TIRE questions,sizes, mounting,pressures ANY tire questions
Old Aug 23, 2006 | 10:56 AM
  #281
jim@tirerack's Avatar
Former Vendor
Some people just want the best dry handling tire they can get. Others are moreworried about tread life and wet traction. That is why there are so many choices.
Old Aug 23, 2006 | 11:06 AM
  #282
carlosalicea's Avatar
Yeah! Like I said . I would love to have the toyo A1R, but since I do care about wet traction and cost/tread life I vote for the khumo (KU15). Like you said there are many options, is just to what is important to each at buying time.
Old Aug 23, 2006 | 12:59 PM
  #283
hqly's Avatar
Originally Posted by InjentC
totally normal.
wow.. 2-4 psi a about a month is normal.. blows me away.. i heard 1-2 was normal.. guess i gotta pump air each month
Old Aug 23, 2006 | 01:00 PM
  #284
hqly's Avatar
Originally Posted by cheffyjay
It doesn't sound too out of line. Check this out:
http://www.tirerack.com/tires/tirete....jsp?techid=74
http://www.tirerack.com/tires/tirete....jsp?techid=73
http://www.tirerack.com/tires/tirete...jsp?techid=147
and ther is also tire gauge accuracy and variation...
The link references that losing 1 psi a montha dn 3-4 over 3-4 months is normal.. norhting about 24 per month being normal?
Old Aug 23, 2006 | 05:16 PM
  #285
InjentC's Avatar
especially in hotter states, like cali, where the original poster is from. hotter tems, hotter tires, constantly heating and cooling, 2-4 pretty normal. hell here in ga, i got close to 5psi/mo can also dependent on the tire compound, payloads, etc.
Old Aug 23, 2006 | 05:22 PM
  #286
DragonEye's Avatar
you could try filling the tire with nitrogen i think it was... but one of those other gases out there works really well too....
Old Aug 23, 2006 | 07:54 PM
  #287
InjentC's Avatar
yup, most luxury car shops do it. the only problem is if you get a nail teh tire blows. high pressure gas = bad.
Old Aug 24, 2006 | 07:44 AM
  #288
Stevens24's Avatar
Compressed air is already 80% nitrogen, 95% percent is what is needed for tires to see no pressure losses plus the lack of moisture helps the tire last longer. We installed a system at the dealership and all 07s(except Fit and Civics get it. Race teams have been using it for years.
Old Aug 24, 2006 | 07:43 PM
  #289
Raimondas's Avatar
Decided on the 195-50-15 GSD3's but they seem to be backordered nationwide
Anyone have experience with Hankook Ventus R-S2 Z212 ?
Old Aug 25, 2006 | 12:49 AM
  #290
hqly's Avatar
what are the possibility of a small leak? think this is worthy of me taking it to the tire shop?
my corolla and civic do not lose this much psi.. this is bizzare for a new car..
Old Aug 27, 2006 | 09:42 PM
  #291
valdesebent's Avatar
Stock tires ride like lead!!
The only thing I don't like about my new Fit is that the stock Dunlop 15" tires ride like lead. Rough , rough, rough!!!! Has anybody else noticed it and have you changed them out for a better ride?
Old Aug 28, 2006 | 01:38 AM
  #292
Packy's Avatar
Frequent FitFreak Poster
What is your PSI for the tires? I'd check your air pressure to make sure it isn't too high
Old Aug 28, 2006 | 01:50 AM
  #293
BargainSeeker's Avatar
I don't mind the ride of the stock tires myself so I haven't swapped out my tires. I did check the Consumer Reports website for you, however. For a good tire across the board (except for ice braking) that rates excellent in ride comfort and impact absorption, CR recommends the Hankook Mileage Plus II H725.
When I replace my tires it will be with CRs top rated performance tire -- the Falken Ziex ZE 512. We have been using these tires on our other vehicles and they are very good to excellent across the board. They are relatively cheap as well (see Edge Racing). They don't rate as highly on comfort as the Hankooks though.
Old Aug 28, 2006 | 02:05 AM
  #294
mexellent's Avatar
Another good tire is the Bridgestone Potenza RE950. Im on my second set and I am very satisfied with them. Dry grip is good and the wet grip is amongst the best of any tire Ive ever owned. Another thing I like about this tire is the road noise- or lack thereof. Its an excellent tire for everyday driving. I dont think they make it anymore though, youd have to look at the RE960, and I havent driven on that one yet, but if its anything like the 950 then Im sold.
Old Aug 29, 2006 | 01:20 PM
  #295
Former Vendor
You could have the tires checked. Losing 4 lbs is quite a bit.
Old Sep 2, 2006 | 11:26 AM
  #296
rox101sg's Avatar
size is 195/55 or 195/50
Old Sep 2, 2006 | 01:13 PM
  #297
Joe_Schmoe's Avatar
^ or go 205/50 and the closest match I can find to the OEM diameter (in 15s) 215/50, which are pretty rare but tire rack has some advertised.
If you want more comfort go to more tire not less tire. Downside is you may hurt milage a little bit.
Old Sep 2, 2006 | 10:13 PM
  #298
MirrorWorks's Avatar
How wide is too wide?
I've been using this calculator:
http://www.rims-n-tires.com/rt_specs.jsp
Assuming stock is 195/55/16 15x5, how wide is too wide? I plan to lower about 1 inch. There are no configurations that are exactly the right width, so I'm trying to figure out what size tires I get if i get 16x7 inch rims.
205/45/16?
Thanks for your input.
tre
Old Sep 2, 2006 | 11:30 PM
  #299
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
205's are what everyone is running I believe. Im going to try and fit 215/50/15's.
I dont know how thats going to work out.
Old Sep 3, 2006 | 12:03 AM
  #300
That's not the exact same dimensions as the stock...so its going to jack up the speedo according to that website.
tre
