ours.
Old Jan 21, 2009 | 07:58 AM
SHG_Mike's Avatar
its plastic
im the fit
91
Dec 12, 2011 03:43 PM
Eamper
Mar 3, 2011 12:13 AM
im the fit
17
Jan 28, 2010 10:44 AM
FELIXY69
21
Dec 11, 2009 11:53 PM
08_Nick_Fit
15
Jul 28, 2009 05:35 AM
