Look what my Fit dragged home(towing)
Old Sep 29, 2017 | 06:43 PM
hasdrubal's Avatar
Homebuilt stuff is often experimental and not subject to the same requirements as production aircraft. Not sure what all the differences are, but I saw some people using RX7 engines, so it can't be too strict.
Which generation engine, and is there much in the way of mods to turn it into an aircraft engine?
Old Sep 29, 2017 | 11:46 PM
Sono's Avatar
Originally Posted by TorontoBoy
The Fit's engine will never get that plane off the ground! Turbo or not.
someone's trying it...lol
Old Oct 6, 2017 | 11:25 PM
carol r's Avatar
Can't find a link to Bassguitar1985 posts. Want to tow small trailer with the occasional sheet of plywood on it. Suggestions?
Old Oct 7, 2017 | 08:10 PM
GBR- any pict of your glider assembled at this new home you towed it to?
Old Oct 8, 2017 | 09:10 PM
Bassguitarist1985's Avatar
check my links here.
Old Oct 8, 2017 | 11:39 PM
hasdrubal's Avatar
carol r, if you click on his username it will pull up a menu, go to 'find all posts by.' If you look at some of the older threads, he's got links in a sig. Not seeing links in the last post for whatever reason. Or try these-
https://www.fitfreak.net/forums/gene...otorcycle.html
https://www.fitfreak.net/forums/3rd-...ing-hitch.html
https://www.fitfreak.net/forums/3rd-...ack-pearl.html
airwicc
Mar 24, 2018 04:33 AM
SilverEX15
May 5, 2015 12:02 PM
ncrspike
Apr 29, 2015 04:01 PM
sooznd
23
Jan 20, 2015 12:08 PM
FotoFit
Apr 4, 2008 12:00 AM
