Transponder key no longer working
Old 09-03-2016, 01:12 AM
KV43's Avatar
Well I just came home from a run and during the run I dropped my key and guess what, it doesn't work anymore is there a way to get it repaired or am I just going to have to buy a new one.
Thanks for any help, I couldn't find much info on the subject
Old 09-03-2016, 03:11 PM
James Butler's Avatar
I would open the key transponder. See pages 395 and 396 of owner manual and remove and reinstall the battery to reset the unit and make sure battery connections are good. Let us know how it works.
PS. If it got wet there may be no hope because of corrosion.
James
Old 09-03-2016, 04:47 PM
KV43's Avatar
James
So Ive already opened it up and cleaned the battery contacts, the battery is about 10 months old, and I looked for any corrosion or wetness and there's none.
Old 11-01-2016, 12:42 AM
gkitf16's Avatar
Don't get ripped off on replacement key remote!
Sounds like one of the small chips on the board inside the key may have cracked loose, etc. Get a replacement key fob blank for less about $12 on eBay. Honda wants $109 for the same p/n key + the cost of cutting and programming it!!! The dealer does charge to cut and program your key. Did this with my '09 base Fit and works perfect! Get the key here:
Replacement for Honda Fit 2008 2009 2010 2011 2012 2013 Remote
Old 11-01-2016, 01:46 AM
KV43's Avatar
Man this is pretty much exactly what I was hoping for, I'll definitely do what you said and I'll report back prices and whatnot later. Thank you!
cecevaqueraa
11-17-2020 05:34 PM
ritholtz
12-02-2018 05:49 PM
ritholtz
12-02-2018 12:02 PM
BenQuick
09-29-2016 05:44 PM
FiveFreshFish
09-27-2008 10:04 PM
Quick Reply: Transponder key no longer working
