Gas mileage
Old Jun 2, 2006 | 10:06 PM
  #101
FITforKRUG's Avatar
Originally Posted by Jetydosa
Im no engineer either, but its a fact that a car at a higher elevation makes less horsepower due to lower air density than one at sea level. That said, its going to take more "throttle" to go up the same hill that would be at high altitude vs an identical hill at sea level, ie the engine will have to work harder. BC of that, you will consume more gas.
Im just saying that would be a larger factor IMHO of cars at higher elevations than the other reasons mentioned in this thread (gravity, less
air drag).
The thing is for a given throttle position you will use less fuel at high elevations since the air density is lower and the ECM will maintain the proper fuel/air ratios or else the car wound not meet emission laws. It's all about using the same amount of work to get up a hill regardless of elevation. A gallon of gas will have the same amount of energy regradless of elevation. If the fuel is burned at the correct ratio to air you will get the same amout of work from that gallon of gas.
Same size hill-same amount of work being done- same amount of fuel used -but the throttle will need to be open more to let the same mass (not volume) of air to be used with that gallon of gas to get up the hill at the lower air density.
BTW I am a senior R&D test technician for an auto supplier here in the "motor city" (Detroit) and work with a few very good engineers. I will talk to them and ask question about this.
Old Jun 2, 2006 | 10:13 PM
  #102
Jetydosa's Avatar
I understand what your saying. If what you said is true, though, can you explain why cars run the 1/4mi slower at higher elevations vs lower? Back in my drag racing days, a difference of even 1000 feet makes a significant difference in ET. Not trying to argue, just wondering how you/they would explain that.
Old Jun 2, 2006 | 10:29 PM
  #103
FITforKRUG's Avatar
At wide open throttle there is less air pressure to push air into the cylinders thus limits how much fuel can be burned at the best fuel/air ratio. The engine will pump less air mass (not volumm) for each stroke of the pistons at high elevation limiting how much fuel can be burnt.
See, turbos (vs superchargers) are great for high elevation since they just spin faster at high elevation to push more volumm into the engine. It's all about air mass not air volumm. If you take a give mass of air at sea level and seal it in a trash bag and drive it to a top of a mountain what will happen to that trash bag. It will inflate and get very tight. the mass is the same but the volumm has increased. Each stroke of the piston is fixed in volumm ( bore x stroke) so at high elevation the cylinder is using the same volumm but less air mass.
Old Jun 3, 2006 | 12:04 PM
  #104
Jetydosa's Avatar
I think a lot of times gas stations pump calibrations are off. I have a friend with a Civic Hybrid that checks his gas milage religiously, and he once put in ~2 gallon more than the tank capacity. He called the state inspection line and complained, and later the station was inspected and fined!
Old Jun 4, 2006 | 01:58 AM
  #105
Gordio's Avatar
Originally Posted by fitjunkie
my first tank of gas in NY is around 24 mpg as well, second tank is a bit higher, now the third tank seems to be getting around 30 mpg, so hopefully it will get better, I think must be something in NY gas that makes the mpg average lower...
I'm sure it's the hills of the city. I am currently averaging 33-34mpg, and I drive in SF
Old Jun 5, 2006 | 09:44 PM
  #106
eeeeeha's Avatar
Smile Gas Milage, Base with Auto
I just filled up first time, with just short of 300 miles on the car I got 33 MPG. It is a Base model with automatic. I gave the car no slack, always first away from the light and accelerated to speed limit as quickly as possible.
Old Jun 5, 2006 | 10:29 PM
  #107
brainfood's Avatar
Anyone with intake/exhaust either or both have gas mileage for their cars? I figure its the same or better just checking.
Old Jun 6, 2006 | 01:45 AM
  #108
IBTG81's Avatar
I'm ay 800 miles and still only averaging about 28mpg.
I drive about 50/50 city/highway.
I'm a big guy (6'3", 280). Could that be the problem?
Old Jun 6, 2006 | 10:22 AM
  #109
fitjunkie's Avatar
I think it's got something to do with the NJ gas...I'm getting similiar MPG in NY and NJ...it's the wash down blend of gas...
Old Jun 6, 2006 | 06:02 PM
  #110
metaxadude's Avatar
This has nothing to do with mileage but I picked this site because there appears to be a lot of people on it. Check out this new spy siting of the next generation of Fit being built in China. Unfortunately, it's all in Chinese. Can anyone here translate and give us a reader's digest version of any differences to the current model? You can definately see that it's a Fit...the style cues are there. If anyone can help out, it'd be great.....thanks.
http://chicago-auto-show.autoblog.co...-chinese-site/
Old Jun 6, 2006 | 08:28 PM
  #111
gcisko's Avatar
Mileage Getting Worse?!?!!!
New Fit Sport AT: Rural/City driving (35 miles each way to work, takes about 1hr 15 min due to heavy traffic).
1st Tank 312 miles, 9.6 gallons = 32.49 mpg
2nd Tank 309.9 miles, 9.76 gallons = 31.75 mpg
3rd Tank 299.4 miles, 9.95 gallons = 30.09 mpg
At this rate, I'll be getting only 3 mpg after another 11,000 miles or so.
Old Jun 6, 2006 | 11:41 PM
  #112
NCFit's Avatar
Post
Mine has varied anywhere from 32mpg to an amazing 41mpg! in a 6 week span.
Old Jun 7, 2006 | 11:52 AM
  #113
Phil Monat's Avatar
My area gas stations have been picked apart and I only use the one station that gives the best mileage for all 5 of my cars. That said and no added weight or other major varialbles, I'm still hovering on 33 MPG. This is done on refills of no more than 7.5 gals.
I don't wait for an idiot light. However technically if gas weights ~8.5lbs./Gal your car is lighter by >40lbs at the 1/2 tank rather than the full tank, so your mileage should be better below the 1/2 tank. (Ha.....Ha)
Old Jun 9, 2006 | 07:05 AM
  #114
smeister's Avatar
Interesting how people aren't even getting 30 MPG. I am getting 35-40 MPG everytime I fill up. I drive 20% City and 80% Highway and have about 1700 miles now.
Old Jun 9, 2006 | 11:06 AM
  #115
coopula's Avatar
I havent gotten less than 40 ever with a high of 44.68
Old Jun 9, 2006 | 04:46 PM
  #116
gimme's Avatar
Master FitFreaker
doesnt matter how i drive, i get no more than 26. 12mpg less than advertised. Honda is getting a call from me.
Old Jun 9, 2006 | 05:25 PM
  #117
hiroko12's Avatar
I had a 2003 Altima Se with AEM CAI and Stillen Exhaust. I ran it quick and it still averaged 23-26 MPG. This is the 3.5 V6! It had roughly 270 hP. Those of you getting only 28-29 MPG I don't understand. Sure your caluculating your mileage correctly?
Old Jun 9, 2006 | 11:23 PM
  #118
fitjunkie's Avatar
Pretty damn accurate i think, when the light comes on I filled up till it clicks off and divide the total trip mileage by the gallons pumped in...I do a full reset after each fill up...I just made past the 600 mileage club, so hopefully things would get better...the best MPG so far I got was 26 MPG... and it's not under full load yet with A/C...and I don't step on it either. if things don't improve, i'm gonna make full use of the warranty...doesn't seem right...
Old Jun 12, 2006 | 12:18 AM
  #119
hiroko12's Avatar
Mileage report: 312.7 miles, 9.477 gallons. Equals 32.99 MPG. 30 percent highway, 70 percent city.
Old Jun 13, 2006 | 07:48 AM
  #120
Vladan's Avatar
I have Jazz 1.4ES since sept 2002, now 55000km on the clock. Most of it in Switzerland, last 20K in Serbia. In CH, my average for 40km trip (to my office, 14km highway 120kmph, 26km a mix of urbam and extra urban 60-80kmph) it was 5.3l/100km. On strictly highway routes 6,2l/100km
In Serbia it is around 7,5l/100km in the town, goes to 9,0l/100km with AC on and very short trips (2km).
I had a record 5,0l/100km in Serbia for my winter holiday, no highways, plenty of hills (but downhills as well), 15km without warmed up engine (while we were there), and a mixture of 60-80-100kmph roads. I obbey the speed limit+10%. I have two witnesses for this 300km trip. I know I am not very special since a friend in Switzerland made 4,7l/100km in his Jazz 1.4Ls (it is about 60kg lighter) on a mixture of 60-80kmph roads. I do not know what is Fit like, but my Jazz is fourth member of our family, my 3yr old daughter likes it very much, as well as my wife and me. All the best to other Fitters/Jazzers
