Kustomz Unlimited Intake Manifold
Old Feb 24, 2010 | 12:55 AM
  #61
dewthedew's Avatar
too damn clean.
Old Feb 24, 2010 | 11:23 AM
  #62
DOHCtor's Avatar
Really amazing!!!! Two thumbs up!!
Marko!!
Old Feb 24, 2010 | 08:13 PM
  #63
grtpumpkin's Avatar
Nickle plating FTW! No wonder it is so shiny. I was wondering how you got such a rough casting to such a fine level of finish. If you don't mind my asking, how much did you end up paying to have the lower mani plated? What did you use for the initial finish removal, a flap wheel? The part that gave me hell was the damned part lines down the sides of each runner, they were a BITCH to get smoothed off!
Old Feb 25, 2010 | 12:12 PM
  #64
BlueCell's Avatar
Took an air grinder and used a lot of sand paper to get through the roughest spots. I didnt get the backside grinded because you cant see it. So most of the grinding was done at the shop. Then I took it to the coating place and they fine polished the rest of it. It costs about $650 for them to polish and coat for all the I/C pipes, the strut bar, valve cover, lower mani, and catch can bracket.
If they are a "BITCH" to get smoothed off, let someone else do it for u lol.
Old Feb 25, 2010 | 04:53 PM
  #65
grtpumpkin's Avatar
I would if I could believe me, but the chancellor of the exchequer demands that my mad money only stretch so far. Strictly as a DIY project, I could probably do it, but the backside isn't visable like you said.
Old Mar 1, 2010 | 07:49 AM
  #66
Tiu's Avatar
Tiu
So this is a 2 pieces intake manifold? Is it possible to fabricate and change the angle to fit the normal positioning of the throttle body to fit NA setup?
Originally Posted by BlueCell
Finally, found a clear shot of my engine....I knew I had one somewhere
Old Mar 1, 2010 | 10:40 AM
  #67
BlueCell's Avatar
Define 2 piece. This one has about 11 pieces. For this design to fit the normal set-up, the angle would need to be changed, the runners may be longer, the vacuum tube needs to be back in the center and a maf sensor hole needs to be on it. It can be made for an NA setup, I still have my old one to figure out where everything needs to line up.
im the fit
91
Dec 12, 2011 03:43 PM
gd3kamiwanaB
76
Sep 7, 2010 06:52 PM
WhEreZmYFiT
Apr 23, 2010 08:57 AM
Mr08FiT
Jun 19, 2009 11:29 AM
OneStopCustoms
Sep 27, 2008 01:21 AM
