LED tailights, install, convert, DIYs
Old Nov 20, 2007 | 09:34 AM
  #201
kndlewis's Avatar
Yo kndlewis can u take some closeup shots of the taillights? like from the side (i want to see fitment) and maybe with the LED'S actually lit from far away? Any kind of shots will help me a lot. Thanks!
Fitment is great! A finishing touch that fits_all needs is a Stealth Bulb for the blinker bulb. Zeta products sell these bulbs, too. They look silver when not lit so there is no "amber glow" in the reflector until they light up.
Night shots!
Old Nov 21, 2007 | 09:14 AM
  #202
fits_all's Avatar
i got those "stealth bulbs" for my front blinkers...i like the amber reflection on the rear though..
anyways, i may be getting led bulbs as well for the blinkers and reverse bulbs...thanks for the tip btw
Old Nov 22, 2007 | 05:24 PM
  #203
ilovemyGD3's Avatar
here are a few shots of mines! genuine honda l.e.d's!
Old Nov 25, 2007 | 03:19 AM
  #204
saiko's Avatar
Avid FitFreak Poster
Mike!!! HAHAHAHA
Old Dec 1, 2007 | 06:23 PM
  #205
espo79's Avatar
Well after waiting a while cause my tailights were lost at the post office i finally got them in. Ill post pics beg of week being that its already dark. Anyhow the install took me about 3 hours but then again most of the time i was watching my son. I bought the n1 concept tailights and after reading just about everypost i could find on here about tailight install it was pretty easy. I did not have to take my bumper off and i didnt need to splice anything either. Like its been said if you take a couple of the clips out and unravel some tape you can get it to work just fine. I did have somewhat of an issue with my passenger side light fitment. seems a little tight on top and spacious on the bottom where it meets the bumper. all in all though its looks HOT!! I got the smoked/red on my black fit and so far its eye candy.. anywayz thanks to some of you guys here on the forum and n1 s DIY install this installation on a scale of 1 being tremendously hard and 10 being easy as hell i would say overall its about a 3.. Good Luck to you guys with doing it and Thanks again to N1 concepts definite recommendation
Old Jan 1, 2008 | 09:53 PM
  #206
Halcyon's Avatar
N1 Tails
This might be a repeat question but where are N1 concept led tails made? I was thinking of them vs jdm, as they are 100$ instead of 400$ and anything made in japan i have to pay that stupid border tax.
thanks
Old Jan 13, 2008 | 08:41 PM
  #207
Jazz GD3's Avatar
can anyone take a picture of the Jdm LED tailight's brightness when its at night just on, and one where it has the brake light on?
i want the jdm original led smoke style, but im plannign on buying some copies, probably from N1. I just want to see if its actually brighter then stock, so itll convince me in buying some, not jsut for looks.
thanks
Old Jan 14, 2008 | 05:33 PM
  #208
Jazz GD3's Avatar
bump on the road
Old Feb 23, 2008 | 04:15 PM
  #209
Crucio's Avatar
Hey Guys,
i just tried to install some taillights on my own.
I notice the bottom screw that is below the tailight is very far up and in a narrow space under the bumper. I know some of you mentioned you can do it without taking off the bumper. I have a screw driver that can get up to that portion of the light and unscrew it but my worry is how do i screw it back in?! there is so little space your screwdrive can go in and you cannot hold the screw still to screw it in because your hand cannot go up there. It seems very difficult to screw it back in, what were your experiences with that screw?
Also, the top bolt is another one im worried about, my hand cant even fit inside the little space that we pop out to see the wires. Am i supposed to take off the entire surrounding in the trunk to get up to that top bolt? i can probably squeeze something in there and unbolt it but then im stuck with putting it back in properly because my hand cant fit. Did you guys have difficulty putting back that bolt?
i may just take it to the shop to get this installed, i dont think i know what i'm doing
Old Feb 24, 2008 | 09:33 AM
  #210
kndlewis's Avatar
I used a screwdriver with a magnetic tip, the kind with a 1/4" hex that you can add extentions and different bits. That held the screw and reached up with no problem. Another mechanics trick is to dip the end of your standard screwdriver in some grease. The grease will hold the screw while you screw it back in!
Use a flashlight or a shop light to shine up there. It helps if you can see what you're doing!
This one I used a little universal joint on a 1/4" driver. But that's not really necessary. A long enough screwdriver will reach the screw with the handle out where you can turn it. No need to take off the lining. I thought that would be easier and started to take it off but that turned out to be a little more difficult than I thought! So I put it back on and worked through the openings.
Good Luck!
Old Feb 24, 2008 | 11:17 AM
  #211
cojaro's Avatar
Has anyone bought these yet? Are they manufactured by the same company as those sold by N1Concepts?
They're both $219, about double the price of the N1 lights (which are $100). That's why I'm asking if they're made by the same company.
06-07 Honda Fit/Jazz Smoked LED Tail Lights :: TAILIGHTS :: LIGHTING :: EXTERIOR :: weksos industries
Old Feb 26, 2008 | 04:34 PM
  #212
Raymond87's Avatar
Crap this thread is huge... I'm going to be installed some OEM JDM fogs on fit_love's Fit pretty soon and need a step-by-step how-to, if there is one, on doing these. Extending wires is easy but I need to know what to remove, how to remove it, and where to go from there. Thanks in advance!
Old Apr 26, 2008 | 09:16 AM
  #213
Suzi_q's Avatar
Im so happy with how they came out.
Please excuse my dirty car, was on the skidpan a couple of days before I installed the lights.
Old May 27, 2008 | 02:25 AM
  #214
ghibli99's Avatar
Did mine today. Took about 2.5 hours. Will probably do a longer writeup later, but a few thoughts:
1. Taking off the bumper is easy and makes getting the light assemblies in/out a snap. If you don't, or if you just peel the bumper back a bit, you really risk scratching up the body paint around the lights. This made things a breeze, and the bumper is only 2 phillips, 2 hex, and 2 pop-its.
2. I had to splice and solder a total of 7 wires (5 passenger, 2 driver). I was running out of light (I started at about 5:30PM thinking it was only going to take me about an hour), so I had to rush it a bit. Some of my solder connections weren't the best, and my shrink tubing didn't fit over a few of the connections, so I just electrical taped them for now.
3. I tried to just do the "shimmy" move for the reverse lights, but I'm going to redo the connections with the correct sockets. It was stupid of me not to, but I'll do it another day when I have more time (and light!).
That's about it. If I knew ahead of time what I'd be doing, it would probably take me about 1.5 hours instead of 2.5, but this is no 20-minute job. More later, but in the end, I love them, and will have pictures soon.
-Mike
Old Jun 2, 2008 | 12:12 PM
  #215
jazzman's Avatar
Can i ask something?
When you fixed the lights everything was OK?
because mine has a little space between the lights and the bumper.
How can i fix this problem?
Old Jun 2, 2008 | 01:08 PM
  #216
ghibli99's Avatar
You can loosen the 3 nuts behind the lights and make minor adjustments in their exact placement. Also, you can slightly adjust where your bumper sits based on where you position the bumper when reinstalling the hex screws. The clip below the taillight can also be adjusted (well, bent, but I wouldn't recommend it) slightly. I would start with the 3 nuts behind the light assembly, and fine-tune the placement of the lighting assembly.
-Mike
Old Jul 5, 2008 | 06:35 AM
  #217
F0NIX's Avatar
Combining brakinglight and drivinglights
I have just read trough this thread because I have just received the lovely "Jazz Back Lamp - Euro Type - Black" from G-One Auto and they look like this:
They are produced by Altezza, and they arrived with two extension cords (looks like they are for the turn signal cord) and a installation manual in Chinese or Japanese (I cant read either).
I have found out how to unmont the old one: three bolts in the rear accessed through the little hole where you change the bulbs. And one screw from the bottom accessed with a long thin arm and/or a long screwdriver.
All this is no problem, I have allready tried on one side, but had to put the old one back when I discovered another problem:
My original rear lights has 4 bulbs, the new one has only spaces for 3 bulbs.
The original have brakelight (red), rear light (red), reversing light (clear) and turn signal (orange) bulbs. I also discovered that the plug to the original brakelight has 3 leads in to the plug but the other three has only two leads in to the plugs.
Maybe there is a way to combine rear and braking light into one bulb?
Do I need a spesial bulb for this? Is it that simple? Or is there other ways around this problem?
Old Sep 11, 2008 | 01:36 PM
  #218
Luichenwai's Avatar
Question:
So instead of solderering... Can I just splice the wire and add the extension wire and wrap the part where they connect with electrical tape.(really tight and secure)?
Old Sep 11, 2008 | 02:05 PM
  #219
fits_all's Avatar
its still a wire dude, lol
thats what ill be doing. if doesnt works, ill make it work hahah
but as far as my little knowledge with wire things goes, im 95% sure it will work
Old Sep 11, 2008 | 06:19 PM
  #220
kndlewis's Avatar
If you don't want to solder, use butt splices. They look like plastic coated tubes that you put a wire in each end and crimp with your wire strippers. That would be better than wrapping and taping. No matter how tight you tape it, it will come loose over time. Butt splices are available at all the auto parts stores and Radio Shack.
