LED tailights, install, convert, DIYs
Old Aug 28, 2006 | 11:39 AM
  #81
604GD3's Avatar
Not that hard to install once you know where the screws are, 3 behind the taillight, and 1 hidden under the rear bumper ! (took me 30 mins to figure that out ... LOL )
took me 15 mins to install the second one :P
Old Aug 28, 2006 | 07:53 PM
  #82
fitjunkie's Avatar
NICE!!! are those OEM ones or aftermarket?? how do they fit??
Old Aug 29, 2006 | 05:49 AM
  #83
604GD3's Avatar
they are aftermarket, for 1/2 the price of the OEM;
I'm quite satisfied with the fitment
Old Sep 2, 2006 | 06:20 PM
  #84
2hot6ft2's Avatar
I got mine off eBay for $260 after s&h but the price has gone down some now making them about $210 last time I looked. And they did require some modification (the sockets are different) and wiring (wires too short on pass. side) to work. Other than that they fit perfect.
Old Sep 4, 2006 | 10:21 PM
  #85
b17gsr's Avatar
Real Honda parts?!?!?!
Old Sep 22, 2006 | 09:53 PM
  #86
stewa2jm's Avatar
LED tail light Bulbs... need help
There was a post on here i read a few months ago about led replacement bulbs for not just the fit, but all cars. The cool thing about these bulbs was that they had legs like spiders that you had to fold back when intalling, and then they pop out once in... and you get an led look from the stock setup... If you remember this, and know where to find these, please help...
I hope my description is good enough
Old Sep 22, 2006 | 10:04 PM
  #87
2hot6ft2's Avatar
Thumbs up Spiderlite LED Tail Light Bulbs
This is what you're talking about.
http://lgtautomotive.com/shop/nfosco...ff2ba13f133055
I don't know about any post regarding it but I know the product since I looked at them before.
Old Sep 22, 2006 | 11:54 PM
  #88
Mugen_Dom's Avatar
I wanted to get a couple of these for the rear turn signal but they only come in red.
Old Sep 23, 2006 | 09:40 AM
  #89
2hot6ft2's Avatar
They would have to plug in just perfect in order to work anyway since the you don't have a full circle opening inside for them to spread out.
Old Sep 23, 2006 | 04:56 PM
  #90
stewa2jm's Avatar
those are it!! Thanks!!
Old Sep 23, 2006 | 08:20 PM
  #91
Illusive's Avatar
I think if you have the JDM LED taillights, you might be able to put the three leg LED signal bulb in there...5 leg one you are taking a risk...but three leg looks OK...don't hold me to that though, I would get a set, but for $60, it's not worth it in my book...
Old Sep 23, 2006 | 08:42 PM
  #92
accordselux's Avatar
I'm a member on hidplanet.com and these were tested, modified, and retested. The output is mediocre. If they used higher quality higher output LEDs in the bulb setup, it would work great. I wouldn't recommend using these in your housings, they won't put out enough light, especially in the daytime. I had LED bulbs on my Accord and I swapped them out quickly because you couldn't tell I was braking or turning in daylight.
Old Sep 23, 2006 | 09:02 PM
  #93
2hot6ft2's Avatar
Talking You're welcome
You're welcome stewa2jm.
I went with these for my LED turn signal bulbs. I don't know of any LED's that are brighter.
http://cgi.ebay.com/ebaymotors/ws/eB...013032608&rd=1
They are bright enough to be seen in the daytime. I'm also considering the white backup bulbs but I have too many things going on right now so if anyone tries them please let me know how you like them.
http://cgi.ebay.com/ebaymotors/2-EUR...spagenameZWDVW
Also you know that you'll have to use load equalizers to run LED turn bulbs. You can't replace the flasher with an LED compatible one since they integrated it into the instrument cluster. Right ?
Old Sep 24, 2006 | 12:53 AM
  #94
Those LEDs are good for forward lighting. This is hte problem with LEDs: they're directional lighting. People behind you will see them but since they are facing outward, there is no light being sent to the reflectors as a halogen does. This means that people on the sides can't see, and the visibility is reduced because the reflector is larger and more noticable. Those are an improvement over the traditional 'bulbs' I see but I still wouldn't trust them. Neither those or those 12-24 stacks of LEDs piled on to each other...
Old Sep 24, 2006 | 08:09 AM
  #95
2hot6ft2's Avatar
Yeah I know. It would be nice if they could/would put 4 on the sides to help with that, but I think that would make it too big.
Old Sep 24, 2006 | 04:20 PM
  #96
People on HIDplanet found out that the spiderlites WERE good LEDs, but they weren't getting enough current to make them totally useful. If you swap them out for different LEDs it will work, join hidplanet.com for further info. Its not too hard if you're electrically inclined...
Old Sep 24, 2006 | 09:33 PM
  #97
aziatiklover's Avatar
Master FitFreaker
nice links ppl hahaha
Old Sep 25, 2006 | 06:03 AM
  #98
2hot6ft2's Avatar
Glad you like them.
Old Sep 25, 2006 | 11:30 PM
  #99
I would provide links but it's hard to do that because you have to be a member of HIDPLANET to see the threads...
Old Oct 4, 2006 | 11:38 AM
  #100
alclssus2020's Avatar
non-honda LED Tails?
http://cgi.ebay.com/ebaymotors/NEW-H...spagenameZWD1V
Has anyone installed aftermarket tails?
Is brightness and light pattern close to original ones? how is the build quality?
