Conservative suspension mods
Old Mar 26, 2013 | 05:11 PM
Rabee's Avatar
Will swift spring clear 205/50/16 tires??
Old Mar 26, 2013 | 05:20 PM
TPColgett's Avatar
EASILY
10char
Old Mar 26, 2013 | 05:35 PM
DiamondStarMonsters's Avatar
Drove a co-workers late model 1.8 Sentra at lunch today, talk about conservative suspension. Handled like a drunken donkey.
Old Mar 26, 2013 | 06:17 PM
Wafulz's Avatar
my buddy in his 1.8 sentra omfg its a headache maf Tps plugs then turns out to be a small leak in head gasket lol
Old Apr 22, 2013 | 10:34 PM
Rabee's Avatar
If I do swift springs + progress sway bar + camber bolts, isn't too much? I am afraid this will make my fit very tail happy! Lol
What do you guys think? Anyone had this setup?
Old Apr 22, 2013 | 10:52 PM
TPColgett's Avatar
It won't be tail happy. It will be VERY planted.
In my car when it had Swift springs, progress rear bar, HTS shocks on full stiff, and 3 degrees of camber up front you had to lift off throttle super late, brake hard, release and then make a severe steering input to get the rear to step out AT ALL!!!
I'm now on mono tube rear shocks on full stiff, doubled the rear spring rate and went toe out to actually get the kind of lift off throttle rotation I need for AutoX
Old Apr 23, 2013 | 03:49 PM
zilla8's Avatar
^^^This
your car will not be anymore tail happy with Swifts and rsb.I run this set up and the only way to get the tail to come around is if I purposely unload the suspension in a turn by lifting off of the brakes.
I never have to do this because I set my entry speed and get on the throttle early and power through/out of the turns.
I know lol a Fit powering out of anything
Old Apr 23, 2013 | 06:41 PM
Wanderer.'s Avatar
Sometimes when I get stuck using 3rd to power out I just want to kick the clutch a few times and have to remind myself it's my DD
Swift springs + anything will never be "too much" for anybody. Perfect for DD.
Old Apr 23, 2013 | 07:41 PM
Rabee's Avatar
you are a very helpful group of people, thanks a lot!
By the way, I took my 100% stock Fit to an auto-cross event, because my Boss 302 was still in its break-in period, and I want to tell you that I had a blast!
After a few turns in my first run, I immediately realized that the tires and the brakes suck! The Fit was doing everything surprisingly good apart from stopping properly lol.
So I will definitely upgrade the brake pads/system ( after tires of course)
I was surprised to see that in Tire Rack website, they don't list Hawk HPS or HP+ for 2013 Fit!!
Is there anyway we can get those fit in our newer Fit?
Old Apr 23, 2013 | 08:01 PM
TPColgett's Avatar
Boss 302? NIiice... What AutoX plans do you have for that?!
The Fit is an EXCELLENT AutoX car, trust me
Also, your 2013 Fit is mechanically identical to the other GE model years, so any 2009+ marketed parts that aren't bumpers and lips should fit.
That being said, I also have not been able to find a part number for a 2009+ GE... In fact.... not 100% sure but I think the brakes are actually the same from th GD-GE... Need to do some research!
Old Apr 23, 2013 | 10:57 PM
solbrothers's Avatar
Who gives a fuck about this stupid gay fit
POST THE MUSTANG!!!!
Vash
Aug 19, 2016 01:01 PM
Green karma
19
Jan 8, 2013 11:53 AM
Jazz GD3
Jul 11, 2009 03:07 PM
0.o slow 1.6
Car Shows, Events, and Racing
May 27, 2008 09:39 PM
slip
Apr 29, 2008 04:52 PM
