Old Aug 9, 2011 | 02:08 PM
  #3061
DiamondStarMonsters's Avatar
Bingo.
Reality just hates electric supercharging.
Old Aug 9, 2011 | 07:39 PM
  #3062
Lyon[Nightroad]'s Avatar
I had just assumed that there was no design of axial fan that could generate a decent pressure ratio. This requires more reading. There's no substitute for a turbo powered by waste energy but just the idea of an electric supercharger is fun to think about. I mean turning mechanical energy into electrical energy and back into mechanical energy doesn't really make sense from an efficiency standpoint but it's still fun to play with. Although we are really storing energy from times when we don't care about efficiency to use at times when we do care.
Old Aug 9, 2011 | 07:57 PM
  #3063
malraux's Avatar
That's actually what's surprising to me because the electrical to mechanical and mech to electrical is one of the more efficient processes; typically less than 5% energy lost. I'm surprised because that means that the waste energy from the exhaust is huge. I must have missed that day in thermodynamics.
Old Aug 9, 2011 | 08:07 PM
  #3064
SilverBullet's Avatar
What would happen if you bumped the voltage to 16 and run a dual 12/16 on the motor and ecu then run 16 volts/18 volts on the Dyson? I remember years ago they did the 12/16 volts on a engine and had a big improvement in power.
Old Aug 10, 2011 | 05:33 PM
  #3065
A quick google for "axial compressor" cleared up my misconceptions. Isn't learning fun!? Interestingly a single stage axial fan can still produce 7-8 psi.
Old Aug 10, 2011 | 05:43 PM
  #3066
I wouldn't lie to you guys
Old Aug 10, 2011 | 05:50 PM
  #3067
Well, your typical gas motor is only 20-35% efficient on their best day. So think of all that heat escaping out the tailpipe that could be used for a better purpose...
Old Aug 10, 2011 | 05:59 PM
  #3068
malraux's Avatar
It does make me wonder why hybrids go through the regenerative braking nonsense instead of sticking a turbine on the exhaust. I blame Carnot.
Old Aug 10, 2011 | 06:06 PM
  #3069
Well I understand that, they are not necessarily mutually exclusive, they are just reclaiming some of that kinetic energy that would otherwise be lost to heat with traditional brakes.
Both would be a good idea.
Frankly the atkinson cycle engine in a commuter car is not a fantastic plan as the average commuter has no idea of how to take advantage of their narrow efficiency range..
Old Aug 10, 2011 | 06:55 PM
  #3070
Same company that came up with the VTES has the TIGERS. TIGERS is basically an alternator powered by exhaust gas. There could be some interesting applications for it.
Old Aug 12, 2011 | 02:06 AM
  #3071
Jay784's Avatar
installed door visors tonight. not fun, but glad they are on.
Old Aug 15, 2011 | 06:15 PM
  #3072
Tong213's Avatar
put on the jdp wing on my base model!!!!! omg
">Name:  DSCN2217.jpg
">Name:  DSCN2213.jpg
">Name:  DSCN2215.jpg
Old Aug 15, 2011 | 06:18 PM
  #3073
Jamy's Avatar
Looks nice! How'd you attach it if you don't mind me asking?
Old Aug 15, 2011 | 06:23 PM
  #3074
Tong213's Avatar
random 10mm screws and fittable washers
some drilling and 3m tape
Old Aug 15, 2011 | 06:25 PM
  #3075
Jamy's Avatar
Think it could be done with just the 3M tape? I'm iffy about drilling into the body of her.
Old Aug 15, 2011 | 06:31 PM
  #3076
Tong213's Avatar
i was iffy too but ran into a fluke
i thought i would have to drill all the way through but nope
i was able to have washers fitted in between the 2 layers of the trunk just like how factory spoilers are put on
3m tape... i wouldnt recommend you do just tape.... if it ever falls off... you'd cry.. i just use it to seal any super big gaps or anything and to hold the over all position
Old Aug 16, 2011 | 09:20 PM
  #3077
Tong213's Avatar
so yesterday i put on my wing
now i am always checking if its stable or not, checking if the bolts will loosen and fall off
can someone reassure me?
Old Aug 17, 2011 | 05:22 AM
  #3078
Black3sr's Avatar
It will stay on til you hit 60mph.
Old Aug 17, 2011 | 05:58 AM
  #3079
Goobers's Avatar
No, no... when it hits 88 mph, it'll travel in time... travel back and forth so fast, it'll look like it's only going 88 mph... but the driver will feel like he's been behind the wheel forever!
oh wait.
Old Aug 17, 2011 | 07:46 AM
  #3080
Krimson_Cardnal's Avatar
Goobz must be home - waking up feeling like he needs to drive 652miles... welcome back.
