Old Oct 28, 2014 | 07:29 PM
  #11921
07fit916's Avatar
Originally Posted by FitStir
Which is why I should've changed the CMC already to the one Item9 modifies... the thing I like about that one is that it's the exact same unit, just modified, so it should be a direct swap. No need to bend any lines, etc, etc.
That's the exact reason I went with the ITEM9. Took about 2 hours including bleeding the clutch after. I didn't really know what I was doing and took me forever to get the big chunk of harness out of the way.
I can see not needing it. In fact most of the time it didn't bother me. (Similar to how I felt about the lack of a dead pedal in my GD.. then I bought one.) After about a year of driving the GE and still getting a random awkward shift here and there, I figured I would give it a try. It feels a lot better and it really didn't cost that much. Maybe I can't drive or adapt or whatever. Doesn't really matter to me. It's like any other mod. Its your car. Do what you want. But I'll say again, if you've been on the fence about it, just get it. You probably wont be disappointed.
And for Wanderer and anyone else in the Bay Area or Sacramento, you're free to try it out at the next meet I make it out to.
Old Oct 28, 2014 | 09:29 PM
  #11922
Speedlimitz's Avatar
Got these today :/
The shipments are starting to roll in now.
[IMG]Name:  qHFK0WE.jpg
Old Oct 28, 2014 | 09:46 PM
  #11923
1SickVeilsideZ's Avatar
^^ Let's pull them out the box and see what you got!
Old Oct 28, 2014 | 10:08 PM
  #11924
Goobers's Avatar
Wanderer is right, in that i wasn't arguing whether it was better or not.
My only real issue was that some folks want to express their opinions as facts and say "everyone" should do this or that because they like it that way.
I wholeheartedly agree that having some, majority or even all users able to adapt to something doesn't make it better... However, by the same token, having people unable to adapt (regardless of experience/willingness), doesn't necessarily make it bad either.
We can come to some conclusion about it being good or bad, if we set rules/conditions for it. But it becomes specific conditions... would it slow down a race driver? Probably in fractions of seconds, even though it can make or break a race. Would it prevent said racer from shifting smoothly? No. Where those fractions of seconds aren't quite so important, could a person drive aggressively and still smoothly? Yes. All conditions require time and effort though. So on and so forth.
If you don't like the CDV, its your prerogative to change it or not, and that being said, I agree with 07fit916 in that, if you're on the fence, it could be worth a try. Worst case scenario... You change it back (unless something or other breaks).
Pozzi, in regards to your shifting out of gear only after fully depressing the pedal... I don't, but I guess it is because I've become used to the basic timing and position if the pedal where it (dis)engages.
Old Oct 28, 2014 | 10:17 PM
  #11925
[IMG]Name:  tcwVdWh.jpg
Old Oct 28, 2014 | 10:30 PM
  #11926
^^ Nice! What are the wheels specs?
Old Oct 28, 2014 | 10:31 PM
  #11927
555sexydrive's Avatar
De36, they are 16x7+42 and tires are 215/45R16 all around. Nothing good in sizing really to stagger with the Miche(err, BFGoodrich Rivals) and keeping circumference similar front and rear. On my 15" CE28s was using AD050s in 215/50 fr and 195/55 rr as they are in circumference just 3mm different,but fronts wear away faster (595mm to 592mm) in width it was 229mm up front and 205mm rear and the car felt really good, neutral and predictable with that sizing. The BFRivals are 213mm wide, so giving up a bit of width on the front end and gaining in the rear (hopefully doesn't induce more understeer), but it may not be a bad thing being that the fit packs ovaries and not testes under the bonnet so the decreased width may speed it up with less friction fighting the anemic power output.
Old Oct 28, 2014 | 10:38 PM
  #11928
Nothing crazy 16x7 42offset
Old Oct 29, 2014 | 12:09 AM
  #11929
Waiz's Avatar
Avid FitFreak Poster
BBS!
Old Oct 29, 2014 | 12:41 AM
  #11930
HellFighter13's Avatar
New exhaust setup
Recently went done to muffler shop and had my cat and res removed and welded in test pipe and straight off the headers through straight pipe. Sounds sick as hell. Very loud
Old Oct 29, 2014 | 12:50 AM
  #11931
Originally Posted by Speedlimitz
[IMG][/IMG]
Edwin's old wheels?
Old Oct 29, 2014 | 09:17 AM
  #11932
^^^ they are the same wheels he ran but not his wheels. Bought mine new
Old Oct 29, 2014 | 01:04 PM
  #11933
FitStir's Avatar
Originally Posted by pozzi
Not to take away from Item9's business, but the 01-05 Civic (non-Si) CMC is a direct replacement for the Fit minus the CDV. No bending lines or modifying anything.....
From what I remember there was some line bending involved. But there's 2 DIY's now... don't think I read the newer one.
Trust me I'm definitely not on the fence... I will do this sooner or later.
The main thing holding me back is free time.... and lacking the necessary skills. I might be able to build the fk out of a house from foundation to finish.... but I'm not too experienced with auto maintanance.
If anyone in the NYC area wants to teach me some skills I can get this done before the snow season starts. lol.
Old Oct 29, 2014 | 02:19 PM
  #11934
Vilot's Avatar
Bought a Visual Garage shark fin antenna, complete interior LED kit, Air Scoop from Showoffimports.nl, Lamin-X yellow film for the fog lights.
Just waiting for mister postman to knock on my door!
Old Oct 29, 2014 | 03:19 PM
  #11935
xxryu139xx's Avatar
Air scoop?
Old Oct 29, 2014 | 03:33 PM
  #11936
Vilot's Avatar
Air scoop?
Yes sir! Have look here: Showoff Imports.nl :: Performance :: Air Intake Systems :: Honda Jazz/Fit 08-12 Air Cooler Kit
haven't received it yet, but I'll gladly report back!
Old Oct 29, 2014 | 05:01 PM
  #11937
Quick pic with new wheels
[IMG]Name:  ZFXE0WW.jpg
Old Oct 29, 2014 | 05:09 PM
  #11938
xxryu139xx's Avatar
I hope u dont have a usdm. It wont fit. The wiper cowl is different. Note the wiper nozzles.
Old Oct 29, 2014 | 05:49 PM
  #11939
Vilot's Avatar
Thanks for the heads up, luckily it's a EU/JDM model. Hopefully it'll fit!
  #11940
Goobers's Avatar
Are you sure? The nozzle isn't exactly a telling difference.
