Revs staying high when flooring it?
Old 03-04-2018, 10:20 PM
ItachiSX's Avatar
Hi all, I drive a 2007 honda fit and am just wondering if it's normal or something that is up with my transmission. While I'm driving on the freeway, say at 60 mph, if I suddenly push the accelerator all the way down,the car will shift down and the rpms will stay at around 6k-7k while going up to speed to 80mph until I let go of the accelerator slightly and it seems to shift back into 5th gear. Is it normal for the rev to stick to the 6k-7k for so long? I've checked my transmission fluid and it's still pinkish and full. Transmission changes gears normally if not flooring it.
Old 03-05-2018, 12:49 AM
Goobers's Avatar
That’s... normal.
Old 03-05-2018, 02:50 PM
USDM's Avatar
Originally Posted by Goobers
That’s... normal.
Old 03-05-2018, 03:55 PM
ItachiSX's Avatar
Thanks guys, appreciate it! I only ask cause I had someone check out my car the other day and stated there was something wrong with my transmission which I found odd since I've never had a problem with the car before. That's a relief for me.
Old 03-06-2018, 09:53 AM
carotman's Avatar
If you keep flooring it past 80 mph, it will eventually shift
geneironlungs
10-05-2014 03:27 AM
GeneralLee86
08-05-2014 11:55 AM
TheRealBenzo
04-08-2010 09:34 AM
wskwong
10-24-2008 10:48 AM
pastafarian
01-23-2008 01:09 PM
Quick Reply: Revs staying high when flooring it?
