Clutch Delay Valve
Old Sep 15, 2011 | 12:07 PM
  #81
fitisbamf's Avatar
Originally Posted by Jodele
I just went to AutoZone and picked up a CMC for $26.99 for a ’98 Civic Dx…it was P/N CM1366
does it look like the one pictured?
Old Sep 15, 2011 | 02:00 PM
  #82
Jodele's Avatar
Yes it does…
You will need a set of snap-ring pliers to remove the original stem. Take the rubber boot off of the new cylinder…even though the original Fit cylinder did not have that boot, I put it back on. I took all the pieces that came off of the Fit master cylinder and put them onto the Civic master cylinder…plus the boot.
Old Oct 26, 2011 | 06:45 PM
  #83
Leets's Avatar
Yes it does…
It looks like the hardline connects differently on the Civic and Fit MCs. Was this an issue? It seems like you and fitisbamf just pulled out the Fit one and bolted up the Civic one. Is there really that much movement in the hardline?
Old Oct 26, 2011 | 07:47 PM
  #84
fitisbamf's Avatar
the line comes undone at the cmc just switch them
Old Feb 11, 2020 | 01:55 PM
  #85
Atmos's Avatar
Almost 10 years now and I'm finally getting used to it.
Bounce
Jul 15, 2017 07:28 PM
sean5995
Apr 12, 2012 08:41 AM
axe
Jan 18, 2011 05:24 AM
Cachupin
Jan 5, 2011 10:24 PM
venom1055
Aug 20, 2005 04:56 AM
