View Single Post
  #14 (permalink)
Old 09-18-2007, 01:58 AM
AJ PwR Jr.'s Avatar
AJ PwR Jr. AJ PwR Jr. is offline
Platinum Honda FIT Vendor
AJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to live
Send a message via AIM to AJ PwR Jr.
Quote:
Originally Posted by fit4idaho View Post
So what do you suggest for handling the heat from the header. Tape, ceramic coating or custom shield?
You can always get the header ceramic coated or heat wrap. I dont think it is necessary because the L15A doesnt produce that much heat to affect the performance.
Quote:
Hey Ben, how hard is this for DIY??? You need to jack up the car? PM me for 11204, thx.
It's pretty easy. You will need to jack up the car and unbolt the bottom bracket and the nuts/bolts which held the header then you can slide it out from the top (make sure you take of your engine cover). Then you have to get the T1R header slide in the way ou slide out the stock header. Bolt it back up ..... DONE.... thats it
__________________
A&J Racing International
#155-1991 Savage Rd
Richmond B.C. V6V 0A4
TEL: (604)279-0329
Email: info@aj-racing.com
URL: www.aj-racing.com
Your JDM parts and Honda Tuning Specialist
