Old Oct 14, 2014 | 02:23 AM
  #11841
07fit916's Avatar
Filled my rear torque mount with 80A urethane over the weekend and today did the clutch delay valve delete with a cmc from ITEM9. If you were on the fence about doing the delay valve delete. DO IT.
Old Oct 14, 2014 | 02:39 AM
  #11842
YeahItFits's Avatar
Senior Member
Went on a little over my budget this weekend.
Picked up another set of Retrofitted Headlights.
LS460-R Projectors.
Osram CBI D2S 5000k Bulbs.
I need new ballast. I'll be ordering soon from RetroFit Source.
My prev set.
Infiniti M45 With TSX Clear Lens Swap.
Also picked this set up.
J's Racing Oil Cap.
J's Racing Radiator Cap.
Attached Thumbnails What did you do to your GE fit today?-20fwyh1.jpg   What did you do to your GE fit today?-sy56xy.jpg   What did you do to your GE fit today?-2n730o1.jpg
Old Oct 14, 2014 | 02:16 PM
  #11843
Waiz's Avatar
Avid FitFreak Poster
Damn, everyone is getting new stuff but me
Old Oct 14, 2014 | 02:39 PM
  #11844
spryter's Avatar
I love the look of my J's oil cap. The J's rad cap is on my list of parts to buy over the winter.
That's the nice thing about Canada: We have two seasons for driving, a season for buying parts, and a season for doing the actual mods.
Old Oct 14, 2014 | 11:13 PM
  #11845
YeahItFits's Avatar
Senior Member
LOL! I haven't gotten anything new for the fit for a while.
You got new Mugen not that long ago. haha
Yes, it's awesome.
Los Angeles is all year. Kinda good, kinda bad. hahaha
Old Oct 14, 2014 | 11:29 PM
  #11846
Yes, it's awesome.
ANOTHER NEW MOD?
What is happening?
Old Oct 14, 2014 | 11:34 PM
  #11847
Waiz's Avatar
^Welcome to last month, you just didn't notice they were made SM's
#newsteamassemble #voltron
Yes, it's awesome.
September was my birthday month, I went big
I just felt left out this month
+1 to Cali "seasons" I live here for a reason!
Old Oct 15, 2014 | 12:14 AM
  #11848
painterguy's Avatar
Senior Member
Installed my Tanabe coils thanks to my bro 1SickVeilsideZ.
Attached Thumbnails What did you do to your GE fit today?-1ef4fe21-9aad-4dfc-aca0-1fe9882eac93_zps9uwaeobh.jpg   What did you do to your GE fit today?-8202ddb1-0848-4406-a5c9-543fa0fe8eb8_zpse1f45ig1.jpg   What did you do to your GE fit today?-bd4362be-1f01-4c10-93ed-37dd01e316d0_zpshwmccs5t.jpg
Old Oct 15, 2014 | 12:16 AM
  #11849
Waiz's Avatar
Glad to see it get all worked out Erik!
Old Oct 15, 2014 | 01:00 AM
  #11850
spryter's Avatar
Yes, it's awesome.
I've always wanted to go out to Cali and see what all the fuss is about.
Old Oct 15, 2014 | 08:48 PM
  #11851
Mr.Dan's Avatar
Finally found a set of my dream wheels:
Untitled by Mr.Dan71, on Flickr
Old Oct 15, 2014 | 09:14 PM
  #11852
^Man, you're bringing hot fire lately!
Old Oct 15, 2014 | 11:52 PM
  #11853
Waiz's Avatar
Nice wheels and brakes!
Old Oct 16, 2014 | 12:47 AM
  #11854
Burzpaw's Avatar
FitFreak Community Team
I was planning on getting those brakes when I need changing!
Old Oct 16, 2014 | 02:10 AM
  #11855
FittedOnEm's Avatar
dayum, killin me with that brake setup..
Old Oct 20, 2014 | 02:10 AM
  #11856
YeahItFits's Avatar
Senior Member
Installed the new lights this weekend.
Attached Thumbnails What did you do to your GE fit today?-b6acyp.jpg   What did you do to your GE fit today?-2cda5w0.jpg
Old Oct 20, 2014 | 09:36 AM
  #11857
MEATBABY's Avatar
Volk Formula lug nuts...you bastard.
Old Oct 20, 2014 | 12:42 PM
  #11858
Waiz's Avatar
Nice headlights Juan, good work!
Old Oct 20, 2014 | 06:11 PM
  #11859
gkitf16's Avatar
Battery tray clean-up
I did a stupid thing 6-7 months ago, however well-intended. I was checking the battery electrolyte levels, and topped them up with distilled water. I overfilled the cells by mistake, forgetting they should only be filled above the plates, and just below the "ring" in each cell.
Fast forward to now. I had begun to notice a wet area and crud starting to appear beneath the battery tray area. Strangely, no buildup at all on the battery terminals themselves. Time to have a look and clean this up. Here's what it looked like before/after cleaning, what a mess.
https://www.facebook.com/photo.php?f...size=959%2C539
Gas generated by charging caused a good deal of acid to escape over time. I drained several ounces from each cell with a syringe to the proper level. Getting the battery tray out isn't hard, but the 2 12mm bolts beneath it are a pain. Need a long extension for the front one, and either a ratchet/socket or closed-end wrench for the back one. You only need to loosen them, as the tray has slotted mounts here.
Cleaned all areas with baking soda, scrubbed off the crud, rinsed/dried everything with compressed air. Then sprayed the frame rail and battery support tray with Rustoleum Rust Reformer. Didn't bother with top coat yet, but may do it later on.
One important note, when dealing with the battery terminal clamps, they have almost no tolerance if the battery posts are worn. I discovered this when I tried to tighten the + clamp, it wouldn't hold. You will need to add a post shim such as this:
http://shop.advanceautoparts.com/p/a...tery+post+shim
Keep a pair in your toolbox next time you need to remove the battery. No fun getting stranded if you can't make that clamp stay put!
Old Oct 20, 2014 | 10:57 PM
  #11860
YeahItFits's Avatar
Senior Member
Thanks Wais!
Really digging them.
I love that they look stock to the untrained eye. Lol
