Ignition Light Ring DIY
Old Mar 9, 2009 | 11:24 PM
  #101
JDM_DOHC_SiR's Avatar
PM me I have a few left...
Old Mar 10, 2009 | 12:07 AM
  #102
reako's Avatar
PM sent....
Old Mar 11, 2009 | 05:04 AM
  #103
slydarkwolf's Avatar
Originally Posted by niko3257
thats a no for the manual locks.
the key ring itself needs a signal from
power locks in order to work properly.
now if you want you can also hook it up to
the dome light wiring. but it all depends
if your dome light stays on after you close
your door.
Ok, so you say its ok to hook the BLUE to the dome light if the light comes on after the ignition shuts off or the doors open, and the doors close the light stays on 60 sec longer....
but as for the ignition... what signal is it looking for exactly?
Red is 12v constant (self help)
Black is ground (self help)
Yellow is switched by ignition
Is the signal from the ignition any specific one? hot, run or acc?
Blue is door lock unlock
Can it be the signal from the button also?
Sorry, but I am just trying to figure it all out! >.<
Old Mar 20, 2009 | 08:25 AM
  #104
Syco54645's Avatar
does this work in the gd3? this is pretty sweet to say the least.
Old Mar 20, 2009 | 08:42 AM
  #105
Thumbs up
Sure does
Old Mar 20, 2009 | 08:48 AM
  #106
Syco54645's Avatar
really gonna have to keep this in mind. i dont fancy wiretaps though...
Old Mar 20, 2009 | 08:57 AM
  #107
Cool
It can be wired directly also...
Old Mar 20, 2009 | 09:02 AM
  #108
Syco54645's Avatar
oh got a diy going directly?
Old Apr 23, 2009 | 01:48 AM
  #109
hello_you1's Avatar
where i can get this light ring?
Old Apr 23, 2009 | 10:32 AM
  #110
niko3257's Avatar
FitFreak GE8 DIY Guy
PM Dave aka JDM_DOHC_SiR
he is the one that sells them.
not sure if he has any left.
but i guess he'll let you know that.
Old May 4, 2009 | 11:47 AM
  #111
bigmitch's Avatar
Excellent write up definitely worth a DIY Sticky. Next question where can I get one. PM me with the info if you don't mind.
Old May 16, 2009 | 03:13 PM
  #112
bigmitch's Avatar
Well just got done doing the ignition light ring mod. Want to thank Niko for the DIY write up as made it pretty straight forward. Also want to thank Dave for the ignition ring and helping Niko to get the info he needed. Had a couple of questions about the install but Nick was most helpful in answering them for me. I love this site and all the info and help that is provided. The only thing I don't like is all the money your all costing me with these mods.....LMAO
Last edited by bigmitch; May 16, 2009 at 03:20 PM. Reason: Question I had was answered via PM
Old May 16, 2009 | 03:15 PM
  #113
reako's Avatar
Originally Posted by bigmitch
The light appears to be operating correctly as red light blinks when doors are locked and turns steady blue when doors unlocked. Now when I put the key in the ignition switch the light goes out completely and comes back on when I pull the key out of the ignition switch. Not sure if this is a normal occurence or if I did something wrong as don't remember reading about it anywhere.
Scott
I believe that's exactly as it should operate. Congrats dude, nice job! I need to quit being lazy and install mine one of these days....
Old May 16, 2009 | 03:20 PM
  #114
niko3257's Avatar
great job bro +rep
sounds like it works fine to me.
Old May 16, 2009 | 03:22 PM
  #115
niko3257's Avatar
thanks
oh and yes get ur done and post up your pics
Old May 16, 2009 | 03:34 PM
  #116
FitStir's Avatar
Dave can we order these yet? check your pm.
Great mod, can't wait to get it done... +reps again niko (edit... it says I gotta spread it around more)
Old May 16, 2009 | 04:36 PM
  #117
triton.'s Avatar
Hey All,
I purchased one of these from Dave about 7 months back. Never installed still in bag. Could actually use the cash if anyones interested in it. I payed $75 for it shipped, asking for the same. PM me.
Old May 16, 2009 | 10:28 PM
  #118
FitStir's Avatar
Thumbs up
Originally Posted by triton.
Hey All,
Just pm'ed you.
Old May 27, 2009 | 09:22 PM
  #119
FitStir's Avatar
Question
I installed the LED keyring, I had some problems with the small gauge factory wires. It never really worked properly since I installed it, then yesterday it went out completely. The red light is very, very dim, the blue not as dim.
I rechecked all the wires and connections and in doing so the brown wire with the silver spots got cut. I stripped a little off each end and reconnected the brown wire with the blue from the keyring, and the lights are still very dim.
Is there anyway I can check if the unit is defective by plugging to a different wire?
Does anyone think I might have messed up the factory wires too much?
Should I disconnect the battery and try to "reset" it?
I was looking at the battery and I'm not sure if I have to disconnect the whole positive terminal or what.
Can anyone help? Dave? Nick?
thanks in advance, I'm going crazy here.....
Old May 27, 2009 | 11:12 PM
  #120
09 Fit's Avatar
If you installed the unit properly the fuse should have protected your car and the unit.
It sounds like low voltage is the culprit. I would check the wires to be sure that one has not been pinched in the installation. Look for sharp bends or flat spots in the wire. Pulling hard on small wires can also break the copper inside the insulation resulting in high resistance or no power.
Triple check that all of your crimp joints are good and tight. You may have a crimp joint that looks and feels good but the wire is not making a good connection. I prefer solder and heat shrink as I know the connection is good.
I don't know if the unit has a reset built into it or not but all that you would need to do would be to remove the fuse under the dashboard for a few minutes. No need to disconnect the battery.
Maybe Dave or Nick will have a better answer. Good luck.
