Which LSD
Old May 23, 2013 | 07:32 PM
  #101
Rabee's Avatar
Boss 302 comes with red and gray key
After your dealer installs the red key tune, once the red key is used, you are basically changing around 300 parameters in your engine.
What you will feel is this:
1) sharp throttle response
2) remarkable engine braking
3) launch control function enabled
4) lopey idle sound, just like a race car
And other little things that I don't yet feel
Old May 23, 2013 | 07:37 PM
  #102
TPColgett's Avatar
Man, that is WAY cooler than having to buy a $700 tuner and dial it in with the help of some one else like I'm doing
Man, pretty awesome OEM hot rod right there!
Old May 23, 2013 | 07:46 PM
  #103
Wanderer.'s Avatar
That's pretty awesome. I'd leave the grey key at home as a spare.
Old May 23, 2013 | 08:53 PM
  #104
Rabee's Avatar
I drive with red key almost always
And yes it an OEM hot rod
Imagine, in the owner manual they tell you how to prepare your car for the track!
But I am really seriously considering taking my Fit to a HPDE.
By the way I still could not find Hawk HP + to fit my 13, some people on the forum were saying, they fit but you have to scarify the metal clip?!
Old May 27, 2013 | 09:22 AM
  #105
Rabee's Avatar
Why do I feel like the steering wheel got heavier? Is that expected?
Old May 27, 2013 | 03:03 PM
  #106
TPColgett's Avatar
Heavier? As in on turn in? What did the toe end up at?... I would expect zero toe and negative camber to feel lighter and "darty" especially at freeway speeds...
Old May 27, 2013 | 03:44 PM
  #107
mkane's Avatar
Darty that one becomes accustomed to. Combined with 205's all is well.
Old May 27, 2013 | 03:54 PM
  #108
TPColgett's Avatar
Agreed! 100% How that should turn out...
Old May 27, 2013 | 04:52 PM
  #109
Heavier steering ftw. The heavier feel is most likely a result of the tires. More grip and friction and such.
Old May 27, 2013 | 05:22 PM
  #110
Rabee's Avatar
Heavier while turning, toe is zero and 0.01 ( almost zero)
I am going to post 2 pictures of my strut bolt ( spc installed)
Spc told me that the tap should be facing the engine to get the most negative camber, I emphasized this point to the 2 belle tires I went to, and guess what! The tap is facing the tires lol
One more observation, both upper and lower bolts on driver side are inserted from the rear, so the head of the bolt is facing the rear of the vehicle, however on the passenger side, they are inserted from the front, so the head of the bolt is facing the front of the vehicle, is this the way they are supposed to be??
Pix taken to the driver front tire from behind /rear of tire:
http://postimg.org/image/cutntlewl/7bdc6da3/
Pix taken to the passenger front tire from the front side:
http://postimg.org/image/pl0521nxv/62279da4/
Old May 27, 2013 | 06:43 PM
  #111
mkane's Avatar
Not sure it matters weather the bolt is inserted from the front or back, but the tab needs to be inboard for neg. camber. Here's our spec's;
Old May 27, 2013 | 10:13 PM
  #112
Rabee's Avatar
Old May 28, 2013 | 10:06 AM
  #113
Rabee's Avatar
What is the sweet point in between performance and tire wear?
I am now at -0.6
Old May 28, 2013 | 02:47 PM
  #114
Wanderer.'s Avatar
Just max it out, anything below 2 degrees will probably not make much difference especially since you LOSE camber when you turn with this suspension. In those situations where your tires are wearing the most you'll be closer to zero anyway.
Old May 28, 2013 | 02:51 PM
  #115
TPColgett's Avatar
Just max it out, anything below 2 degrees will probably not make much difference especially since you GAIN camber when you turn with this suspension. In those situations where your tires are wearing the most you'll be closer to zero anyway.
To clarify, by "GAIN camber" you mean that when the suspension compresses positive camber occurs yes?
When I was at -2.0 up front with the softer Swift springs, during hard cornering I was loosing SO much negative camber due to body roll and suspension compression that I had people observing POSITIVE camber on the outside tire
Old May 28, 2013 | 03:09 PM
  #116
Wanderer.'s Avatar
Correct, it is confusing now that I re-read it.
I suppose "losing camber" would be more accurate if the camber angle is starting negative and you define "camber" as inherently a negative measurement, which is almost always is. Thanks for pointing that out, I will change the OP
Old May 28, 2013 | 10:08 PM
  #117
Rabee's Avatar
Here is what I will do tomorrow, get -1 negative camber so that all the wheels have -1, front and rear, because the rear wheels are already at -1
Old May 29, 2013 | 09:15 AM
  #118
Rabee's Avatar
I took to belle tire and told them to direct the camber bolt TAP toward the engine and sure enough they were able to achieve up to -1.5, but I asked for -1 only as a sweet point in between tire wear and handling.
Thnx for your help
Old May 29, 2013 | 09:56 AM
  #119
mkane's Avatar
-1.5 camber will not hurt tire wear.
Old May 29, 2013 | 05:30 PM
  #120
TPColgett's Avatar
Agreed. I had my "daily" setup at -1.5° for over 2 years and still got near 30K out of my factory Dunflops
Still I bet the -1.0° feels better than the -0.6° did!!! How is the car now?
