View Single Post
  #1358 (permalink)
Old 07-25-2008, 09:14 AM
mahout mahout is offline
mahout is a glorious beacon of lightmahout is a glorious beacon of lightmahout is a glorious beacon of lightmahout is a glorious beacon of lightmahout is a glorious beacon of lightmahout is a glorious beacon of light
Quote:
Originally Posted by Blackwing703 View Post
Hello fellow FitFreaks,
I found a set of rims that looked great, but I'm not sure if it will work out. They are 15x7" +35mm offset. I will put 205/50 tires on the rims. And right now I'm on stock supension, but I have GF210 that I'll be putting on in the future. Was wondering if this will rub or cause extra wear on the tires or any kind of problems.
Thanks for your help.
Count on rubbing like the dickens.
42 mm minimum offset stock and 45 mm when dropped is the rule here for 205 section tires of ca 23.5" diamter.
