Unlock my doors, please!
Old Oct 6, 2009 | 04:19 PM
  #201
Black3sr's Avatar
Originally Posted by blassty
For some reason the methods above didn't work for my car to have doors unlock when I turn my key out of the ON position.
I have an AT Sport.
I did the following for my doors to unlock when I switch to off (this is in the manual) but the following is from my memory:
1) Pull up E-brake, Insert Key, Switch to the ON position (don't start the engine, make sure doors are closed
2) Press Brakes, Twist Key and start engine, switch from (P) to (N) Neutral.
3) Hold Unlock button for 5 seconds, hear a click (don't let go yet), wait another 5 seconds and hear a 2nd click, then let go of unlock button.
4) switch from (N) to (P) Park, let go of Brake, Twist key from On to Off and remove.
I prefer previous method. You should keep trying because then the doors will unlock as soon as you put it in park. No need to shut it off to kick the freeloaders out. You need to wait for the third click I believe but check the previous messages in this thread.
Old Oct 6, 2009 | 09:57 PM
  #202
Shockwave199's Avatar
About post #185 on page ten of this thread-
You must take your key out at the end- not just turn it to the off position leaving the key in. Also, pushing and holding the door lock refers to the door lock button on the drivers door, not the keyfob. I know that seems obvious, but the first time I read through all this I assumed it was the keyfob.
I noticed something just last week and I don't know if this has always been so, or the reprogram causes it. If you push unlock on the keyfob and don't enter the car before the interior lights dim to black, the car locks itself again. Is this a normal, default setting? It seems reasonable even if it is, but I'm just wondering.
Dan
Old Oct 6, 2009 | 11:59 PM
  #203
blassty's Avatar
Hmm...you have a point. Unlocking the doors when switching to P is more logical instead of having to switch it off.
Old Oct 7, 2009 | 06:18 AM
  #204
Black3sr's Avatar
Dan
I like this feature. I think I may have read it in the manual. If you do not open the door within 30 seconds it will re-lock. Great for when you accidently hit open on the Fob with no intention of getting in the car. I could be dreaming too about the manual.
Old Nov 3, 2009 | 01:30 AM
  #205
Jennnyy's Avatar
I did the unlock button and wait for 3 clicks method and it worked like a charm
Old Nov 10, 2009 | 08:16 PM
  #206
FITNuB's Avatar
Works great! as one posted before, you have to take the key out as soon as the second click happens. theres one click immediately then 2 at 5 sec intervals. after that take the key out wait a sec. to test it: turn your car on put it in neutral then throw it in park and it worked! THANKS GUYS!
Old Nov 12, 2009 | 04:17 AM
  #207
FitDEEZ's Avatar
worked perfect after the second click 4 me.. took me 2 mins
Old Nov 18, 2009 | 04:58 PM
  #208
fjt's Avatar
fjt
Originally Posted by CrystalFiveMT
This is from memory, so forgive me if this doesn't work:
- Insert key and turn forward 2 clicks (don't turn engine on).
- Press and hold the door lock button to its "unlock" position.
- After 5 seconds you'll hear a click. DON'T LET GO YET! Wait another 5 seconds until you hear another click.
You're done.
Hope that works.
I have a M/T 09 and this worked perfectly..
Just turn key to off after you hear the 2nd click..
Thank You
Old Dec 19, 2009 | 11:58 AM
  #209
Chazzlee's Avatar
"P's" a better deal IMO...
I've found this auto unlock when in P (on my AT) a better deal... Previous to this setting change my 'ol lady (and other passengers) would fume about being held captive whenever I forget to hit the master unlock door button right away!
Now when in P all the doors unlock for everyone right away, and it's a real simple thing for me to just hit that master door button to lock all the doors again as I exit the car. -And of course the keyless fob's remote unlock makes it easy for me to get allus back in again...
Old Jan 12, 2010 | 12:37 AM
  #210
FITunion's Avatar
Set the auto unlock when shift to P. It is wonderful. Thanks for the instruction. You guys are full of knowledge.
Old Jan 20, 2010 | 05:54 PM
  #211
Blackberry Goose's Avatar
Same deal here on our new 2010 Blackberry Pearl Sport A/T...thanks! Doors lock automatically when putting in reverse rather than 9 mph but that's ok. The main thing was the unlock all when putting in park
BG
Old Feb 1, 2010 | 02:34 AM
  #212
lovelyprasanna's Avatar
do anybody know how turn on auto door locking in M/T honda jazz in indian version we dont have master lock button in driver door.... only lock tab! please reply guys@
Old Feb 1, 2010 | 10:07 AM
  #213
niko3257's Avatar
FitFreak GE8 DIY Guy
it's not possible in your car.
Old Feb 1, 2010 | 12:28 PM
  #214
thanks
hey thanks man,,,, where r u from?
Old Feb 2, 2010 | 10:06 AM
  #215
niko3257's Avatar
I'm from USA and if i'm not mistaken it can only be
done to our cars. Meaning the usdm body type which
is in serval other contries.
Old Feb 10, 2010 | 03:35 PM
  #216
mommabear's Avatar
This worked for me after a couple tries... I think I might have waited for a 3rd click. I'm in a 2010 M/T btw
Thanks for the 411 CrystalFiveMT!!
Old Feb 13, 2010 | 11:00 PM
  #217
casinobon's Avatar
I have a stupid question about the back door locks. Can't find my manual. I think we have it in the childproof mode for the back door which won't open from inside. Help. Thanks. This is a 2008 Fit Sport automatic.
Old Mar 11, 2010 | 08:53 PM
  #218
ShotgunSi's Avatar
Thanks, this worked for me in an 09 Fit Sport Manual.
Kept the transmission in neutral, parking brake on, wait 3 clicks, remove key and viola!
Old Mar 12, 2010 | 10:43 AM
  #219
niko3257's Avatar
this is for GE8 Fit's
you have a GD3
you might have to go to the GD section
to find what you need.
Old Mar 19, 2010 | 12:36 PM
  #220
britdevine's Avatar
Installed a new battery yesterda on my 2010 AT Fit Sport and had to reset door locks.
The two click method worked great.
i guess when you disconnect battery you need to reset the doors.
