MODS/ACCESSORIES for the GK
Old Nov 27, 2015 | 03:22 PM
  #1241
BeauDiddley's Avatar
Originally Posted by jhn
I put a rubber all fit lip on it. I don't know if I like it. What do you think?
I think it looks pretty good. I'm torn between trying an $80 polycarbonite universal splitter from eBay or just going the Home Depot cheapo lip.
Old Nov 27, 2015 | 03:28 PM
  #1242
jhn's Avatar
jhn
Yeah medium. I think you're right small might look better
Old Nov 27, 2015 | 04:24 PM
  #1243
TorontoBoy's Avatar
I thought that there was some kind of lip already underneath the car? It is not very tall, which is good for me, as the snow is coming and I need all the clearance I can get. I'm wondering if the Fit is too low for the snow?
Old Nov 27, 2015 | 04:30 PM
  #1244
Bassguitarist1985's Avatar
HDMI Mirroring While Driving: Step my Step Procedure
Not a mod, but a worthy hack worth noting to the forum community.
***The SNAPSHOT step does NOT work, so skip it. Supposedly it will save the setting but it does not work, least for the 6MT Still once you memorize the screens it takes me about 20 seconds to flip the error menu off and I'm off and running!
****DISABLING THE DD VSP ERROR MENU I'VE HEARD MAY CAUSE SOME ISSUES WITH PEOPLE WHO HAVE AUTOMATIC CLIMATE CONTROLS. RE-ENABLING THE ERROR WILL FIX ANY POTENTIAL BUGS. NONE OF THE USDM FITS HAVE AUTO CLIMATE CONTROL FOR 2015. I DON'T THINK ITS THAT TERRIBLE TO CAUSE A MAJOR MALFUNCTION THOUGH.
Old Nov 27, 2015 | 06:21 PM
  #1245
jhn's Avatar
jhn
Yeah, there is one I took it off though.
I guess too low for the snow is subjective: it depends on the amount of snow and how well the roads are maintained.
Snow is not an issue for me.
Old Nov 27, 2015 | 06:23 PM
  #1246
jhn's Avatar
jhn
I didn't see the splitters out there but I don't think I could A/X in my current class with one. This one is a kit from All-Fit.
Old Nov 30, 2015 | 07:53 PM
  #1247
drloot's Avatar
Originally Posted by rikerr
Got the windows tinted yesterday.
Is your top tail light blacked out? Ive been looking into blacking out the reflectors (dont know if I can separate the red cover from the reflector yet). Also looking to black out or D/C the LEDs of the top stop light.
Also, how much was your tint job and what kind did you use?
Love the white gen 3!
Old Dec 9, 2015 | 04:07 PM
  #1248
D33DsY's Avatar
I've been trying to decide if I want to go this route..glad you posted up a picture. I'm still on the fence. I wish something aftermarket would come out that would fit the US front end . I keep drooling looking all the lips overseas.
Old Dec 9, 2015 | 04:52 PM
  #1249
Action Jackson's Avatar
Gas hood struts
Old Dec 9, 2015 | 08:38 PM
  #1250
jhn's Avatar
jhn
I like it for the flexibility and it's cheap. It's pretty low and it scrapes on some entrances.
Old Dec 10, 2015 | 08:00 AM
  #1251
2Rismo2's Avatar
Originally Posted by Action Jackson
Gas hood struts
Looks great. Appears to be an easy install, but any gotchas that you ran into?
Old Dec 10, 2015 | 10:23 AM
  #1252
Here's more pics: https://www.fitfreak.net/forums/3rd-...ml#post1328994
The "gotchas":
Smaller front brace will need to be mounted facing forwards, not 180 facing backwards as pictured. It will just rotate if installed as above.
You cannot over tighten forward bolt as the "nut" is the plastic housing of the headlights.
The paint there will get scratched.
Hood opens up a little farther back.
When you open or close the hood, you can see the front bodywork and headlight housing flex (only a bit) just under the front brace.
Attach the strut to the front brace first b/c if you have to compress it, it's easier to compress it forwards, rather than pushing the hood away from the hood prop if you did the longer brace first.
Don't lose that pin!
Old Dec 13, 2015 | 01:21 PM
  #1253
Got a stainless steel glove box handle stick on trim.
http://www.ebay.com/itm/281643303768?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Problem is, that it's 2 mm too tall. So you can install it, and it will cut into your fingers, or install it higher, and you can't open your glove box.
Return requested.
Old Dec 15, 2015 | 03:16 AM
  #1254
NewShockerGuy's Avatar
Arrow
Originally Posted by JimTheSoundGuy
Drummingfish, I paid $159 on eBay for my set from motoringmax. Assuming that they are all being made at the same factory in central China I can only recommend working with a merchant with a high service rating. I would give the quality a 7.5/8 out of 10, but is still definately worth it from a safety point of view. The increase in lighted area is substantial and all those LEDs keep the tailgaters at bay.
Also: do NOT trust the wiring diagram, I had to re-pin both of the harness extensions that came with mine to get them to function as described; not difficult, just frustrating, so test your leads early in the installation. You will tap the black, white, and green/white leads running to the stock taillights. If you only have LEDs under braking, try swapping the red and white leads to the pillars. That was the problem with mine.
Supplies Needed:
10mm socket
wire strippers
heat shrink
basic soldiering kit
friend to turn lights on/off and hit the brake pedal
An hour to figure out the first one, 20 minutes to install the 2nd.
You won't be disappointed with the results when you see these things in action.
I want to get these for my sister's new fit. They look good. Any issues other than the wiring which is an easy fix? Any leaking/fogging...etc. Overall do they look like OEM when they are lit up? Any LEDS burn out...etc.
Thanks,
-Nigel
Old Dec 15, 2015 | 08:17 PM
  #1255
Maxplo's Avatar
Heres my 2015 lx fit
-16" fast mag
-interior led
-led for liscence plate
-custom led tail light
-headlight led
-blinker led
-foglight led
-24" led bar
-k & n air filter
-honda type r shift knob
-spoon sports n1 catback exhaust
-jl audio 10" subwoofer with 500 watt rms amp
-plastidipped honda emblem
-i-vtec emblem and sticker
-35% tint all over
Attached Thumbnails MODS/ACCESSORIES  for the GK-image.jpeg   MODS/ACCESSORIES  for the GK-image-2-.jpeg   MODS/ACCESSORIES  for the GK-image-1-.jpeg
Old Dec 16, 2015 | 01:13 AM
  #1256
Is that led light bar behind the lower grille or in front? I like the idea of having one but would rather it not be sticking out to be easily damaged or stolen.
Old Dec 16, 2015 | 09:10 AM
  #1257
-16" fast mag
-interior led
-headlight led
-blinker led
-foglight led
-24" led bar
-k & n air filter
-35% tint all over
I too am interested in more pictures of the light bar. I was even thinking of installing it with powerful magnets on the roof in front of the sunroof. My concern with mounting it on the grill is air flow restriction for the summer months, it could compromise cooling efficiency.
Where did you get it?
What Model?
How did you wire it? My thought was to wire with the fog light relay.
How does it look at night? Likely a 60 degree spot pattern I'd imagine.
Old Dec 16, 2015 | 12:40 PM
  #1258
Maxplo's Avatar
Hi, yes it is behing my grille! The led bar is bolted to my bumper and wired directly to the battery and a switch in the interior. I got if off ebay, it's a cree 24" 240W, I was impressed the first time that I tried it at night!!
Attached Thumbnails MODS/ACCESSORIES  for the GK-image-3-.jpeg   MODS/ACCESSORIES  for the GK-image-4-.jpeg
Old Dec 16, 2015 | 01:40 PM
  #1259
KentFinn's Avatar
And what do the local LEOs have to say about that light bar? I'm afraid that it would cause all sorts of consternation here in Tennessee.
Old Dec 16, 2015 | 02:08 PM
  #1260
bigbacon's Avatar
I waited as long as I could for K&N to bring a cold air intake to market for the GK5 and got tired of waiting.
My AEM Intake arrived yesterday and this morning it went into the Fit. Part# AEM 21-748C $249.99 on Amazon Delivery time 7 days
The AEM installation was not without it's issues:
1) The instructions call for an 8mm socket to remove the hose clamp on the transition coupler. It isn't. It is (probably) 3mm which I didn't have and I doubt you do either. Be careful taking a screwdriver to it, the phillips head is soft and easily stripped.
2) While the instructions are (for the most part) very detailed, there is a step and diagram missing before "carefully remove stock airbox" that should say "Locate these two bolts under and behind the stock airbox and remove them " otherwise that sucker isn't going anywhere!
3) Finally, there was alot of mold flash left behind in the MAFS opening that had to be removed with a fine metal file before the Mass Air Flow Sensor could be fitted into it. Also, the gunmetal grey finish had clumped around the edges where the sensor is meant to sit flush which also had to be filed/shaved away to ensure a good seal.
Having now installed the K&N on my GE8 and an AEM on my GK5 I have to say that K&N got it right and AEM got it close. The sound is certainly an improvement over stock, I will report back with driving impressions and fuel efficiency changes in a few tankfulls.
If anyone is curious, the Tanabe strut tower brace does not interfere with the installation at all. The heat sheald can be maneuvered into position without scratching either piece.
how does a tube and a filter mashed right in the engine bay, where it gets really hot, count as a cold air intake?
