Anyone else get a loose engine splash shield under their car?
I also use car ramps but just regular ones, not low profile versions. It looks like that rubber that is hanging down along the front will hit the ramp going up at first but it misses it when you actually go up. With the ramps it still feels like a bit of a tight fit when going under the car. The Fit is definitely lower as compared to my Civic on the same ramps.
I strongly agree with you, its not changing oil shops not putting the screws back, I bought my Honda with only 2000 mile on it, no chance they changed the oil before, yet the tray was loose, with close look I found scratches from read bumper.
I car is so low to save on gas, high cars cause wind turbines under.
if you can find a way to raise Fit please share it.
Mine was just half falling off. It was flapping on the ground under my car.
I'm not talking about wheel splash guards, but the thin plastic under the cars engine.
Apparently like half the plastic tabs fell out and it was hanging down and hitting the road.
I did get an oil change at my dealership a couple weeks ago. Would it be from that? Or did half the tabs just fall out on their own?
We zip tied it back on and used a couple screws too. My dealership can't get me in til later this week...will I be ok to wait?
And anyone else have this problem?
I've only had the car 8 months!
I just searched eBay, didn't save the link.. there were numerous vendors selling them, there are 2 diameters and 3 lengths used on the GD near as I can tell.. I don't even try to save them, I just break them and install new ones.. They are available on Aliexpress too, fwiw..
100 Pcs Bumper Hood Fender Splash Guard Retainer Clips Fasteners for Honda Acura | eBay
This guy is where I got mine. He has a lot of interesting stuff.
I don't even re-use them for 5 bucks a hundred..
Oh, and at least the ones I got, are ferocious for staying in, basically I punch them through with a screwdriver breaking the head off.
So did the part 74111-T5A-900 fit the 2015 fit? Mine needs to be replaced.
There are 3 sizes of the plastic fasteners in the front end
I think they are two thick ones with a reach of about 5/8 inch and about 3/4inch and a smaller one in the fender liner that attaches the liner to the fender at about the 2 or 10 o'clock position depending on which side your on.
Most of them are the thick ones that reach in about 5/8.
And if you look closely your AC pump is totally in jeopardy of road spray without the guard.. It also get a lot of water on the firewall without it in the rain, especially on the passenger side. The belt takes a lot of wet as well if the guard is gone.
I seriously doubt it's there for anything other than a slight increase in mpg by streamlining airflow under the car....engines and accessories have gotten splashed for 100 yrs, am sure Honda's modern parts are up to a lil splashing without a need for a plastic shield....salt is not an issue here in east TN
Count me in
Obviously in dry weather its likely a non issue..
I just did an oil change and one of the plastic screws was just spinning when trying to back it out. I had to jam a screw driver under it while I backed it out for it to come out. I don't think it would have fallen off, but I replaced it with a spare I ordered the last time I ordered online. It came in handy. 28k miles and still on there and it has taken some bumps and scratches from the potholes we get in the DC metro area.
Those plastic "screws" aren't really screws. They are expansion fasteners where you push the "screw" straight into the expanding part to spread the end out. The "threads" are just there to make it easier to remove. If you do the normal thing and push inward while unscrewing it will just stay in place, feeling like the thread is stripped. If you push inward with a very light touch it will come right out. Not a fastener for a ham-handed mechanic.
To reinstall, you don't have to screw it in. Just push the "screw" straight in and you are done. You can't get it tight since it isn't made to tighten.
Yes, Honda could have done it better, but it is really just made to facilitate assembly. the push fasteners do the initial positioning for the insertion of the metal screws.
Same thing happened to me. My splash guard came off on the HWY not 10 mins after leaving the dealer from an oil change. They put the front two push pins in and not the other 4 with screws.
Needless to say they bought me a new panel and i put it on myself.
One day, some day Honda will be forced to adress this issue. I'm starting to think there engineers knew what would happen and frankly put it out anyway to generate income both for the dealership and Honda . Because our Fits do have a low ride height Honda should have known better ..
Do not run over stuff.
It's not a tank, it's a car. Buy some hyperopic glasses.
I had two dealer oil changes thus far on my 2015 FIT, but like everyone else, my access panel (splash guard some people here call it) came crashing down on one side while on the road. It happened approximately 2 months and 3000 miles after the last oil change so I am not sure what caused it?
Heard a loud scraping coming from something outside the car. Thought at first that I ran over a box or something and was dragging it.
Stopped in a shopping center parking lot and looking toward the back of the car from the front, you can see the panel left side on the ground.
Called AAA, who jacked up the car and removed the panel so I could get home.
Next day, brought the panel to my long time Honda dealer. Service advisor said that it's not unusual for the plastic clips to break or come off on these panels.
He ordered a technician to take my car immediately to the service bay and re-install the panel no charge. They fixed it immediately.
I will now be closely watching this panel since it is an issue.
Fortunately, this time I was driving slow and was able to turn into a parking lot space. But if I was on the highway like I was last weekend at 75 MPH going through Death Valley, this would not have been pleasant.
As a side note--AAA guy told me these Honda panels come off all the time--he said Honda never used them on any cars for decades--leave it off. He said it's a Honda thing to put these panels on, but not necessary. That was his thought, although I read here that some people think they protect the electrical system from water?
Thank you to everyone that posted here with a similar panel problem. Sounds like Honda needs to come up with a better way to secure this panel. Something like that should not come off while driving absent severe impact. The panel dislodging could cause it to turn into a projectile on the road, cause underside damage, and possibly a collision. Nothing should be coming off a car under normal use.
