Bad new body kit
I like everything you've done so far and the gauge pods are very nice, but, I cannot as Wanderer stated, figure out why you would abandon the exterior/body work -and test drive it first- before starting on the interior and engine upgrades. With all the body work I would want to know if the moldings could even stand up to the extreme elements/vibrations/speed-aero dynamics and all without disintegrating in the process...
I didn't stop work on the body. I bought a new rear bumper and I'm trying to come up with a design that I can make possible and like,. M as for the streangth the body can withstand 124mph and I forgot what else I was going to say
So you must already now I like making easy stuff complicated.
What do you guys think about no power steering???
The sc is made for the tsx with electric power steering.
I just mite have a solution to the power steering issue
so here is my install
so to start off tsx has an e.p.s.so in order to fit my power steering pump i had to modify the bracket that will take its place
with my new bracket half of the pump is air born
pulleys are straight
the other bracket for the ps pump
im not sure if you can see all them but i now have 8 pulleys lol
now comes the wiring. so far this is the biggest pain in the ass. the wiring diagram for the ecu (also known as Powertrain Control Module pinout numbers) took me about 3 hours to find. the pinout numbers i found are for the 08 accord coupe but they appear to be the same. for anyone who may plan on scing 8th gen accord i'll post everything i used on a new thread
Correction the 08 accord coup has a different pin than the sedan and to my knoladge 06 civic has the same pin out as the 08 accord coup. The differences between the sedan and the coups is minor. The MAF and I think some of the ground are moved. Luckily a guy at my local honda dealer was able to give me a print out of my cars pinout.
