KraftWerks Supercharger Kits
Old Mar 6, 2008 | 11:37 AM
  #521
Illusive's Avatar
I'm going to assume that the base kit probably maxes out the stock injectors, so the addition of the header will further strain the stock injectors and you could run lean. The new injectors should give you more than adequate fuel since it should support 10# of boost in the high boost kit. Better to let Oscar Jr. give you a definitive answer, but that is my assumption given the FAQ and other posts in this thread.
Old Mar 6, 2008 | 12:11 PM
  #522
Originally Posted by KraftWerksUSA.com Fit MT information
With the addition of a Header and/or Test-Pipe to this kit, our Injector Upgrade Package is required.
  #523
Originally Posted by trige
Just to clarify, this pre-order deadline doesn't apply to AT owners since pre-order for AT is not available yet, correct?
Does not apply to AT owners... Correct.
Old Mar 6, 2008 | 12:14 PM
  #524
Illusive's Avatar
So when is the estimated ship date OJR?
Old Mar 6, 2008 | 01:40 PM
  #525
The estimated ship date is still late March.
Old Mar 6, 2008 | 01:44 PM
  #526
Originally Posted by ldweng
What is the upgrade injector size and the stock injector size?
Stock:
180cc injectors(Approx.)
Flow-tested by RC Engineering
Our Upgraded Injector Pack:
205cc injectors
Old Mar 6, 2008 | 02:28 PM
  #527
thanks for the injector specs ojr, i had been wondering myself.
illusive, you are correct, the base kit dyno was on stock injectors, which do get maxed out by the kit.
Old Mar 6, 2008 | 02:49 PM
  #528
Illusive's Avatar
Excellent, enough time for me to swap over to my Air Miles CC when I get it
Old Mar 6, 2008 | 04:27 PM
  #529
Mr_ET's Avatar
If I may ask, why such a small increase? Why not go with 240cc inectors or even 310cc?
Those should be able to maintain stock driveability and give you much more room for upgrades.
It just feels like 205cc injectors will be above 80% duty cycle on a 10psi kit with other supporting mods no?
Old Mar 6, 2008 | 04:41 PM
  #530
GAFIT's Avatar
I was kind of wondering the same thing. I'm used to domestics, but those seem really small to me. If memory serves correct, to convert to lb/hr you divide by 10.5. That would make a 205cc about 19.5 lb/hr. That's still a really small injector for a FI application.
I'm guessing really high fuel pressure???
Old Mar 6, 2008 | 04:57 PM
  #531
Illusive's Avatar
Your calculation is correct.
Old Mar 6, 2008 | 06:04 PM
  #532
xorbe's Avatar
1 atm is 14.7 psi, so 5 psi is +34% air and 10 psi is +68% air?
I remember someone said the stock 180cc injectors don't like to run over 80% duty cycle. Perhaps the 205cc injectors are more aggressive than stock in this regard.
205cc / (80% * 180cc) = +42% peak fuel delivery? Seems fine for the 5# kit, so maybe the 10# kit comes with larger injectors yet. Or maybe my math is all out of whack...
Old Mar 6, 2008 | 06:05 PM
  #533
The Upgraded Injector Pack is for the Base kits ONLY. We are not talking about higher boost levels.
Mr_ET:
You will get a Check Engine Light with an injector 20% larger than stock on a stock ECU. That's just how it is. You cannot run a 240cc or 310cc on a completely stock ECU, unless you use a type of piggyback that will change what the ECU sees. Remember, the ECU NEVER sees the SuperCard.
Also, you will not have crisp start-up with injectors above 20% on a completely stock ECU.
So no, you will not be able to maintain stock drivability with that large of injector.
Yes, you would be out of injector at 10PSI with a 205cc injector. That's why the High-Boost Kit uses MUCH larger injectors. We can do that on a stock ECU because the Hondata Reflash adjusts the stock ECU to accept boost and the larger injectors. This allows us to have crisp start-up and stock drivability, with the extra large injectors.
GAFIT:
The Fit has a returnless fuel system and the stock fuel pressure is used. We use stock fuel pressure all the way to 10 PSI.
So folks, that is why we chose the 205cc. It fits perfectly with the parameters we wanted... A simple bolt-on upgrade, that could work the stock ECU and support our Header/Testpipe customer.
Old Mar 6, 2008 | 06:08 PM
  #534
Illusive's Avatar
Mr_ET:
GAFIT:
Sweeeeeeeet! So when are you gonna drop the injector upgrade price on us?
BTW, I see you guys have your own section now heheheh
Old Mar 6, 2008 | 07:35 PM
  #535
randomracer's Avatar
i read in the siphon mag that it made some kind of air purging sound.. and i didnt hear anything at the SD meet ...
Old Mar 7, 2008 | 01:10 AM
  #536
Thats cause the car was off the whole time and when it wasnt it was going 5mph
Old Mar 7, 2008 | 08:52 AM
  #537
DynamicFit's Avatar
One last question Oscar,
What exactly does the injector upgrade package entail? Is it just injectors or does it have some type of Fuel management change that is included? I'm just curious because it looks like I'm going to have to buy this kit in order to support my header and would still like to be able to swap the car over to CARB legal standards when I have to get my smog in a short period of time (ex: swap only injectors over).
Old Mar 7, 2008 | 08:55 AM
  #538
comes with injectors, clips, and an upgraded chip for the supercard.
Old Mar 7, 2008 | 08:58 AM
  #539
DynamicFit's Avatar
Thank you kindly sir. Now I'm torn over going to the full 10 lb kit uprgrade, and just the injector upgrade.
Old Mar 7, 2008 | 12:55 PM
  #540
Subscribe to the KRAFTWERKS CONSOLIDATION THREAD Version 2.0 for the most up to date information!!
-KraftWerks
OJRKraftWerks
1150
Jan 15, 2016 09:40 PM
OJRKraftWerks
19
Jan 8, 2009 07:58 PM
OJRKraftWerks
542
Nov 14, 2008 07:38 PM
OJRKraftWerks
19
Sep 13, 2008 11:45 AM
OJRKraftWerks
369
May 21, 2008 01:46 PM
