Unlock my doors, please!
Old Aug 22, 2009 | 07:46 PM
  #181
Stravos's Avatar
Does anyone know if it's possible to have the doors lock at 9mph (default on my Fit) and unlock when put into park? I did this code today and it worked (thanks!), but now my doors lock as soon as I take it out of park, which I don't like.
Old Aug 23, 2009 | 04:57 AM
  #182
Black3sr's Avatar
Stravos - Mine do.
Old Aug 23, 2009 | 08:36 AM
  #183
Ando's Avatar
See my earlier post in this thread about how to lock the doors in either Park Mode or Drive Mode.
Old Aug 23, 2009 | 08:10 PM
  #184
55Fit55's Avatar
Originally Posted by CrystalFiveMT
This is from memory, so forgive me if this doesn't work:
- Insert key and turn forward 2 clicks (don't turn engine on).
- Press and hold the door lock button to its "unlock" position.
- After 5 seconds you'll hear a click. DON'T LET GO YET! Wait another 5 seconds until you hear another click.
You're done.
Hope that works.
The secret to this is removing the key after the second click.
I tried the above method about 6 times with no luck, until I noticed the key removal part someone mentioned pages later.
Hopefully this post will save somebody some time.
<----------------- IA/TVTECH with my paddleshifters
Old Aug 27, 2009 | 02:52 AM
  #185
Shockwave199's Avatar
First off, thank you for this info! Oh how great this is!
Now, there's a slight twist. The original proceedure-
- Take the key out immediately
I have an '09 Sport A-T. I had to wait for three clicks and then take the key out, for this to work. The original proceedure didn't work for me after four attempts. So in short, if the original proceedure doesn't work, add one more click and then turn the key off and pull it out. Also, after doing this my doors still lock at the default 9 mph setting, which is what I want.
Sweet! Thanks again!
Alternate proceedure if the original doesn't work-
- After 5 seconds you'll hear a click. DON'T LET GO YET! Wait another 5 seconds until you hear another click. Don't let go yet! Wait another five seconds until you hear one more click.
- Turn the key to off position and take it out immediately.
Dan
Old Aug 27, 2009 | 09:24 AM
  #186
mikeual's Avatar
Hey Rangefit the third click thing did the trick. My only complaint about the Fit has been resolved. My wife and I could'nt be happier. 250k here we come.
Old Aug 27, 2009 | 09:58 AM
  #187
Dennis51's Avatar
The third click does the trick!
The procedure: waiting for the 3rd click worked like a charm on my Base MT. Locks pop open when I remove key, and still lock automatically once underway. Thanks, everyone!
Old Aug 28, 2009 | 08:14 PM
  #188
FogyinFit's Avatar
Our new Fit base auto is my wife's daily driver, and she's only had two complaints about it. First was the doors not unlocking when parked. Well, thanks to Crystal and you others, plus about fifteen seconds, I got that problem solved! She is quite pleased.
Next up are the following: carpet floor mats, Accord horn (her other beef), and a remote keyless blank, all from CHH.
I love this car. Too bad I hardly ever get to drive it!
Old Sep 11, 2009 | 05:40 AM
  #189
methodr's Avatar
It works! Thanks for everyone who contributed to this thread! I was in a rush at the dealership so I never got to go over all this type of stuff. Thanks!
Old Sep 18, 2009 | 01:46 AM
  #190
Fit4Cycling's Avatar
Yeah, thanks for this. My kids were getting on my nerves with the rapidfire "the door's locked Dad (aka: stupid)" latch pulling. They didn't like Daddy's return "THE CAR IS ONLY 5 DAYS OLD!!!" look either.
Old Sep 18, 2009 | 09:43 AM
  #191
blyndgesser's Avatar
THANKS! Now my wife won't give me the look every time she tries to get out of the passenger seat.
Old Sep 19, 2009 | 03:12 PM
  #192
BayAreaKid's Avatar
This has worked after many failed attempts! Instead of pushing the unlock button and waiting for 3 clicks, I was pushing the lock button...not reading the post close enough.
Old Sep 24, 2009 | 10:31 AM
  #193
docjim2's Avatar
This must be a post for newer FIT's since my 2007 does not have this feature... but I do like the feature that will not let me lock the car when the key is in the ignition: kool...
Old Sep 25, 2009 | 12:00 PM
  #194
skunk2fit's Avatar
i need so much help.
my battery is dead.
i cant get into my car because the key wont unlock the doors nor turn off my alarm.
how do i get in without setting off the alarm?
Old Sep 25, 2009 | 12:46 PM
  #195
docjim2's Avatar
if your battery is dead then why worry about setting off the alarm. if it goes off just pop the hood and disconnect the battery cable... otherwise call AAA or a local mechanic that makes house calls... sorry I feel your pain but have never had anything close to a problem like yours since I owned Hondas...
Old Sep 25, 2009 | 04:01 PM
  #196
Black3sr's Avatar
my battery is dead.
Please clarify. If the battery is dead then there will be no alarm.
You say key will not open door or turn off alarm? Alarm is on? Did you mean the remote on the key does not work? Of course it does not as the battery is dead. Use the key key to unlock your doors. Put the key in the lock and turn it.
Old Sep 25, 2009 | 11:28 PM
  #197
skunk2fit's Avatar
thanks. i kind of knew that but i was just so frustrated that i couldnt think straight.
Old Sep 26, 2009 | 03:06 AM
  #198
Black3sr's Avatar
So did you get in?
Old Sep 26, 2009 | 10:17 AM
  #199
skunk2fit's Avatar
yeah, i got in but now i just need to get a new car battery. cant find one
Old Oct 6, 2009 | 12:18 PM
  #200
blassty's Avatar
For some reason the methods above didn't work for my car to have doors unlock when I turn my key out of the ON position.
I have an AT Sport.
I did the following for my doors to unlock when I switch to off (this is in the manual) but the following is from my memory:
1) Pull up E-brake, Insert Key, Switch to the ON position (don't start the engine, make sure doors are closed
2) Press Brakes, Twist Key and start engine, switch from (P) to (N) Neutral.
3) Hold Unlock button for 5 seconds, hear a click (don't let go yet), wait another 5 seconds and hear a 2nd click, then let go of unlock button.
4) switch from (N) to (P) Park, let go of Brake, Twist key from On to Off and remove.
