Gas mileage
Old Jul 18, 2006 | 03:39 PM
  #201
Honda Rider's Avatar
31 mpg, mostly freeway @ 80mph with CC and AC running.
Old Jul 18, 2006 | 11:12 PM
  #202
loganjnt's Avatar
update
NHBP AT sport now at 1200 miles I got 35MPG on the 5th tank!
Old Jul 19, 2006 | 07:02 AM
  #203
trowpa's Avatar
Originally Posted by RatPlanet
I got 410 miles out of my most recent tankfull.
What's your secret???
Old Jul 19, 2006 | 12:10 PM
  #204
rayzer59's Avatar
Secret
pROLLY altitude
Old Jul 20, 2006 | 02:01 AM
  #205
hiroko12's Avatar
My mileage got worse on this tank. 29.2 mpg. I don't know why. I haven't driven differently or varied from my routine. The only difference was I used Chevron instead of BP Amoco gas. This is irritating.
Old Jul 20, 2006 | 03:49 AM
  #206
buttahball's Avatar
do you pump gas at different gas stations?
Old Jul 20, 2006 | 02:00 PM
  #207
trowpa's Avatar
Wow - why are the rest of us at the mid thirties? is there that much difference between base and sport?? Are Canadian fits better mileage?
Old Jul 20, 2006 | 03:31 PM
  #208
RatPlanet's Avatar
Exclamation
No fast starts.
Watch those RPMs in 1st, 2nd, and 3rd.
Try to keep the RPM below 3500 for most of
your starts and traveling.
Feel free to FLY in 4th and 5th.
Gas Brands Used Thus Far: Marathon, Kangaroo,Texaco, Citgo
Old Jul 20, 2006 | 07:48 PM
  #209
Blinky's Avatar
Originally Posted by willmax11
The Honda .Ca site lists my LX Auto as L/100K - 7.8/5.6 . Country/City
Try and figure that out to compare to the majority of the posters to this thread.
Use Google's built in calculator function; search for "5.6L/100km to mpg"
Old Jul 20, 2006 | 09:19 PM
  #210
willmax11's Avatar
What mpg figure did you get from Google?
It only reads in American gallons.
Old Jul 21, 2006 | 07:55 AM
  #211
Blinky's Avatar
Google will want to use American units whenever possible, and usually it is possible to prefix "imperial" before the unit to switch however I have found that is not the case for converting to mpg. Therefore just use "MetricValue/1.2 in mpg", e.g. "5.6L/100km/1.2 in mpg"
Old Jul 21, 2006 | 07:59 AM
  #212
trowpa's Avatar
Filled up again today - I have a long commute and the gas is much cheaper near my home, so I can't run it down to nearly empty like I'd like...
Anyway - 216.3 miles - put 6.262 in = 34.54168 better than the dealer tank of 33.1 Hoping to see continued improvement.... My goal is to get over 35 consistantly.... Need to check tire pressure this weekend...
Old Jul 21, 2006 | 10:15 AM
  #213
Aerodynamic Head's Avatar
I'm in the same boat. I spent two tanks (since my last post) driving like an absolute grandma. Never more than 3k on the tach, and only that much when getting on the freeway onramp. the rest of the time, 2500 rpm or less. No paddles. Yes, it's all been around town driving. Same Exxon station I always use, same grade of gasoline. And so on, and so forth. I STILL can't do better than about 24.5 - 26.5 mpg. That's low, even for the city. Next week, I'll take the FiT on a roadtrip from Nashville to south Florida. That should be several tanks of nothing but cruise-control Interstate. I'll report back after that.
Old Jul 21, 2006 | 06:13 PM
  #214
fm2n's Avatar
Tell me if you guys have encountered this: I hate using my local gas station's air pump. I have to ask the front clerk to turn it on for me, then as I start inflating my tires, after 5 minutes, it shuts off. I have to ask them again to turn it on.. It gets tiring. I wonder if a foot pump from Walmart works or is it just a hassle? I'm thinking of buying a Battery Jumper/Air Compressor combo for $59. Any thoughts? I figured I could just get the foot pump for $6.00 and do the leg work (get it? ha ha). On the chart it says that it can be used for small vehicles.
Old Jul 21, 2006 | 06:42 PM
  #215
gimme's Avatar
Master FitFreaker
I have the combo charger/compressor you are talking about. 1 thing to remember is. The compressor WILL die if it gets too hot. i.e. running too long. Mine died after pumping a raft. let it run too long.
Old Jul 21, 2006 | 07:48 PM
  #216
fits2000's Avatar
Smile 36.5+?
Originally Posted by BKKJack
I have always shifted into the highest gear for the situation. If I am just cruising along, I will be in 5th at as low as 30-35mph. Granted, a downshift or two would be necessary for any acceleration, but if you are just coasting, it shouldn't stress the transmission any more than having it in a lower gear.
Sounds good, so will try this at my next fill up (which is soon, I'm at 320 Miles thus far on this tank). I will try shifting early this time and cruise at 50 in 5th. I'll also limit quick starts unless absolutely necessary. We will see if I can get my Fit to get better than 36.5 MPG, it's worth a shot.
Old Jul 22, 2006 | 09:11 PM
  #217
fm2n's Avatar
I picked up a foot pump at walmart for $6 and it seems be more convenient then driving to the gas station just for a simple pump to get get a fraction of a PSI in there. You guys should consider one to keep in the trunk. Its light and will come in handy despite the leg work (get it? ha ha). So it turns out my rear tires are at 30 PSI! I upped it to about 38 (cold). For the front tires, they were at 34 PSI so I upped it to 38 as well. I hope theres gonna be some change to the MPG!
Old Jul 22, 2006 | 09:17 PM
  #218
mjrossman17's Avatar
I checked my tires, and seems they were pretty low (not sure why). Around 28psi front, 31-32psi rear. The sidewall on my dunlops say max psi of 51. I was wondering what people think should be a good level to run them at.
Old Jul 22, 2006 | 09:35 PM
  #219
fm2n's Avatar
The tires are recommended at 35 PSI, with a Max of 51 PSI. If you load your car up with a lot of passengers, then keep it at recommended, but if its just you, up to 40 is ok. I'm keeping on the safe side and keeping at 38 PSI.
Good luck and keep us posted of any improvements.
Old Jul 22, 2006 | 09:43 PM
  #220
jrlnc's Avatar
I recently upped my tire pressure to 38 psi (cold) all around. I think that's what is helping to improve my gas mileage. I think I will pick up a foot pump too. It's a pain going to the pumps at the gas station. Their pressure gauge is hard to read.
