After major drop, positive camber. WTF? Pics Inside.
Old 09-26-2012, 03:02 AM
sabawballs's Avatar
sorry to bump this thread but i too installed my coilovers and gave me positive camber T_T. .4degs driver side and .3degs passenger side.
OP did camber bolts fix the issue? kinda weird to me since usually when you lower your car, it should give negative camber
Old 09-26-2012, 08:23 AM
SickFit's Avatar
Yup. Camber bolts solved it!
Old 09-27-2012, 09:18 AM
RedShiftChris's Avatar
One thing to consider is that if you have lowered the car enough to get positive camber, that mean either the bolt holes on the new struts are off (hopefully) or that you have lowered the car so far that it's FAR outside it's proper camber curve to handle well.... meaning if it sits statically (still) in a position where any further compression of the spring will provide for positive camber, then you will have an absolutely retarded handling balance. Might want to consider raising the front a bit.... that's what most guys do on track cars when that happens because best performance is had where the suspension geometry is proper, even if it means the center of gravity is a little higher.....
And from a technical point of view, when you lower a strut car, you increase the roll couple (the length between the roll center and center of gravity), and that makes the front of the car want to roll more, thus making it understeer more usually. So, it's a double negative. So, running the front of the Fit a touch higher than "slammed" is definitely a good idea.
Hope that helps a few of you who care about your handling.
Chris
Old 09-27-2012, 10:11 AM
mkane's Avatar
^^^^^^^^^^^^^^^Ding ding ding.
Old 09-27-2012, 11:22 AM
apexanimal's Avatar
since the upper knuckle hole is elongated, did you check this? you shouldn't use a camber bolt with an elongated hole that 's already designed to give you more camber...
Old 09-27-2012, 01:07 PM
sabawballs's Avatar
funny this is i'm on 17s and runing a 45 series tire.. only having around 1.5-2 finger gap so i think i'm far from slammed
still getting positive camber though.. weird.
Old 09-27-2012, 02:49 PM
that is odd. and it's pretty tough to make a mistake on the install on this car...
Old 09-27-2012, 09:10 PM
Tommy C's Avatar
Car looks great!
Sorted it out yet?
Old 09-28-2012, 11:44 AM
It has to be the way the holes are drilled on the strut then... nothing else (and I mean not a single other thing) will affect camber on the Fit.
Chris
Old 09-28-2012, 12:00 PM
SickFit's Avatar
Originally Posted by Tommy C
Car looks great!
Sorted it out yet?
Thanks!
Yup. After putting new wheels on the car i bought the camber bolts and they solved the issue. They've been perfect since.
whitefitsport
10-02-2018 10:54 PM
ciref8
10-17-2014 12:31 AM
Nvillegas
01-09-2014 01:05 AM
flushge8
Hawaii Community
41
02-17-2010 01:25 AM
nealy
09-15-2009 10:57 PM
Quick Reply: After major drop, positive camber. WTF? Pics Inside.
